Browsing this Thread:
3 Anonymous Users
Weavsvet | TPIS vs Stainless Works LT's | ||
Started changing out these headers this morning. Going to TPIS 1 3/4" from Stainless Works 1 5/8" with the AFR 195 St. Elim. heads.
Below is a link to show the comparison between the two using the Fel-Pro 1404 gasket. Which btw fits the AFR's exhaust ports perfectly. The SW were blocking the exhaust port considerably IMO. You can tell by the soot on the SW header flange. The TPIS didn't fit the 1404 perfect either. They do now though. Just a very slight porting of their round exhaust ports took care of the fit. I feel this this will help exhaust flow quite a bit. http://s274.photobucket.com/albums/jj ... s%20Works%20LT%20headers/ EDIT: Had the Felpro number wrong but it is fixed now. I had 1204 and it's 1404. |
Posted on: 2010/7/5 13:23
1996 Corvette Coupe,AFR 195 street Eliminators,Edelbrock LT4 Air Gap intake manifold,9.5" 2800 stall,TPIS LT headers,Bullet 226/230.565.565/111 lsa cam,1.7 Scorpion rr's,EWP, X Pipe, Stock Exhaust,Elec.Cutouts,Dana 44/3.45, Tune by Wester's Garage |
Steve40th | Re: TPIS vs Stainless Works LT's | ||
The stainless works were blocking quite a bit.
Can you measure the TPIS, SW and Fel Pro gasket ID? |
Posted on: 2010/7/5 13:58
Ko'u ohana aia ku'a ikaika |
Weavsvet | Re: TPIS vs Stainless Works LT's | ||
The pictures do not really show the difference in these port sizes and how much was being blocked with the SW. This does though. Good idea Steve! SW header ID 6.01mm avg.(yes I doubled checked this). TPIS ID 15.88mm avg. Fel-Pro 1404 gasket ID 13.80mm avg. |
Posted on: 2010/7/5 15:25
Stl94LT1 | Re: TPIS vs Stainless Works LT's | ||
What? These numbers are not making sense to me. mm's? |
Posted on: 2010/7/5 15:33
The actual port is that small? A quarter is one inch and its 25mm.
Posted on: 2010/7/5 15:35
Think of it in wrench sizes. |
Hey, I'm going by what this digital caliper tells me. I'll try a rule....... |
Posted on: 2010/7/5 15:37
Calm | Re: TPIS vs Stainless Works LT's | ||
Are your old SW headers for sale?
Posted on: 2010/7/5 15:41
1995 Forged 385 ZF6 227/234 1.6 FIC30# MSD BBK SS SLP Bullets X-Pipe DynoMax |
Don't question this because I know how to read a rule! Fel-pro 1204 1 1/2" TPIS 1 9/16" SW 1 3/16" |
Not yet but they probably will be at a later date. |
Posted on: 2010/7/5 15:43
LOL. |
Posted on: 2010/7/5 15:44
BrianCunningham | Re: TPIS vs Stainless Works LT's | ||
Looking forward to the results.
Posted on: 2010/7/5 19:47
Matatk | Re: TPIS vs Stainless Works LT's | ||
I am amazed at the size difference.
Matthew |
Posted on: 2010/7/6 1:33
Posted on: 2010/7/6 21:51
What's TPiS say?
Posted on: 2010/7/6 22:49
I emailed them but no reply yet. It'll probably be tomorrow before I hear anything if then. Maybe I'll just call. |
Posted on: 2010/7/6 22:57
I would cut it and make it work.. The headers arent needing the extra length for any other purpose than fitment to wide range of vettes in the C4 line. Cut it, put some band clamps on it, and ensure your cats arent touching the floor boards or the tranny.
Posted on: 2010/7/7 4:14
I cut two inches off the right side and three off the left. Didn't help very much though. I'll just have to get some heat shield tape or something to protect the undercarriage next to these cats. Might also have to fab up something for the tranny to shield it. Those Walker clamps appear to have sealed really well. At least this way I can disconnect the headers form the exhaust system if need be.
