Matatk | Confirm I bought the wrong exhaust reducer... | ||
I thought I had a ball/socket hookup on my headers, and I guess I should have checked them better. I ordered the reducer based on this, and they don't mate up properly. Verify I bought the wrong one so I can send it back. I believe I need a three bolt flange/gasket reducer.
Matthew Attach file: 2010-04-27 10.28.20.jpg (0.00 KB) 2010-04-27 10.28.48.jpg (0.00 KB) 2010-04-27 10.29.49.jpg (0.00 KB) |
Posted on: 2010/4/27 16:31
pianoguy | Re: Confirm I bought the wrong exhaust reducer... | ||
It certainly would appear so.
Posted on: 2010/4/27 17:35
BillH | Re: Confirm I bought the wrong exhaust reducer... | ||
Matthew, It won't work either way. You're headers are gasket style and the exhaust pipe fitting is for a ball style like the stock pipes.
Simplest solution would be to cut the ball flange off. Summit has the collectors w/gaskets and rings for $19/pair Either weld on or clamp on. Ref: SUM-G4753, 3" to 3" , you'll have to check for other pipe sizes. These are in the catalog. |
Posted on: 2010/4/27 17:49
Also, looks like a Header Buddy might work.
SUM-G4722 |
Posted on: 2010/4/27 18:18
BrianCunningham | Re: Confirm I bought the wrong exhaust reducer... | ||
Can you return them?
Posted on: 2010/4/27 19:28
Matatk | Re: Confirm I bought the wrong exhaust reducer... | ||
Thanks guys, I just wanted to make sure I wasn't imagining things. It's my own fault. When I bought the reducers, instead of actually *looking* at my headers (which were in the garage and it was 10 at night) I just looked the headers up on summit and it said they were ball/socket so I ordered ball/socket reducers. Apparently the page is wrong, or since the headers are a few years old they changed the style.
I ordered these: http://www.summitracing.com/parts/HED-21114/ and I need these: http://www.summitracing.com/parts/HED-21100/ I'll send them back later today or tomorrow, they fit in a $5 flat rate box, so that's not too bad. Matthew |
Posted on: 2010/4/27 19:35
These are the headers, so you can understand my confusion:
http://www.summitracing.com/parts/HED-68440/ Brand Hedman Hedders Manufacturer's Part Number 68440 Part Type Headers Product Line Hedman Street Hedders Summit Racing Part Number HED-68440 Header Style Full-length Header Material Steel Header Finish Painted Primary Tube Diameter (in) 1 5/8 in. Collector Attachment Ball and socket flange Collector Diameter 3.000 in. |
Posted on: 2010/4/27 19:41
-=Jeff=- | Re: Confirm I bought the wrong exhaust reducer... | ||
Honestly, i would buy the ball /socket set and cut the flanges off the headers and weld the ball style on there..
the ball and socket is what i used on my 89 and I did then same, I cut the 3 bolt flange off and with the ball and socket style, the sealing was better. |
Posted on: 2010/4/28 12:17
RickAnthony | Re: Confirm I bought the wrong exhaust reducer... | ||
ASE Master Certified
I like this idea too Jeff, the ball and socket style, makes lining/fitting everything else up down the line much easier.. as when you have a slip fit or clamped connection everything must be straight to seal correctly. and it doesn't give you really any room to adjust/align things. -=Rick |
Posted on: 2010/5/14 19:29
Posted on: 2010/5/18 13:16
anesthes | Re: Confirm I bought the wrong exhaust reducer... | ||
I've done the same, and it works great. Hedman changed all their headers to ball and socket over the last couple of years. -- Joe |
Posted on: 2010/5/20 17:41
flyboy | Re: Confirm I bought the wrong exhaust reducer... | ||
Are those C5 rear lights and is that an after market bumper? Nice looking ride. |
Posted on: 2010/5/20 23:10
Yes they are! unfortunately I sold that nice ride in Oct 2008 I have this one now: |
Posted on: 2010/5/24 15:09
