121 user(s) are online (86 user(s) are browsing Forums)
Dads90 Replaced the Instrument Cluster
Pearland, Tx
318 Posts
Well, got a replacement cluster from a local guy. It was a little time consuming on the tear down and replacement but after all the effort it works great. No more variable brightness problems and fading speedo numbers. I think the hardest part was bolting the steering wheel back up. Luckily a neighbor stopped by and he held it up while I reached under with the bolts. :thumbright: :thumbleft: :thumbright: :thumbleft:
Posted on: 2008/3/5 4:42
bogus Re: Replaced the Instrument Cluster
coolio! I have half my interior apart still... need to find time to fix that...
Posted on: 2008/3/5 5:30
RRTvette Re: Replaced the Instrument Cluster
Bogalusa, LA
50 Posts
I swapped the one in my 92 in about 30 minutes. Fairly easy project. Glad to hear everything is working normally.
Posted on: 2008/3/7 3:14
CentralCoaster Re: Replaced the Instrument Cluster
Congrats, but next time, don't remove the steering wheel, it's not necessary.
Posted on: 2008/3/7 9:05
Matatk Re: Replaced the Instrument Cluster
Hopefully there won't be a next time, right?
Posted on: 2008/3/8 1:15
TommyT-Bone Re: Replaced the Instrument Cluster
33770 Posts
On the 90 you have to drop the steering column. Two bolts from the underside of the column holding up a metal plate.I've disassembled it several times and it gets easier and faster every time. I held the column up with my left shoulder and neck while I started the bolts with my right hand. I'm sure there are other creative ways to hold everything up while you start the bolts but that worked for me. My tach was whacked for years and my center display bulbs finally went dark causing me to run out of gas on the highway once.(doh) Knowing your speed and other operational info can be very beneficial. I got a rebuild and testing that cost me $325 for the cluster. The local Vette shop quoted me around $1100 for the job. I love when I save money. I understand you can get it done for less than $325 if you shop around.
Posted on: 2008/3/8 1:41
Dads90 Re: Replaced the Instrument Cluster
Pearland, Tx
318 Posts
I found a place in Indiana that would repair it for 185.00 I wound up finding it local.
Posted on: 2008/3/10 2:19
LD85 Re: Replaced the Instrument Cluster
Indianapolis, Indiana
784 Posts
Congrats,,
BTW, The guy in Southern Indiana did mine 3-4 years ago and it has worked great ever since!
Posted on: 2008/3/10 22:43
2005/Z51
jhammons01 Re: Replaced the Instrument Cluster
Tommy, are you sure about that?
I did mine a few months ago and the steering column remained. Only the Tilt was unscrewed after tilting the wheel all the way down.
Posted on: 2008/3/11 2:32
My bad, I forgot the interior changed in 90.
Posted on: 2008/3/11 18:42
