232 user(s) are online (115 user(s) are browsing Forums)
The ...
iCorvette 700r4 vs.4l60e
302 Posts
can the 700r4 be made to shift with the same versatility of the "e" version
to avoid an external controller
specifically WOT shifts and part throttle normal driving, this would save me a ton of money if it can accomplish this, I'll compromise if someone will tell be the differences.
and is the e over rate as far as strength compared to the 700r4?
will the e be able to interface with my vss configuration (89 vette)
with a new sensor or is this impossible? thanks
Posted on: 2009/11/12 15:54
1Fast04Vert Re: 700r4 vs.4l60e
E being electronic and all shifts controlled by the PCM I don't think you can swap one into a 93 or earlier as they have ECMs, not PCMs.
Posted on: 2009/11/12 18:54
vetteoz Re: 700r4 vs.4l60e
95vette wrote: I don't think you can swap one into a 93 or earlier as they have ECMs, not PCMs.
Can be done with a expensive GM or aftermarket contoller
http://www.crateenginedepot.com/store ... ller-12497316-P722C0.aspx
A quote
"Because the transmission is electronically controlled by the PCM and its requisite wiring, it is usually simplest to join the 4L60-E to the engine it came with from the factory. Earlier engines can be joined to the 4L60-E by use of a GM Controller, #12497316. Individuals converting to earlier engines or engines not controlled by a GM PCM should consider the TH700R-4 as the simpler and cost-conscious alternative."
Posted on: 2009/11/12 22:18
1989GTA Re: 700r4 vs.4l60e
61 Posts
"can the 700r4 be made to shift with the same versatility of the "e" version"
IMHO no. I converted from a 700R4 to a 4L60E with the TCI controller and there is no comparison. I can program in what ever I want the 4L60E to do and it does it. With the TCI controller it has a switch that you can go between program A and B. Program A can be a "street version" and Program B can be a "race version". My A/B programs are set up the same except a little higher shifting rpms for the race version for when I go to the track. Did I tell you I love my 4L60E.
Posted on: 2009/11/13 4:15
Matatk Re: 700r4 vs.4l60e
What was the cost for the TCI setup with everything?
Posted on: 2009/11/13 13:07
dan0617 Re: 700r4 vs.4l60e
The 700R4 WOT shift points are controlled by the governor. It can be adjusted fairly easily and cheaply to get the WOT shifts right where you want them.
The part throttle shifts are a combination of the governor springs, the TV cable and other things. I have yet to figure out how to get the part throttle shift rpms up where I want them. Weaker governor springs will not let it shift at all. Adjusting the TV cable will make a small difference but can burn up the trans in a hurry. I've been told a TCI constant pressure valvebody will allow me to put the TV cable wherever I want it in order to raise part throttle shifts and will not burn up the trans, but I haven't tried one yet.
The shift firmness can be changed with a shift kit or smaller shift improver kit. Fairly cheap and easy to do and works great.
The "e" transmissions are completely computer controlled. I wish I had one. I think you can install an "e" trans in your car but you will need the trans wiring harness, possibly the entire engine wiring harness, and the pcm from a car that came with an "e" transmission. If your car is an '89 then you will need to find a pcm that used MAF and an "e" transmission. It can be done, search on www.thirdgen.org in the DIY prom section. I'm sure I've seen people talk about doing this.
Posted on: 2009/11/13 15:17
383tpimachine Re: 700r4 vs.4l60e
Corpus Christi
976 Posts
in GMHTP they features the ls1 pcm upgrade to gen1 and gen2 sbc
It has the option to get a connector for the 4l60e
I have decided to NOT waste money on my 700r4 and just wait until I get this and build a better transmission once
Posted on: 2009/11/13 16:26
1970 El Camino-Awaiting LSX
PeteK Re: 700r4 vs.4l60e
Remember gents that the internals of a 4l60 are identical to the 700r4/4l60. 95% of the parts interchange.
The 4l60e has an electronic valve body, and has eliminated the governor and tv valve, but 1 is not stronger than the other.
Posted on: 2009/11/13 20:04
Aardwolf Re: 700r4 vs.4l60e
Fremont, WI
209 Posts
My local trans guy was saying the E has an aluminum valve body and that lets the case twist more? Any truth to that?
Posted on: 2009/11/13 20:54
Not sure about that, but the steel valves wear the aluminum bores, and create driveability problems. A $200 remanufactured valve body is always a wise investment in an overhaul, but most opt out of spending the coin.
Posted on: 2009/11/13 21:19
61 Posts
I believe I got the controller for around $750 and I don't remember what I paid for the harness. I bought them at different times as funds became available. Maybe $900 total? Did I tell you I love my 4L60E?
Posted on: 2009/11/14 5:05
iCorvette Re: 700r4 vs.4l60e
302 Posts
with a manual i notice i have the luxury of shifting, at any rpm and different in any gear... wonderful.
wind second short 3rd what ever....skip 5th go to 6th
so in a automatic is there only two (2) possibilities?
1/ WOT set it a forget it, this could be a bit much as sometimes i want to just make a mustang go away without seeing a shift light go off, so you say once it set, it targets the preset rpm and that's it?
2/ is less that WOT still WOT to the tranny?
when is the stock trans suppose to shift at partial throttle?
what is partial? something less than WOT?
you see, i drive like anyone else does, a little of this and a little of that, how is an automatic suppose to know what gear you need? my power band in wide so being right is not crucial, but i am interested in gas mileage and noise level, who wants a high shift when you want a conversation?
is it a function of load or speed or rpm?
Posted on: 2009/11/14 5:50
61 Posts
"is it a function of load or speed or rpm?"
The 4L60E controller reads TPS position, speed and rpm. You set the parameters around those inputs. With light throttle I have it shifting for good economy. I also have the torque converter lock up set at 45mph. With say a 1/4 throttle it goes into "performance" mode. It will downshift and take right off. You can have it down shift at say 75% of maximum rpm.
There are tables for each gear. You can set them for what ever you want. Let's say you are cruising along at 50 mph in 4th gear and lock up and nail it. In my case it will unlock the torque converter down shift into 2nd gear and away you go. It will do whatever you have the tables set at. Did I tell you guys I love my 4L60E?
Posted on: 2009/11/14 22:39
302 Posts
I may have to compromise and go with a 700r4, my tech says I can manually shift it, to make up for not having the "e" trans
this is still hell of alot easier that having to shift all the time with the ZF
what do you think? it saves me 800 bucks is it worth being frugal in this department?
Posted on: 2009/11/14 23:01
I thought you were talking about another '89 car. Didn't realize you are talking about swapping an auto into your ZF car. Unless regular drag racing is on your menu, I'd stay with the ZF. They are fun to drive. I have an auto and like it but if I had a 6 speed I'd stay with it. An auto, for tooling around and having fun, just isn't as fun as a stick. If it is a daily driver and you are sick of shifting then do the swap, but I think you will look back and wish you spent the time/effort on something else.
Posted on: 2009/11/15 18:00
302 Posts
of course it's my ride, i sit in traffic and i had many automatics and i prefer that now that i have around 4000 miles with the Corvette stick, heck even new cars Ferrari's are automatic with paddle shifters, auto is the 21st century! resurrected....
Posted on: 2009/11/15 19:13
Corpus Christi
976 Posts
auto is the new standard in most cars
unless its the very high end vettes since the autos cant hold the power as well from the factory haha
Im all for 4L60e with paddle shifter kit
Posted on: 2009/11/15 19:24
