201 user(s) are online (166 user(s) are browsing Forums)
Also known as SMC.
The only issu...
Dads90 Hurst shifter in, Yehh
Pearland, Tx
318 Posts
Told the wife the car was shifting bad, hanging up, wearing out, I neeeded a new one and the GM was 500 bucks,, she fell for it. "Honey, I can get a better shifter for a whole lost less online". Well she got suppicious when the Hurst showed up the very next day. Damn that was fast shipping. Jacked it up, dropped the exhaust and grabbed every size hammer and punch I had. The first punch I grabbed I just put it on the pin to check its size and the dang pin went flying out. ALRIGHT !!! I've read all the horror stories. Boy was I happy, so happy I replaced the slave cylinder too while the exhaust was out. I like the Hurst, it taking a little to get used to. No reverse lockout, the throw is sweet, a little notchy on shifts, very happy though.
Posted on: 2009/2/19 4:52
pianoguy Re: Hurst shifter in, Yehh
Congrats! Glad to hear you fared well with the pin, too - luck of the draw, it seems ;-)
Posted on: 2009/2/19 11:32
BrianCunningham Re: Hurst shifter in, Yehh
One of the best things I've done to my car
Posted on: 2009/2/19 13:26
CentralCoaster Re: Hurst shifter in, Yehh
You can still buy the Hurst? Where did you get it from. I thought after B&M absorbed them, they discontinued the Hurst model.
Mine fit fine other than having to knock down the edges on the sides of the shifter body, because it would rub against the aluminum shifter cradle as you moved it fore/aft. It's smooth as silk now.
Posted on: 2009/2/19 17:16
Dads90 Re: Hurst shifter in, Yehh
Pearland, Tx
318 Posts
I got it on ebay,, 157.00 including fgt. It didn't come in the official box, but who cares.
Posted on: 2009/2/20 4:18
Pearland, Tx
318 Posts
Posted on: 2009/2/20 4:24
88BlackZ51 Re: Hurst shifter in, Yehh
481 Posts
Let's see a pic.
Posted on: 2009/2/20 10:56
Pearland, Tx
318 Posts
I tried to upload a photo. Lets see
jpg  100_0413.JPG (886.74 KB)
1057_499f6476bf41d.jpg 2200X1650 px
Posted on: 2009/2/21 2:20
Matatk Re: Hurst shifter in, Yehh
I dunno, Dean, those don't look like certified NCRS floormats to me. That's not good
Shifter install looks great. Still getting used to it? Good improvement? I've never driven a stick vette so I have nothing to compare it to
Posted on: 2009/2/21 12:51
TommyT-Bone Re: Hurst shifter in, Yehh
33772 Posts
What's that in front of the shifter on the bottom left under the radio? XM, Sirius, MP3 player?
Posted on: 2009/2/21 13:35
Flux capacitor ;-)
Posted on: 2009/2/21 16:53
Pioneer CD changer control.
Posted on: 2009/2/21 22:13
Pearland, Tx
318 Posts
You are correct, sir !! I've read alot about how Bose system sucks, but with the changer its sounds good. I know there is better out there, but this way I can keep close to stock.
Posted on: 2009/2/22 3:58
Pearland, Tx
318 Posts
Actually they are just area rugs I cut to fit. They cover the original and keep them clean. When I drive it to work, I don't worry about getting oil or grease on the matts.
Posted on: 2009/2/22 4:05
bogus Re: Hurst shifter in, Yehh
any bets that Dad bought his Hurst from the guy who designed it?
The guy who designed it was named Chris (Reinhardt? does that sound right?) and had a ZR1. Just a stab with a UID of zrchris.
I have the Hurst... AND LOVE IT! It's been in there for 7 years now.
Posted on: 2009/2/22 7:33
Pearland, Tx
318 Posts
It makes driving it fun again. Does anybody experience a click between 3 and 4 ? From 2nd to 3rd I have to allow it to center for a fraction of a second and then hit 3rd. Any tips.. I'm looking at another slave bleed to try and force more air out, maybe that will make it smoother.
Posted on: 2009/2/23 1:08
For hitting 3rd, and especially 5th, you need to just shove the shifter up at an angle.
If you try maneuvering it over and up, you're more likely to miss a shift.
Just use the palm of your hand, no fingers.
The gates on the ZF are actually further apart than most 6 speeds I've driven.
Posted on: 2009/2/23 4:10
Pearland, Tx
318 Posts
Thanks CC, I will work on it. It's funny how one shift it falls right into place, and the next time I have to double clutch it. I really have to concentrate, the ZF has 40,000 miles on it, but hell, I have always had slave issues.
Posted on: 2009/2/24 3:05
THX138 Re: Hurst shifter in, Yehh
11 Posts
This is something Ive been wanting to do but fighting with the pin puts me off.Ill buy the shifter and just set it aside for now,Ive already got the Hurst white ball.
Posted on: 2009/3/12 5:59
I do suggest doing the project with a clutch swap... it's SOOO much easier.
Posted on: 2009/3/12 6:20
The pin wasn't that tough on mine. I even did it with the exhaust on, which was tricky.
The hardest part was just taking apart and reassembling the shifter on the bench.
Posted on: 2009/3/12 7:02
Pearland, Tx
318 Posts
Whats funny I was so concerned about the pin, I pulled the exhaust. What a waste of time that was. But if I didn't (the way my luck goes) I would have been pounding and drilling the damn thing out.
Posted on: 2009/3/13 3:43
33772 Posts
That shifter knob is a little worn. Maybe it's time for a knob job.
Posted on: 2009/3/13 10:46
Pearland, Tx
318 Posts
You know I've consdered getting the black hurst ball, but I like the stock look. I'll take a sharpie and cover that worn spot, good as new :thumbright:
Posted on: 2009/3/14 2:48
Try some liquid shoe dye - I used some to touch up a little worn spot on my driver's seat bolster, worked great. I also have used it on my exterior door handles.
Posted on: 2009/3/14 3:06
BillH Re: Hurst shifter in, Yehh
The problem with a Sharpie is that it has a purpleish hew when dried, it hardly ever matches black correctly.
And, I don't think thet shoe polish will work because it won't sitck well to plastic, does work well on vinyl,etc.
A little black model car paint or some black spray paint ( sprayed into the cap & put on with a small brush) will stick better.
Posted on: 2009/3/14 15:25
