302 user(s) are online (270 user(s) are browsing Forums)
Matatk Engine Hoist Chain
Saw this in the Summit catalog. Is it worth $15? Better to go to HD and pick up three feet of standard chain?
http://www.summitracing.com/parts/SUM-G1027/
Brand Summit Racing
Manufacturer's Part Number SUM-G1027
Part Type Engine Lift Slings
Product Line Summit RacingĀ® Engine Lifting Sling
Summit Racing Part Number SUM-G1027
Weight Capacity (lbs) 600
Sling Style Chain
Chain Length (in) 34.00 in.
Sling Material Steel
Sling Finish Zinc
Quantity Sold individually.
Save your back when installing or removing an engine.
Don't throw your back out trying to get several hundred pounds of cast iron out of your vehicle-use our Engine Lifting Sling. The sling features a steel centering ring with a Zinc plated steel chain. The chain has steel tabs that bolt to your engine's mounting holes.
Posted on: 2009/11/21 2:56
Durango_Boy Re: Engine Hoist Chain
Don't forget to add shipping costs. I make all my own hoist chains. Not only does it save me money but I get to pick and choose the length, size, and chain ends.
Posted on: 2009/11/21 3:54
Livin_the_dream Re: Engine Hoist Chain
robesonia , pa
516 Posts
I agree a couple of eye bolts and clevis's and you can make your own with adjustable length
Posted on: 2009/11/21 4:06
bogus Re: Engine Hoist Chain
I have a leveler I got at Pepboys... works great.
Posted on: 2009/11/21 6:23
BillH Re: Engine Hoist Chain
Me to, big time saver.
Matt, the only thing with the Summit chain is that, if you guess the angle wrong, you have to sit the engine back down and have the chain totally loose to move a link and change the angle. Otherwise, there's nothing wrong with it.
If you decide to go to HD, take a 5/16 bolt with you and make sure the hole in the links are large enough for the bolt.
A standard piece of chain will work just fine with bolts and large washers.
Posted on: 2009/11/21 14:42
Aardwolf Re: Engine Hoist Chain
Fremont, WI
209 Posts
I pulled my engine last week and got some chain at Harbor Freight. It was $2 per foot (three needed) and heavier chain.
Posted on: 2009/11/21 15:59
Jeffvette Re: Engine Hoist Chain
Mat, a chain like that is fine when you are working on a Tri 5 Chev and you have room to push Rosie O'donnell through. The only way I suggest doing it in the Vette is with a load leveler. You don't have to pitch much in a C4, but an inch or two helps make things easier.
Posted on: 2009/11/21 21:11
Matatk Re: Engine Hoist Chain
Thanks, guys, I'll stop by Pep Boys when I'm ready for my project and pick up a load leveler.
Posted on: 2009/11/21 23:10
Fremont, WI
209 Posts
I thought of getting one too but decided not to, since the rebuild bill is high. I had zero trouble without one.
Posted on: 2009/11/21 23:40
NelsonV Re: Engine Hoist Chain
Sunny Southern CA
245 Posts
Or, if you happen to have your boat/trailer backed into the driveway such that the bow pulpit just happens to be right next to where you're hoisting your engine, you can also use your anchor rode chain...
Posted on: 2009/11/22 0:38
Hm... and you didn't borrow my leveler again...
Posted on: 2009/11/27 6:37
