183 user(s) are online (111 user(s) are browsing Forums)
QuitHaten Tire Sizes on a C4
Nashville, Tn
16 Posts
I have a 1996 Collector Edition with the LT4 and the tires I have on the rear are 315/35/17, I want to go to a 335/35/17. Does anybody know if the 335/35/17 will fit or does anything need to modified? Thanks for your help.
Posted on: 2009/7/12 11:09
Matatk Re: Tire Sizes on a C4
22806 Posts
Some guys have experienced rubbing issues with the wider 335s, especially if your car is lowered. It depends partly on the brand, because some run wider than others even though the "number" is the same. I think 315s are wide, already! Also, the 335s might bulge out a little bit on an 11" rim.
Brian on here runs 335s on all 4 corners for autocross, I believe, but he has aftermarket rims. I'm not sure the offset, but he should chime in.
Good luck,
Posted on: 2009/7/12 11:50
88BlackZ51 Re: Tire Sizes on a C4
481 Posts
If your staying with the 11 inch rim, the 335's really don't make much sense to me. You "might" see some buldge.
Posted on: 2009/7/12 13:23
bogus Re: Tire Sizes on a C4
Those are already "non-stock" compared to the CE. If you had a GS, they would be stock, and those came with the cute little fender flares... what good they did.
I am afraid that you would have a rather dorky looking bulge... Also, selection... The tire will have a bit more height, too. Lemme see... If I did the math right, the 335 would be 1/2" taller. That could skew speedo readings and piss off the ABS/ASR computer a little...
Finally... selection... I just checked tirerack.com (shameless guru sponsor plug!) and they only have three tires in that size...
Kumho Ecsta XS $204.00 each
Michelin Pilot Sport PS2 $443.00 each
Pirelli PZero System $499.00 each
If you stick with the 315s, they are a lot cheaper.
The Kumhos are $201.00
Goodyear F1 $323.00
Sumitomo $115.00
Short of a potential appearance improvement, which I doubt, the 335s are simply pointless. I don't see a performance improvement worth the cost.
Posted on: 2009/7/12 16:43
QuitHaten Re: Tire Sizes on a C4
Nashville, Tn
16 Posts
Thanks everybody for the info. I think I will just stick with the 315/35/17. Brian.
Posted on: 2009/7/13 9:03
BrianCunningham Re: Tire Sizes on a C4
I run 335's, but my rims are 12in wide.
They do stick out a little.
What rims are on the car GrandSports?
CE's didn't come with 11in rims.
Posted on: 2009/7/13 13:30
11.5" on the GS
Posted on: 2009/7/13 22:44
1Fast04Vert Re: Tire Sizes on a C4
11.5" on the GS
11"
Posted on: 2009/7/14 2:05
22806 Posts
11.5" on the GS
I believe they are 17x11, Andy.
Posted on: 2009/7/14 2:06
hm... wasn't the ZR1 then 11.5? I thought one was 11.5... oh, well...
Posted on: 2009/7/14 4:33
vis_croceus Re: Tire Sizes on a C4
VA
260 Posts
trivial to correct.
nope.
Posted on: 2009/7/14 18:53
94 vert
VA
260 Posts
On a related subject...
Anybody know if a 28" tire will fit in back?
94 vert
Nashville, Tn
16 Posts
I put the black 17 x 9.5 on the front and 17 x 11 on the rear. I didnt like factory wheels that were on the car.
I went with the black wheels that the Grand Sport has because of the car having the LT4 in it I had the car repainted silver and added black Grand Sport stripes.
Posted on: 2009/7/22 6:54
What width?
15in drag wheels?
Posted on: 2009/7/22 13:03
tequilaboy Re: Tire Sizes on a C4
19 Posts
Mick's car looks pretty good with 28" M&H 325/45R17s, so it would appear that 28" tires will work/fit.
How about a 29" tire? I've been considering some 275/55R17s lately, but will likely go to a 27" tall 255/50R17 instead, next time I need tires.
For a 17x11 wheel there aren't too many choices. Check out the M/T 295/45R17 ET Street Radial II if you're looking for a Drag Radial, or the aforementioned M&H.
It would be nice if there were a few street tires in these approximate sizes. 17x11 wheels have limited choices for tires.
Posted on: 2009/7/22 17:20
All the way around?
Be interesting to see what that looked like.
May look like a 4x4, but it would make driving over potholes a lot easier
LOL
Posted on: 2009/7/22 17:27
19 Posts
I would intend to run the same size tire all around.
I measured a 255/60R17 General Grabber UHP mounted on a Toureg. From the specs, this is also supposed to be 29" tire like the 275/55R17. Actual height was about 28 1/4" tall, so I suspect that the 275/55R17 is closer to 28" than 29" FWIW.
I would also consider a 255/50R17 front and 275/55R17 rear combination.
With my 3.73 gears, the 255/50R17 will behave like a 3.55 gear, the 275/55R17 or 255/60R17 would behave like a 3.37 gear, compared with my present 255/45R17 tires.
I wouldn't mind the shorter effective gearing. Its good to see that there are some "different" options available.
Posted on: 2009/7/23 16:41
Nashville, Tn
16 Posts
If you want to see a picture of the car, Go to cardomain.com
and search for QuitHaten. You can see it there.
Posted on: 2009/7/27 9:17
mseven Re: Tire Sizes on a C4
Motor City Madhouse
247 Posts
vis_croceus wrote:
On a related subject...Anybody know if a 28" tire will fit in back?
They fit and the well can take at least a 29", if removing the plastic "tubs' a 30" looks possible.
Posted on: 2009/7/28 14:04
VA
260 Posts
Thanks!
Posted on: 2009/7/31 0:22
94 vert
