PeteK | Some old video's | ||
From the good old days. Mid 90's approx. 1st 11 second run.
And another clip. That car always seems to hook well. |
Posted on: 2009/1/11 14:01
1Fast04Vert | Re: Some old video's | ||
Nice, makes me wish I could take it to the track today. Come on spring time.
Posted on: 2009/1/11 14:45
PeteK | Re: Some old video's | ||
Up here, spring is a long way off. Racetrack will not likely open before the end of April. |
Posted on: 2009/1/11 14:59
TommyT-Bone | Re: Some old video's | ||
Were you running a line lock Pete? Just wondering, with Vettes, do most just toast there rear pads and smoke em'?
Posted on: 2009/1/11 15:02
No line lock. The rear pads are about 10 years old, and the burnouts don't seem to hurt them at all. |
Posted on: 2009/1/11 15:03
BrianCunningham | Re: Some old video's | ||
Cool
Do you have them on tape? You can wire the VCR directly into the digital one. That would eliminate the video of a video. |
Posted on: 2009/1/11 15:36
Thanks, I will mention that to my buddy. He owns them. That makes it easier for sure. |
Posted on: 2009/1/11 15:41
pianoguy | Re: Some old video's | ||
Excellent - helluva jump on that second vid!!
Posted on: 2009/1/11 15:51
xccter | Re: Some old video's | ||
Pretty Cool stuff there.
Posted on: 2009/1/11 17:24
´71 350/270 L48 Coupe Numbers Matching Ontario Orange 4 spd, Mid-year side pipes, deluxe black leather, ac, ps, pb, pw, tilt/tele steering wheel. 93k miles. Original rotors still riveted to the hubs! NCRS #48337 |
BeachBum | Re: Some old video's | ||
Cool Beans
Posted on: 2009/1/11 17:35
I think I was still running recap tires back then. In the early days of drag radials, the BFG's had to be bought direct from BFG, and were almost always back ordered. I ran a yokahama autocross tire, but the outer 3rd was smooth, therefore always caught the tech inspector eye, and I usually was accused of running a worn out tire. The solution was to run a performance recap from a place in Tennessee. Laugh if you will, but they hooked like glue, and never needed much weight to balance. Good in the rain, and got approx 5-7k out of a set. Best 60' on one was 1.550. I won my 2 track championships on recaps. Like I said, the good old days
Posted on: 2009/1/11 17:42