Posted on: 2010/7/7 18:23
looks good
looking forward to your results. |
Posted on: 2010/7/7 19:28
Just curious, if you would have cut more off, like 4-6 inches so the cats are right up to the collector, would they clear the transmission and body better?
Posted on: 2010/7/7 20:02
Maybe but I would have had to cut the cat to. That would have put me into a big mess at the other end. The pipe would have to to short. If it doesn't work out I'll get some stainless and move them up. I looked at some old pictures with the SW on there. The cats are in about the same spot these are just bigger in dia. |
Posted on: 2010/7/7 20:07
are yours 4 inches in diameter at center and 2 1/5 in/out
Posted on: 2010/7/7 20:09
Posted on: 2010/7/7 20:10
I'd have to check 0n the dia. Steve. I do know they are 3" in and out. |
Posted on: 2010/7/7 20:11
Thanks. Now go drink some sweet tea, no lemon of course, and relax for a while.
Posted on: 2010/7/7 20:17
Posted on: 2010/7/8 9:27
Damn it!!!!!!!!!!!!!!!
I fired it up this morning and let it run for a while. So why I'm fiddling around doing something else I look up and there is black smoke poring up from the back of the engine! Smells like plastic. I run get the water hose and start spraying. It didn't seem to help any so I look under the car and the right cat is glowing bright red. I guess it was melting the under carriage. The left side was fine. I'll have to look later today to see what the damage is. What could cause a brand new cat to do that? Acts like it's plugged or something. |
Posted on: 2010/7/8 11:41
flyboy | Re: TPIS vs Stainless Works LT's | ||
That sucks, lean condition?
Posted on: 2010/7/8 11:55
High Temp Copper RTV will work, LPE uses this on their turbo flanges for their Vettes.
Any check engine light? For the right side to be lean, you may have a broken spark plug (header install can cause this #8 on TPIS), or a loose/broken wire on the O2 sensor, or loose sensor in the bung, and of course header leaks at exhaust gasket. There are some other things, but you dont touch them for header install. |
Posted on: 2010/7/8 13:15
One of things that had my attention when all of this happened was I was looking at readings on the Tech1. BLMs were 128/128. I'll have to check it for a leak at the band clamp before the cat on that side. But seems like BLMs would be off if there was a leak. Injector v on all 8 was 4.2 something @ 1000 rpm. I'll just start checking things. It's possible I may have switched the 02's from one side to the other because I didn't mark them.
Yes, #8 is more of a pain with these headers even from underneath. I'll check that also. Thanks! |
Posted on: 2010/7/8 16:21
Nothing will affect a condition such as this after the O2 sensor. If you swapped O2 sensors, it would make no difference.
If both sides show blms 128/128 and voltages good we need to look at mechanical, ie plugs etc. burnt/or arcing plug wire close to header.. |
Posted on: 2010/7/8 16:26
Ok, I put HT RTV on all four band clamps. Since the car did not seem to be missing on a cylinder I'm hoping this is it. Trouble is I have to wait until tomorrow to crank it so that messy s**t can cure.
Posted on: 2010/7/8 17:42
BTW, it appears all of the smoke was coming from some heat tape I had stuck close to the cat. It had come loose and fallen down on the cat. No harm done to the under body at all.
Posted on: 2010/7/8 17:57
pianoguy | Re: TPIS vs Stainless Works LT's | ||
Good to hear! |
Posted on: 2010/7/8 18:08
Ok, I've made sure there are no exhaust leaks, checked plug wires(number 6 slipped on a little but no much). So it's sitting there idling and I keep looking under the car at that right side cat. After about 15 minutes that sucker is glowing bright red again. The voltage on the right side 02 is fixed at 43mv or so. The other side is bouncing around all over the place. I changed that 02 out with another one I had and it's the same fixed mv and not moving. Do you think this is a wiring issue? Wires look ok around the 02 itself.
