movnviolation | Vacuum source | ||
Is the fuel cannister the main source for the vacuum system?
I have some vacuum from the throttle body going down to the cannister but none leaving. Also, what is the vacuum line from the cruise control into the firewall connected to, and witch line is he source of vacuum to the cc. I took the panel under driver side but can not folloe the line. Any help? Thanks |
Posted on: 2010/7/9 22:31
Mods AFR 180 comp. heads w/ heavy springs. TPIS ZZ409 cam w/ 1.6 roller rockers, TPIS long tube headers, Miniram, 52mm throttle body, 24 lb Bosch injectors, Level V TPIS chip |
1Fast04Vert | Re: Vacuum source | ||
On my 95 the vacuum ball (reservoir) is in the well in front of the left front tire. Vac hose from servo that goes thru the firewall hooks to the cruise control disconnect switch on the brake/clutch pedals. Vac to the servo comes from a fiting under the pass side fuel rail cover. Hope this helps.
Posted on: 2010/7/9 22:44
movnviolation | Re: Vacuum source | ||
Thank, that explains the line through the firewall. The ball only has one vac line going to it. I assumed that was to retain vacuum for a short time.
Posted on: 2010/7/9 22:53
CentralCoaster | Re: Vacuum source | ||
The vacuum source comes from several places and the charcoal cannister isn't one of them. Your 89 should have come with a vacuum line diagram sticker on the radiator shroud.
What are you trying to accomplish? |
Posted on: 2010/7/9 23:31
Correct on both parts. |
Posted on: 2010/7/10 1:47
MK 82 | Re: Vacuum source | ||
The hard vac line that goes into the wiring harness into the dash also feeds the AC servos.
Posted on: 2010/7/10 2:02
96 CE Roadster LT4 |
I found a broken check valve under my 89 by the front left wheel. It was identified on here as the check mvalve for the climate control door. I am trying to find where that goes, and found there is no vacuum comming up the left side where the T is. The lines off the T go to the cruise control, and one goes to the small tube into the wire loom that goes to the climate control. No diagram on radiator shroud. My haynes has nothing. Thanks |
Posted on: 2010/7/10 3:19
vetteoz | Re: Vacuum source | ||
movnviolation wrote: witch line is he source of vacuum to the cc. On a TPI ,vac supply to check valve comes from one of the ports on pass side rear of plenum (as shown in diagram below ) Rear line from check valve goes to plastic HVAC line in firewall harness; rubber hose on side port of valve goes to the T feeding cruise then the vac line continues along inner wheel well to vac ball. Rubber line through firewall for cruise release is seperate item as noted above by 95vette Quote:
So someone has played around with it and not hooked up the vac supply to the check valve Quote: movnviolation wrote: Usual place is by the dist. [IMG]http://i171.photobucket.com/albums/u309/vetteoz/electrical/checkvalve.jpg[/IMG] |
Posted on: 2010/7/10 3:43
movnviolation wrote: My haynes has nothing. That is why most use them in the toilet and not for reading either Quote: movnviolation wrote: No diagram on radiator shroud. Vac lines for A/c and cruise are seperate from emissions plumbing shown on sticker. Factory emissions sticker [IMG]http://i171.photobucket.com/albums/u309/vetteoz/electrical/VacuumTPI.gif[/IMG] What yours should look like with AIR and EGR removed Your MR setup will be identical except for where you get the vac supply for HVAC/ cruise from [IMG]http://i171.photobucket.com/albums/u309/vetteoz/electrical/VacuumMOD.gif[/IMG] |
Posted on: 2010/7/10 3:46
Matatk | Re: Vacuum source | ||
If you have a check valve that matches the A/C check valve in front of your wheel well near your headlight, that's wrong. In that case, are you sure it's not a disc style valve? If so, that is for the EVAP system. Or is the valve behind the wheel well? If that's the case, it sounds like it was moved. The picture Oz posted is where it should be. I have a bunch more that can help if you are more specific.
Can you post a picture of what you are looking at/for? Matthew |
Posted on: 2010/7/10 5:57
Thanks guys, will hit it today again.
Posted on: 2010/7/10 10:04
flyboy | Re: Vacuum source | ||
Thanks for the info. |
Posted on: 2010/7/10 12:15
Up and running. Started anew. Thanks Oz
Posted on: 2010/7/10 19:35
