290 user(s) are online (259 user(s) are browsing Forums)
Ultraman, more...
BrianCunningham 15yo lawn mower worth fixing?
This spring weather (60's) got me to yank out the lawn mower and try to get it up and running.
put some gas down the carb and it runs for about 15sec
pulled the carb off, I was expecting it to be all gummed up
nothing, nice and clean
I thought about the coil, but why would it fire up for a few seconds??
time to take it down and have it 'serviced'
how much they getting for that?
or should I just buy new one
Posted on: 2010/3/8 21:29
BillH Re: 15yo lawn mower worth fixing?
What brand of carb? Walbro? Does it have a small "prime" rubber button?
There's nothing to screw up in these small carbs, easy to take apart & put back together.
Unless you spend big bucks, the new mowers are fairly junky.
Posted on: 2010/3/8 21:37
Ultraman Re: 15yo lawn mower worth fixing?
14746 Posts
Online
probably cost you a $125 to have them go through it and change oil and plug sharpen blades and such. Ahhh maybe 80 or 90 bucks. Cheaper than a new one.
Posted on: 2010/3/8 22:45
VtVette Re: 15yo lawn mower worth fixing?
Las Vegas, NV
357 Posts
Agreed - it seems you gotta spend bucks to get something decent these days when it comes to small engines. There is a lot of JUNK out there.
the older stuff was more robust and seems to last longer.
Posted on: 2010/3/8 23:14
Brian
VTvette
And a ten buck DIY.
Posted on: 2010/3/8 23:37
BrianCunningham Re: 15yo lawn mower worth fixing?
didn't write the carb name down
it's a Briggs Europa engine though
paid $400 for it 15 year ago
Posted on: 2010/3/8 23:53
The $400 is now $800, fix it.
Check the line from the tank to the carb for crap.
I it's a pumper carb, it will have the prime rubber button that you push before startup. If it has this, it may be the diaphragm in the pump (his type of carb is a carb & fuelpump).
If it's not this type, it has to have a floatbowl and that's what you need to pull and check, should have gas in it.
Either way, these carbs are so simple and they can be taken apart and put back together without replacing anything, gaskets,etc.
Post a pic with it mounted on the engine.
Posted on: 2010/3/9 0:12
took the carb fully apart, not even any buildup.
after 15years!
Posted on: 2010/3/9 0:36
TommyT-Bone Re: 15yo lawn mower worth fixing?
I'm in the fix it camp too unless it's internal. It doesn't appear to be.
Posted on: 2010/3/9 1:15
Matatk Re: 15yo lawn mower worth fixing?
I'd fix it. I had a honda that was over 20 years old that I gave away when I moved (thought it would be easier). Hell, I bought a new one with a honda engine and it cost me almost $400, and isn't as good as the one from the 80s!!!
PS - sharpening blades is a PIA to get it correct and properly balanced. I'd pay the few bucks if I could even find a lawnmower shop that's open anymore.
Posted on: 2010/3/9 1:57
tjpreul Re: 15yo lawn mower worth fixing?
Spray the carb out with cleaner. The gasket is the fuel pump, so it is probably warn. It should be flat. Put a new one in and it should be fine.
Posted on: 2010/3/9 2:18
biggrizzly Re: 15yo lawn mower worth fixing?
Its got to be gunked up somewhere. I had an old sears craftsmen I bought about the same time. I gave it to my dad last year when I bought a new fancy mower. That old Briggs had a piston slap like no other but once it warmed up and stopped smokin' it would run like the devil. I just kept a sharp blade on it at all times to keep it from bogging down on high loads. Dad gave it to a friend and as far as I know its still running. I used to drop it off at the small engine place every couple of years for a cleaning and it kept it running through years of sandy abuse!!
Posted on: 2010/3/9 4:18
CorvetteBob Re: 15yo lawn mower worth fixing?
1409 Posts
I'm certainly not a wiz w/ lawnmowers, but I had a Toro do something similar to what yours is doing. Turned out to be a sheared flywheel key. About 37 cents, plus tax. PITA to fix, but stupid cheap.
Posted on: 2010/3/9 6:24
took it down
He said it was going to be $160 just to get it running again.
RIP old lawnmover!
Posted on: 2010/3/10 22:58
update:
the carb was completely shot
they cleaned it out as well
it ran a little longer, but wouldn't maintain idle at all.
all the control lines are frozen.
new carb is $40, then I'd have to get all new control lines.
He had a used Toro all tuned up and ready to go for $100
sounded good, so I picked it up today.
of course now it's going to rain for the next 4 days.
go figure.
Posted on: 2010/3/11 22:59