Posted on: 2010/7/9 15:02
Can't help, but I'm glad you're getting somewhere and you didn't melt your floor pan.
Posted on: 2010/7/9 15:36
yeah me too! I really expected to see a big hole in there. As usual another self inflicted wound on my art. I had #2 & #4 plug wires crossed. The problem now is that the left side cat is glowing after running a while now! Just have to start checking that side after it cools down some. I may have a exhaust leak on that AIR connector where it screws into the header. BLMs are 130 on that side now. I hope it's that simple. |
Posted on: 2010/7/9 15:43
The air header leak on the left side will cause a lean condition over time. Ultra Copper RTV that pipe thread going in there. Now hopefully the other side cat is okay.
Posted on: 2010/7/9 16:11
Did that. Solomon says those are LT fuel trim numbers and 130 is close enough. I hope the cats are ok too. Right (edit, right not left)) one got really hot. twice! |
Posted on: 2010/7/9 16:47
It's down off the stands but I'm still getting a low voltage code on bank 1 02 sensor. I put a short jumper in there to clear the headers could that be causing this code? PO131
In the mean time CRANK IT UP..... |
Posted on: 2010/7/9 22:39
CentralCoaster | Re: TPIS vs Stainless Works LT's | ||
Are you going to mount some electric cutouts in there, or just plates?
Nm, I see your avatar. |
Posted on: 2010/7/9 23:40
MK 82 | Re: TPIS vs Stainless Works LT's | ||
Nope. Think about it. What is a cats job. To burn of the hydrocarbons and reduce Oxides of nitrogen. It is pig rich and the cat has a bonfire. Eddie |
Posted on: 2010/7/10 2:15
96 CE Roadster LT4 |
Where did you put the jumper? You cannot mess with the O2 after the connector. Any extensions have to be added upstream of the plug.
An O2 sensor has to have ambient air as a reference. Believe it or not, it gets it from the wires. putting a splice in there screws it up. You will need a new O2. Eddie Quote:
Posted on: 2010/7/10 2:23
I think the lean condition is correct, as far as the ECM sees, and therefore it dumps fuel to fix the lean condition |
Posted on: 2010/7/10 2:25
True, you cant splice anywhere from the connector to the sensor. BAD. Its in the FSM. It will ruin the readings, which is from 0- .1 volts, not much room for error. |
Posted on: 2010/7/10 2:26
Thanks guys. I figured it was dumping fuel and therefor a very hot cat. Being the "not paying attention" individual I am I had crossed #2 & #4 plug wires. That is what was causing bank 2 to fire up the cat like it did. The jumper is a 12" plug and play jumper that came with the headers. Probably for the rear cats (which I don't have). I'll just remove it and try to get the 02 wire off the header and see if that takes care of it. |
Posted on: 2010/7/10 3:23
Posted on: 2010/7/10 12:20
This is getting old really fast............
So, I replace the bank 1 02,take out the jumper and go for a 30 min drive. It had thrown a code in shorter time than this last drive. I almost make it home and BANG! SES light,crap! I check it out and it is different this time PO1153, slow response bank 2 sensor one. I wrapped the 02 wires up in reflective heat tape. Was this a no no? That's the only thing I did different on that side. I'll remove it after it cools down and try again. Another thing according to FSM is the use of some RTV. I used high temp RTV yesterday to seal off the band clamps. Wouldn't it have thrown this code yesterday instead of waiting until today to do it if it was the RTV causing the code? Mercy........... |
Posted on: 2010/7/10 15:11
RTV is fine where you used it. The O2 sensors can not be altered or have any rtv at all on the threads etc. They come with something already on them.
I would check wiring on O2's. Ensure they are not cut at all from connector to O2. Are you sure the tune has the O2's after the cat tuned out? |
Posted on: 2010/7/10 17:42
Positive. Tech1 shows fixed mv values no activity at all. |
Posted on: 2010/7/10 17:55
