298 user(s) are online (254 user(s) are browsing Forums)
pr0zac hey check out this budget motor.
Posted on: 2008/11/29 15:17
pr0zac Re: hey check out this budget motor.
Posted on: 2008/11/29 15:19
Posted on: 2008/11/29 15:21
88BlackZ51 Re: hey check out this budget motor.
481 Posts
Was your thread deleted?
Posted on: 2008/11/29 18:03
PeteK Re: hey check out this budget motor.
Click the words, and they take you to the linked site.
Posted on: 2008/11/29 18:05
BrianCunningham Re: hey check out this budget motor.
440chp on a stock bottom end is pretty
Not a bad showing for the iron head vortecs either.
I've heard the stock iron head LT1's outflow their AL counterparts.
Posted on: 2008/11/29 19:24
BeachBum Re: hey check out this budget motor.
751 Posts
Ahhh... thats better.
I like em all.... my favorite is the $ 2000 385 HP motor.... maybe swap the intake or something and find yourself another 15hp for a 400 HP motor for $ 2200 or so..... not a bad deal for a street cruiser of some sort.
Posted on: 2008/11/30 0:19
brut Re: hey check out this budget motor.
New Albany, IN
1308 Posts
I am doing a iron Vortec build for my '76. I was thinking of going to a 383....but that 355 sounds enticing with 400+ HP.
Posted on: 2008/11/30 0:45
'71 Nevada Silver Coupe
'07 Hummer H3
cuisinartvette Re: hey check out this budget motor.
pr0zac wrote:
or this
Sounds identical to Bluewasps LT4 on CF, used LE heads, same cam and 11:1 447 rwhp?
Posted on: 2008/11/30 1:26
Schrade Re: hey check out this budget motor.
HEADS
There were two heads used on the 350, one aluminum and one cast iron, along with one cast iron head for the 265. GM claimed that the original LT1 aluminum head had a 15% increase in airflow as a result of revised port angles and higher port ceilings when compared to the 1991 L98 head. That was impressive in 1992, but the iron LT1 head that came out in 1994 was even better. It flowed 20% more on the intake side and made more horsepower on the dyno.
From here:
http://www.9c1.com/technical/LT1_rebuild/ar99928.htm
If accurate, that means head flow was nearer to LT4.
Posted on: 2008/11/30 6:26
Posted on: 2008/11/30 7:43
