138 user(s) are online (83 user(s) are browsing Forums)
iCorvette How true is it when they say at WOT the Corvette goes into Open Loop?
302 Posts
At what voltage? is there a load criteria?
or does it just stays in closed loop....
Posted on: 2009/8/8 5:55
vetteoz Re: How true is it when they say at WOT the Corvette goes into Open Loop?
It goes into Power Enrichment(PE ) mode which is not OL
Read
http://www.thirdgen.org/techboard/diy ... -p730-target-afr-how.html
Posted on: 2009/8/8 8:30
TommyT-Bone Re: How true is it when they say at WOT the Corvette goes into Open Loop?
33780 Posts
That certainaly clears things up a bit.
Posted on: 2009/8/8 12:34
The short version;
at WOT the ECM engages PE mode; where it calculates fuel from a set "chart " for want of a better word ,instead of using the O2 sensors as in normal closed loop operation.It does not drop back to open loop as in cold startup.
Quote from above link
"In PE Mode the Base Pulse Width ( amount of fuel ) is calculated from a theoretical Air/Fuel Ratio (AFR). This AFR is independent from the O2 sensor. It is simply a theoretical target value that the ECM is going to make an attempt to achieve without any feedback ( from the O2).
Posted on: 2009/8/8 12:48
iCorvette Re: How true is it when they say at WOT the Corvette goes into Open Loop?
302 Posts
Read
Thanks....
Posted on: 2009/8/8 16:26
383tpimachine Re: How true is it when they say at WOT the Corvette goes into Open Loop?
Corpus Christi
976 Posts
OK so since my tune is ALL out of wack Im losing alot of power when going WOT?
this is probably why it bogs so bad at WOT
Posted on: 2009/8/8 20:25
1970 El Camino-Awaiting LSX
302 Posts
supposedly it goes to power enrichment not open loop, learn something new everyday
Posted on: 2009/8/8 21:33
bogus Re: How true is it when they say at WOT the Corvette goes into Open Loop?
for sure.
especially if the PE tables are set for stock.
Posted on: 2009/8/8 22:22
mseven Re: How true is it when they say at WOT the Corvette goes into Open Loop?
Motor City Madhouse
247 Posts
383tpimachine wrote:OK so since my tune is ALL out of wack Im losing alot of power when going WOT?
There are several inputs/look up tables that play a role in calculating PE, and or the performance in WOT. While timing is a factor ("bogging" description}, the calculated PE AFR also includes the last BLM used/seen (along with other tables) to formulate AFR at WOT. If entering PE lean, the overal PE/WOT AFR will be affected (likewise if entering PE rich). Depending on when you enter PE (RPM vs load), this can change the afr when entering PE. This is why developing the closed loop area of the tune should be done first before tuning for WOT.
Posted on: 2009/8/9 16:19
302 Posts
wonderful insight.... would it not that the maximum airflow vs. rpm must be adjusted for an engine with greater ability to move air. and I should max it out to a 255 default providing it with a greater range sensitivity.
And conversely with stock ceilings per rpm assigned, this can fool the maf into thinking X amount of air is moved vs. the correct albeit more volume of air is actually moved, henceforth creating a lean condition,
and when the throttle depending on where I trigger PE can result in the concomitant lean condition as you metioned above.
is this correct?
Posted on: 2009/8/9 18:55
Motor City Madhouse
247 Posts
wonderful insight.... would it not that the maximum airflow vs. rpm must be adjusted for an engine with greater ability to move air. and I should max it out to a 255 default providing it with a greater range sensitivity. And conversely with stock ceilings per rpm assigned, this can fool the maf into thinking X amount of air is moved vs. the correct albeit more volume of air is actually moved, henceforth creating a lean condition,
I have used this table primarily for c.l. tuning below 4000. Raisng the air flow in any particular RPM in this table will have the effect of richening. Typically I look at everything above 4000-4500 being pe., therfor from 4k and up I set to 255. For PE if I can't add enough(or subtract)using the 'PE vs RPM' table, I will use add on tables such as : 'PE vs.temp' add-on (which when adding fuel percentage will also reduce inj.dc) and also 'ae factor vs change in load', as part of a base tune.
TPS postion, is a part of it but I look at were it actually entered (specific rpm vs.load), and go from there. First I tune C.L. with pe disengaged which allows me to tune higher rpm and deeper into the load range. Once I have the blm/afr locked (not moving and very little int. change)across the board I begin tuning PE (using a afr meter). This has given me pretty consistant results entering pe at various rpm, load ranges. I have found there to be no problem attaining a good cl tune as well as a solid wot tune in typical 383 and 350 set-ups. I believe the need for additional AF grams above 255 would become needed if using a FI/blown set-up or possibly a high rpm real fire breather.
Pat (tequilla boy) has been using a ford maf which I believe provides 300+ grams.
Posted on: 2009/8/9 21:54
anesthes Re: How true is it when they say at WOT the Corvette goes into Open Loop?
Boston, MA
Pat really went to town changing code, as well as the airflow calc. The stock code reads up to 1792 counts, and translates that to up to 255 grams. (which happens to be the limit to an 8 bit signed integer).
Pat changed the way the code worked in a manor that I believe still reads from 0-255, but is no longer relational to grams. He also reworked it to read the ford MAF, to translate whatever crazy voltage it is into counts.
So in Pat's setup (I believe, it's been a while since I discussed this with him) 100 grams on the tale might really be 150, and 255 might be 382.
I believe he's also reading IAT from the ford sensor as well.
Pat is a smart cookie.
A lot of guys on thirdgen.org are switching to vortec/ls1 ECM's because the ability to read higher airflow with those MAFs. On a conbination with a crazy camshaft (something with like 80 degrees of overlap) that could work a lot better than MAP. Big cams pass almost no air at idle, which makes MAP calibrations a pain in the ass because of lack of manifold vac looks similar to WOT on the table.
Plus it makes AE transitions a nightmare.
-- Joe
Posted on: 2009/8/10 2:37
vetted Re: How true is it when they say at WOT the Corvette goes into Open Loop?
10 Posts
First came the IOTA then RSGB had their VHF shindig then this weekend it was the MDC QSO party...dam can't anyone spell out these big long words?
WOT...Wide Open Throttle? I'm guessing. But the more I read these posts the more ignorant I feel cause I know not waht you speak of, I just own and occasionally get to drive a car that matches the dream of my youth.
Is there a translation guide somewhere?
More lost now than I was in the 60s.
Posted on: 2009/8/10 6:44
BrianCunningham Re: How true is it when they say at WOT the Corvette goes into Open Loop?
Who did your tune?
That's one area where it pays to find someone that can do it for you.
Posted on: 2009/8/10 13:26
Boston, MA
BrianCunningham wrote:
Who did your tune?
Isn't that the truth. Any monkey can bolt parts on, but tuning a car takes talent.
-- Joe
Posted on: 2009/8/10 13:56
tequilaboy Re: How true is it when they say at WOT the Corvette goes into Open Loop?
19 Posts
With the HPX sensor, I'm simply doubling the range to 510 gm/sec now. With my own car, I'm seeing airflow peaks around 430-440 gm/sec and targetting 11.8 AFR in PE.
An example Vortech Si-trim with a 3" pulley on an otherwise stock L98 is flowing around 370 gm/sec at 5,400 rpm with the same sensor with a 260F discharge temperature.
Here's a pic:
[IMG]http://i15.photobucket.com/albums/a372/tequilaboy/07-18-09_1804.jpg[/IMG]
Posted on: 2009/8/10 15:58
302 Posts
Here's a pic:
Posted on: 2009/8/11 1:24
