316 user(s) are online (282 user(s) are browsing Forums)
rklessdriver Update on the quest for 500RWHP
Well the little tinkering on my car came to a very, very bad end last week.
I swapped my 58mm TB out for an AS&M Mono Blade. I wanted to ge the car on a dyno - just to check the tune out. BUT due to moron actions by the local dyno shop close to me last time (I did a check out on my car) I was looking for a new guy... I was unable to get up with another local dyno and Ed being over 3hrs away in Suffolk I decided to take the car out for a little test drive as is...
Like I said, I really wanted to see how the car drove with the new TB so I took it out last Sunday early in the morning. While I was out playing around on an otherwise deserted hwy making easy 2nd gear pulls, I ended up getting in a race with the only car other car out that morning a modified STI (which the owner/driver said had over 450WHP). He said he heard me (and my car is pretty loud) out on the Parkway and decided to come see what I was driving... anyway I played around just putting a few cars on him in 1st and second gear from a roll. He seemed to think he'd do better the longer we ran so.... I ran it pretty hard one time just to let im know I really was playing around with him. 8+ cars by the top of 2nd gear (85mph) should have gotten the message across but I chose to run slam out of site on him in 3rd and 4th just be sure.... with the "message delived" and me feeling pretty good about how the car ran I decided to head home before I got my self in any legal trouble.
When I got back home with the car, it was blowing oil out the breather and dip stick. Massive positive crank case pressure. A partial compression test has 2 cyls down to under 100lbs... the plugs from those cyls are covered in alum as well... Looks like I have a few burned pistons to show for being stupid and not checking the tune after changing the TB.
My day job with the Govt has me working out of state the last week and this week. I've not had time to do anything more than think about how much money this is going to cost me...
After talking with dad and my brother, It looks like next month around spring break I'll be able to get the car down to my dads shop in GA and we'll go from there depending on how bad the block is screwed up. Hopefully this is a deal where it just torched the ring land and didn't do any damage to the bore. Of course I won't know for sure until we pull it apart.
If the bore isn't screwed I'm going to take the oportunity to bump the SCR from 10.6 to 11.6 as I can do that easily by moving from my current Wiesco's (20cc dish) to a Manley piston built for the CASCAR spec series (12cc dish). I'm going to leave the current hyd roller camshaft in it. This is obviously an exellant oportunity to fully port the intake manifold which I've been meaning to get around to but never have...
If the bore is screwed... I'm either going to have to spring for some custom pistons or find another block. I'd have to get with BRC (our normal custom piston supplier) for a price on pistons and see if it's more feasible than machining a different block to fit the Manley pistons.
Before anyone says it.
I KNOW I SHOULD NOT RACE ON THE STREET.
This is fitting however. I KNEW I should have checked the AF ratio on a dyno before making any real hard pulls with the car but I went against my better judgement and drove the car anyway...
So there you have it kids.
Don't race on the street. Don't drive your car around untuned and then decide to race it untuned. Don't let the fact that following both of these rules would have prevented me from destroying some clown with a Subaru dissuade you. Really it's just not worth it... Or maybe it is. I'll let you know when we have it apart and disect the damage.
Posted on: 2009/2/23 20:11
88BlackZ51 Re: Update on the quest for 500RWHP
481 Posts
Sorry 2 hear about this. That sucks!! Will what was your combo again?
Posted on: 2009/2/23 20:56
rklessdriver Re: Update on the quest for 500RWHP
382 cubic inches
10.6 SCR (8.2 DCR)
43lb pendlum undercut 4340 crank (3.75 stroke)
545gr Scat Q lite 4340 H beam Rods (6.0")
398gr 2618 Weisco pistons (4.030)w/99gr tool steel pins
AFR 210 Elims CNC comp port
T&D Shaft Mount rocker system (1.7/1.7)
Morel lifters
Hydra Rev
Converted Victor 2925
58TB w/36lb injectors
The cam is a custom grind from Mike Jones (Jones Cam Designs).
288/292@.006
242/246@.050
.620/.620 (1/7/1.7)
106IC/110LS.
Posted on: 2009/2/23 21:12
BrianCunningham Re: Update on the quest for 500RWHP
ouch
hopefully it's something simple like a head gasket
Posted on: 2009/2/23 22:04
Stl94LT1 Re: Update on the quest for 500RWHP
128 Posts
Sorry to hear of more bad news. The quest for 500rwhp has been a rocky road.
Posted on: 2009/2/23 22:23
MK 82 Re: Update on the quest for 500RWHP
Palm Beach Gardens, FL
439 Posts
Hard to believe that a TB change would cause all of that.
Eddie
Posted on: 2009/2/23 23:41
96 CE Roadster LT4
481 Posts
Will. Combo looks stout. One thing I was wondering about is the injector size. I am no expert but 36's seem small for 500 plus rwhp?
Posted on: 2009/2/24 0:18
AKS_Racing Re: Update on the quest for 500RWHP
62 Posts
I told you that MB can be hazardous to the health of your car...
I wish you the best in getting it back together.
Aaron
Posted on: 2009/2/24 2:13
tpi421vett Re: Update on the quest for 500RWHP
Salt Lake City Utah
125 Posts
500rwhp on a 23 degree sbc is a max effort deal.I feel fortunate to exceed those numbers with my 421 N/A. To keep it streetable with pump gas takes alot of effort. But I think with your skill and knowledge, you will get there.
Posted on: 2009/2/24 2:41
08 C6 LS3,3LT,Z51,A6,NPP
450ci now with AFR 235...
anesthes Re: Update on the quest for 500RWHP
Boston, MA
That is what blowers are for.
-- Joe
Posted on: 2009/2/24 17:54
Salt Lake City Utah
125 Posts
Your right Joe, power adders would make the 500rwhp goal much easier!
Posted on: 2009/2/24 19:31
Randyj75 Re: Update on the quest for 500RWHP
MD
129 Posts
That sucks Will, hope the damage is not to serious.
Posted on: 2009/2/27 16:01
1989GTA Re: Update on the quest for 500RWHP
61 Posts
Let's hope the damage is not bad at all. You have a well thought out combination and I like the heads and the camshaft. When I switch to the monoblade it did not affect the a/f ratio hardly at all.
Posted on: 2009/2/27 19:29
BeachBum Re: Update on the quest for 500RWHP
751 Posts
I feel for you on the carnage !! I know firsthand how that feels....
Good luck in your quest for 500rwhp.... I do not know if you can do it with a 383/hyd roller/23deg combination, but you're sure going to have fun trying.
Posted on: 2009/2/27 20:08
-- Joe
That's what I'm doing, and what Chevy did on the new ZR1
all that power and a 100k mile warranty!
Posted on: 2009/2/27 21:57
