313 user(s) are online (246 user(s) are browsing Forums)
Ultraman, more...
biggrizzly Cam Specs for 383 build
I just got my new cam specs from Jerry! Damn that's way more duration and lift than the old cam for sure. How does this compare to some of you other 383 owners out there? I's just curious to see what Jerry has up his sleeve for me.
New 383 Cam Specs
Adv. Duration @ .006 = 276/280
Adv. Duration @ .005 = 224/230
Lobe Separation = 113
Lift with 1.6 Rocker = 566 Intake, 577 Exhaust
Posted on: 2011/2/15 19:19
vetteoz Re: Cam Specs for 383 build
The XFI 280 seems to be a popular 383 cam
230/236 .576/.570 (w/1.6 ) 113
Mine runs fine with a dated GMPP 847 cam
234/242 .540/.560 112
Posted on: 2011/2/15 21:54
Matatk Re: Cam Specs for 383 build
CS XR282HR-10 08-432-8
.510/.520
230/236
110
Posted on: 2011/2/16 2:17
biggrizzly Re: Cam Specs for 383 build
Thanks guys it's interesting to see the different specs that different people use for different applications... I know little about cams and have been trying to learn over the past few years how duration, lift and LSA all effect each other.
Matt - have you put your on a chassis dyno yet?
Posted on: 2011/2/16 2:32
Josh Re: Cam Specs for 383 build
I'm using the XFI 280 cam in my 383. No problems, runs great with my Mseven tune.
Posted on: 2011/2/16 4:14
No. I'm hoping once I get the injectors rebuilt and the tune finalized I will get a chance.
Posted on: 2011/2/16 12:33
I just sent my injectors off to Jon yesterday. I got a few weeks before I'll need them, but I wanted to have them ready when needed.
Posted on: 2011/2/16 13:20
pr0zac Re: Cam Specs for 383 build
i would go with something with more lift then the cam you are talking about.. i had the xfi cam that josh has in my lt4 and it did a 8.19@90 with a 1.96 60ft in the 1/8th with shorties,4.10's and a mail order tune. i think that cam would be better with a different lsa. my current 385 has a bit larger 245/253 with .612/.612 on a 107 lsa but i dont think you'll want something that large of a duration.
Posted on: 2011/2/17 15:55
It's a done deal now. I was just trying to see what other people are using. My engine builder feels very confident about our selection based on what the final goals are for the car. We have been through those questions, matter of fact we talked about the cam again today, and I'm good with it.
Posted on: 2011/2/17 21:11
flyboy Re: Cam Specs for 383 build
No expert, but I like the numbers. Should be easy to tune.
Posted on: 2011/2/17 21:21
Ya, if I could go back I would probably go bigger. The only reason I have the 280 is because I ran it in the stock motor with TFS heads and the LT1 intake. When I did the 383 build, I couldn't afford another cam so I stuck with the 280. Don't get me wrong, I like it, and the car runs great, but I think you could go quite a bit bigger and not sacrifice much.
How does your car act? To me, it seems like that cam would be on the upper limit of what you could make reasonably streetable. That's just a guess though, I've never had a cam that large or tried to tune (or more accurately, have Mick tune) for something like that.
Posted on: 2011/2/18 7:27
SpectatorRacing Re: Cam Specs for 383 build
Can't remember my durations but my lift is 577/574 also with 1.6 RR.
I have 112* LSA with a little advance timing.
Purrs like a kitten. Honestly, I wish it had a little more cam lope for a racing application Doesn't sound mean enough and drivability is not a concern. It is very drivable, BTW.
Posted on: 2011/2/18 20:11
PeteK Re: Cam Specs for 383 build
Great cam choice Don. It is exactly what I would have recommended for your build.
Sure, more cam would make more power, but you will be pleased with the entire combination.
PS: Your trans is complete.
I sent you a few pics.
Posted on: 2011/2/19 2:33
I'm glad you didn't paint it pink! It looks nice all shiny and new. I won't know how to act with a transmission that actually shifts and feels like its not slipping and sliding. My Corvette buddies were calling it the "slush box". Not no more!
Posted on: 2011/2/19 13:18
i got to drive it with the tune for my old setup and injectors and it wasn't that bad at all but i think the maf was picking up the pace for the tune. it would be wayyy better off in a stalled auto cause for now it seems surge quite a bit on the bottom when going under 10mph but the power instantly poors in and its almost too aggressive. the reason its so big is to bleed of the compression ratio for pump gas. but even when its not running right it still pulls like a freight train. it is probably more then you would want to go if you actually needed to drive the car.
Posted on: 2011/2/19 13:47
As broken up as it was, I can't believe it moved at all.
I saved the cracked and broken parts for your wall of shame.
Posted on: 2011/2/19 13:50
Stl94LT1 Re: Cam Specs for 383 build
128 Posts
That cam should run real smooth and be easy to tune in your 383.
I'm running a 224/230(.050),605/622(1.6),112+2 LSA in my 350 and it is pretty mild sounding with no bucking even at low rpms.
Posted on: 2011/2/20 0:04
