jaa1992 | Replacing things on my 92 | ||
Questions:
My Flywheel has over 100k (DM). I probably will be pulling my engine around Labor day. Good/bad idea to change clutch and flywheel at same time? Should I get everything from Carolina clutch? Aluminum or steel flywheel? Stock replacement or stage2? I don't care about the extra noise. I use the car 20% on the street and 80% on road courses. Engine rebuild: Most I can go is 355 ci without rollcage, truck and trailer. Any issues with using something like this from Summit? THanks in advance |
Posted on: 2009/7/14 16:03
BrianCunningham | Re: Replacing things on my 92 | ||
Dual Mass flywheels are getting hard to find.
See if you can even locate one. |
Posted on: 2009/7/14 16:42
jaa1992 | Re: Replacing things on my 92 | ||
Thats why I was asking about steel or aluminum replacement flywheels. I'm not going to worry about finding an unobtanium DM.
Checked Carolina Clutch website and it turns out the flywheels are the same price (AL ot steel). When it gets closer to "pull the engine" time I'll order the aluminum. Any machine shop should be able to match balance it with my current DM - right? Looks like they don't cary things like throwout bearings, clutch forks and slaves for the ZF. Any preferences for suppliers or just order from autozone or the like? |
Posted on: 2009/7/14 17:22
The aluminum one I got for my dual disk setup came with removable weights, in case I internally balanced the engine. Which is exactly what I did.
I don't know about the others. |
Posted on: 2009/7/14 17:55
rklessdriver | Re: Replacing things on my 92 | ||
I know for a fact the Fidanza Alum, SPEC Steel and the SPEC Alum all come with a removeable weight so you can internal balance.
Yes a machine shop with a balancer should be able to trim the weight or add weight to match balance a new SM FW to your old DM FW. I have a Fidanza Alum SM FW on my personal car and an engine I built last year for a friend over on CF, we used a SPEC Steel SM FW. Both were nice FW's, fit properly and yes the tranny noise is noticeable as compared to the stock DM espc since both of these cars have pretty healthy camshafts. Will |
Posted on: 2009/7/14 18:01
Stl94LT1 | Re: Replacing things on my 92 | ||
If you are rebuilding the engine, it will probably need to be rebalanced. At this point the DM balance will be out of the equation.
Posted on: 2009/7/14 18:38
Jeffvette | Re: Replacing things on my 92 | ||
Rebuild the motor to zero balance, then add the flywheel and balancer.
Posted on: 2009/7/14 18:47
SpectatorRacing | Re: Replacing things on my 92 | ||
I have used the Caronlina Clutch stage 3, with the Fidanza Aluminium flywheel for about 4 years on the race car. I had the motor out last month for a refresh and the clutch and flywheel were in great shape. Of course I bought a new friction surface for the flywheel, but that's just an insert. Be careful installing the flywheel if you go aluminum. Lots of them strip the bolt holes that hold the clutch assy to the flywheel, including mine. Although the helicoil repair has held for as many years.
What are your goals for the rebuild? Personally, I'd use individual parts instead of a rebuild kit. You can do better for similar money for bearlings, oil pump, and gaskets. I used Clevite coated bearings and Speedpro file-to-fit rings, and of course Felpro gaskets everywhere. What about the heads, anything for the top end? Valve job and a new valvetrain is recommended at the least. As stated above, get the motor rotating assembly balanced, then balance your flywheel and your damper independantly. An LT1 is a zero balance machine... |
Posted on: 2009/7/14 20:25
aka Scaryfast |
Be absolutely sure you mean this. Mine is LOUD, even with a big motor, no cats, and bullet mufflers. It sounds like a pile of rocks in a dryer. Quote:
You should have a rollcage if it's a track car, anyway. What about seats and harnesses? Do the right thing if you run that often and retire her from street duty. If you saw the C4 wreck that I saw last weekend you would agree...car rolled over 5 times. But with the right safety equpment and cage the driver walked away. |
Posted on: 2009/7/14 20:31
aka Scaryfast |
Yes I know I'm on borrowed time without a cage, truck and trailer aren't in the budget yet. Not doing door-to-door racing. Think of it as HPDE 4, running about 8/10.
If I didn't have to rebuild the engine the cage would deffinately be on the winter parts list. Thanks for the input on the parts, that should help. When I pull the heads I'll clean them up and inspect them. Valve job and LT4 springs were done before I put them on last fall. Have less than 2000 miles on them. I'll check with the machine shop and see what the charge is to balance the internals and add it to the list. Thanks again!!!! |
Posted on: 2009/7/14 22:24
Just do the best you can. Make sure you at least have good harnesses (and properly installed), good helmet, etc. We all like to live in denial, but this stuff can be dangerous. I've been upside down, on fire, and into a few walls and I'm still here because of the right safety stuff. Quote: Thanks for the input on the parts, that should help. So your heads should be fine. Check this parts list for an idea of what other stuff will cost. This is the shop that did my heads and balanced my motor. http://www.champion-performance.com/ click the "services" link, it's a full spreadsheet with pricing. A balance job is $200. What did you decide on the clutch? |
Posted on: 2009/7/15 14:36
aka Scaryfast |
bogus | Re: Replacing things on my 92 | ||
Check RAM clutches. They have a C4 conversion that uses a hydraulic throw-out bearing.
Looks real interesting. |
Posted on: 2009/7/15 14:42
I am still looking for someone local to get a quote for a cage, or atleast a roll bar that can be expanded to a cage. So far everyone only wants to work on C5's. Shoot I can't even get a quote to weld in an autopower or similar roll bar. I'm avoiding just adding a harness bar, but may do it for the last few track days this year. Helmet is 9 years old SA2000, Don't know if I should pick a 2005 off clearance this December or wait for the 2010's. Its been a good open face helmet, but its time for a closed face. Ahh - the clutch. I'm going to go with the stage 2 and aluminum flywheel. Seems like a tried and true solution, just hope at 2500 rpm on a 10 hour trip it doesn't drive me crazy. The aluminum flywheel should help me pull out of oak tree (VIR) or Turn 7 (Road Atl) and get up to speed quicker with the lower rotating mass. Turns out my machine shop has a similar list of services so they should be able to balance everything. |
Posted on: 2009/7/15 20:08
BillH | Re: Replacing things on my 92 | ||
Properly installed weither it's with a harnessbar or rollbar means: get rid of the stock seat and install one that allows the shoulderbelts to come thru the seat at the proper width. |
Posted on: 2009/7/15 22:07
I sent you a PM about the roll bar.
I'm orginally from around the Atlanta area and know several chassis people who can help you if you can't find anyone. Will |
Posted on: 2009/7/17 22:13
Thanks for the info on the roll bar. I'll need it cause I've found a built 383 shortblock for a reasonable amount.
The wreck gave me pause and the found 383 make it a requirement. Damn this track addiction is expensive! |
Posted on: 2009/7/21 20:09
