83 user(s) are online (48 user(s) are browsing Forums)
Matatk Confirm I bought the wrong exhaust reducer...
I thought I had a ball/socket hookup on my headers, and I guess I should have checked them better. I ordered the reducer based on this, and they don't mate up properly. Verify I bought the wrong one so I can send it back. I believe I need a three bolt flange/gasket reducer.
jpg  2010-04-27 10.28.20.jpg (0.00 KB)
jpg  2010-04-27 10.28.48.jpg (0.00 KB)
jpg  2010-04-27 10.29.49.jpg (0.00 KB)
Posted on: 2010/4/27 16:31
pianoguy Re: Confirm I bought the wrong exhaust reducer...
It certainly would appear so.
Posted on: 2010/4/27 17:35
BillH Re: Confirm I bought the wrong exhaust reducer...
Matthew, It won't work either way. You're headers are gasket style and the exhaust pipe fitting is for a ball style like the stock pipes.
Simplest solution would be to cut the ball flange off.
Summit has the collectors w/gaskets and rings for $19/pair
Either weld on or clamp on.
Ref: SUM-G4753, 3" to 3" , you'll have to check for other pipe sizes. These are in the catalog.
Posted on: 2010/4/27 17:49
Also, looks like a Header Buddy might work.
SUM-G4722
Posted on: 2010/4/27 18:18
BrianCunningham Re: Confirm I bought the wrong exhaust reducer...
Can you return them?
Posted on: 2010/4/27 19:28
Matatk Re: Confirm I bought the wrong exhaust reducer...
Thanks guys, I just wanted to make sure I wasn't imagining things. It's my own fault. When I bought the reducers, instead of actually *looking* at my headers (which were in the garage and it was 10 at night) I just looked the headers up on summit and it said they were ball/socket so I ordered ball/socket reducers. Apparently the page is wrong, or since the headers are a few years old they changed the style.
I ordered these:
http://www.summitracing.com/parts/HED-21114/
and I need these:
http://www.summitracing.com/parts/HED-21100/
I'll send them back later today or tomorrow, they fit in a $5 flat rate box, so that's not too bad.
Posted on: 2010/4/27 19:35
These are the headers, so you can understand my confusion:
http://www.summitracing.com/parts/HED-68440/
Brand Hedman Hedders
Manufacturer's Part Number 68440
Part Type Headers
Product Line Hedman Street Hedders
Summit Racing Part Number HED-68440
Header Style Full-length
Header Material Steel
Header Finish Painted
Primary Tube Diameter (in) 1 5/8 in.
Collector Attachment Ball and socket flange
Collector Diameter 3.000 in.
Posted on: 2010/4/27 19:41
-=Jeff=- Re: Confirm I bought the wrong exhaust reducer...
Bartlett, IL
573 Posts
Honestly, i would buy the ball /socket set and cut the flanges off the headers and weld the ball style on there..
the ball and socket is what i used on my 89 and I did then same, I cut the 3 bolt flange off and with the ball and socket style, the sealing was better.
Posted on: 2010/4/28 12:17
-=Jeff=-
1990 Corvette ZR-1 #1051
RickAnthony Re: Confirm I bought the wrong exhaust reducer...
ASE Master Certified
Downers Grove, IL
703 Posts
I like this idea too Jeff, the ball and socket style, makes lining/fitting everything else up down the line much easier.. as when you have a slip fit or clamped connection everything must be straight to seal correctly. and it doesn't give you really any room to adjust/align things.
-=Rick
Posted on: 2010/5/14 19:29
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
Bartlett, IL
573 Posts
here are my 89 Exhaust pics (well some anyway)
http://www.vettextc.net/jeff/4-23-06/
Posted on: 2010/5/18 13:16
-=Jeff=-
anesthes Re: Confirm I bought the wrong exhaust reducer...
Boston, MA
I've done the same, and it works great.
Hedman changed all their headers to ball and socket over the last couple of years.
-- Joe
Posted on: 2010/5/20 17:41
flyboy Re: Confirm I bought the wrong exhaust reducer...
Are those C5 rear lights and is that an after market bumper?
Nice looking ride.
Posted on: 2010/5/20 23:10
Bartlett, IL
573 Posts
Nice looking ride.
Yes they are! unfortunately I sold that nice ride in Oct 2008
I have this one now:
Posted on: 2010/5/24 15:09
-=Jeff=-
