154 user(s) are online (128 user(s) are browsing Forums)
The ...
BrianCunningham Murphy's law on taps
The tap you need will be in the next sized kit.
when you finally find a store that sell individual taps in the size that you need, they will be out of stock.
well at least I picked up the hacksaw I needed.
Posted on: 2010/6/30 22:20
1Fast04Vert Re: Murphy's law on taps
Same rule applies for bolts, nuts, screws, etc, etc. As huge as a HomeDepot inventory is they always seem to be out of the one thing I need.
Posted on: 2010/6/30 22:40
Matatk Re: Murphy's law on taps
So you can cut the hole out and not worry about tapping it at all?
Posted on: 2010/6/30 23:07
BillH Re: Murphy's law on taps
Gotta disagree, Andy. Home D's inventory sucks, it sucks, it sucks.
They will sell you a 7/16ths nut, but don't have one 7/16th bolt in the store.
Their specialty selection is a joke.
Lowe's new speciality selection is only half a joke.
We had a Supply One here that had 100x the stuff HD has.
They do have a good inventory of wood though.
Posted on: 2010/6/30 23:09
TommyT-Bone Re: Murphy's law on taps
33776 Posts
I like old mom and pop hardware stores. The longer they've been around the more hard to find stuff they have. Either that or ask BillH. He probably has two or three out in his garage.
Posted on: 2010/7/1 0:12
Bill,
Don't forget HDs headquarters is Atlanta. The stores here are likely better stocked since HDQ brass probably shop in them too. I must have at least 10 clerks offering to help me everytime I walk in. Oddly though I like Lowes better.
Posted on: 2010/7/1 1:38
Livin_the_dream Re: Murphy's law on taps
robesonia , pa
516 Posts
I thought you broke a tap.. For me it breaks on the last turn of the thread. You're better off buying from MSC with taps.. much better than most the stuff you find in the hardware stores
Posted on: 2010/7/1 2:17
Yes, he has a detailed storage and inventory system. If you ask him, I'm sure he'll be happy to look for you:
Posted on: 2010/7/1 2:39
flyboy Re: Murphy's law on taps
Posted on: 2010/7/1 3:45
95vette wrote:
Bill,
That's quite possible, keep the brass happy.
The supply One that was here was probably run out of business by Lowes & HD.
They did have an amazing hardware section. They had things like a section for socket head cap screws that was about 10 feet long, 6 ft. high shelves with drawers full of every size, std. & metric. HD has one foot and a half long drawer with just a few sizes, individually bagged no less.
Same with nails, HD has a lot of stock on the regular stuff but a poor selection of things like siding nails.
I shop there quite a lot though (closer that Lowes which i too like better).
I did a post a while back on the 10 clerks at HD and what I do after the 5th "Can I help you?", wasn't pretty.
Murphy says: Why do they all disappear when you actually have a question?
Posted on: 2010/7/1 13:15
Hell,Yea.
There's stuff out there I haven't seen in 20 years.
jpg  IMGP0802.JPG (0.00 KB)
Posted on: 2010/7/1 13:18
Thanks for the reminder, I gotta get them dumped in the lake before bodies decompose and start to smell.
Posted on: 2010/7/1 13:21
BrianCunningham Re: Murphy's law on taps
turns out Murphy's law also applies to wrenches and inverse torx bits.
Not enough room to get my extended socket on
Needed to go get a 24mm open wrench.
They don't sell inverse torx bits as singles
Needed to buy a $39 kit!
Better luck with my rear swaybar links
got the inserts milled down
all torqued down ready to go.
Posted on: 2010/7/9 2:32
