BrianCunningham | Car's new stance with coilovers | ||
Posted on: 2010/7/10 13:20
TommyT-Bone | Re: Car's new stance with coilovers | ||
Now all you'll need is a speed bump/sidewalk hump deflector plate. Are you still gonna cruise it or are you mostly going to track it? You have the pick up truck. Do you have a long ramped trailer? Just wondering .....
Posted on: 2010/7/10 13:27
BrianCunningham | Re: Car's new stance with coilovers | ||
Yes
Yes and yes one of the nice things about coilovers is the ability to adjust the ride height. I may raise the front a little just so the race tires won't rub. |
Posted on: 2010/7/10 13:38
Matatk | Re: Car's new stance with coilovers | ||
This has been a long day coming. I share your pain and your joy!!! Lol. Now when will the motor be done?
Matthew |
Posted on: 2010/7/10 13:43
BillH | Re: Car's new stance with coilovers | ||
I had one guy with coils that had that problem on the track but he was definately too low to start. Probably messed his alignment up a bit when he raised it at the track. Definately something to check after your first session. |
Posted on: 2010/7/10 13:45
I've been keeping my builder busy modifying suspension parts, man I wish I could weld, so I can't fault him for not having it done yet ;) |
Posted on: 2010/7/10 15:17
Weavsvet | Re: Car's new stance with coilovers | ||
Posted on: 2010/7/10 21:26
1996 Corvette Coupe,AFR 195 street Eliminators,Edelbrock LT4 Air Gap intake manifold,9.5" 2800 stall,TPIS LT headers,Bullet 226/230.565.565/111 lsa cam,1.7 Scorpion rr's,EWP, X Pipe, Stock Exhaust,Elec.Cutouts,Dana 44/3.45, Tune by Wester's Garage |
Steve40th | Re: Car's new stance with coilovers | ||
Cant wait for some driving impressions etc once alignment is done.
Posted on: 2010/7/10 22:07
Ko'u ohana aia ku'a ikaika |
Just got back from my Corvette Club's meeting, which gave me a chance to go for a nice long drive on a variety of roads.
WOW what a difference. Not only is the ride better, but it takes offramps like they weren't even there. A kidney belt is no longer required. Rough roads not only don't bother it, but the car has grip on them to boot. |
Posted on: 2010/7/12 2:46
vis_croceus | Re: Car's new stance with coilovers | ||
That got my attention. Which coilovers? Shocks? Spring rates? |
Posted on: 2010/7/12 4:52
94 vert |
pianoguy | Re: Car's new stance with coilovers | ||
Looks great, Brian - glad to hear the ride and handling are worth the effort!
Posted on: 2010/7/12 12:21
Trae1976 | Re: Car's new stance with coilovers | ||
Love the stance, very nice!
Posted on: 2010/7/12 12:51
Penske double adjustables with Hardbar dual rate springs. I bought them used off another forum member for $2,500. and converted them for use on a C4, C5/6's use different ends. The beauty about these is that you can rebuild them yourself right at the track. You can have all the power in the world, but if you can't get it to the ground, it won't do you any good. The dual rate springs can be fitted to any coilover shock. In the past.. you could either pick a spring that would make it handle great on a flat track, but bouce all over the place on a rough road. Or you could pick a soft compliant spring that would give it a great ride, stick to the little bumps, but do poorly when the going got fast. But that's no longer the case... With the dual rates, you have a soft spring that not only helps with rough roads, but helps you stick to them better as well. Then the stiff springs kick in when they are needed. So, in a sense, they are self adjusting as well. |
Posted on: 2010/7/12 18:18
Luv to see that. |
Posted on: 2010/7/12 19:33
CentralCoaster | Re: Car's new stance with coilovers | ||
I wouldn't put it past him, lol, but the toolbox might do more laps than the car.
Put some crazy swaybars on there to reduce body roll and fender rub. Have you looked into an adjustable swaybar also? |
Posted on: 2010/7/12 23:29
Not that hard. relief the pressure, a couple of snap rings and they come apart. You just need a nitrogen tank to recharge it. I already went from the base springs to the Z07 bars Now I have solid links, which should make a big difference in reaction time. |
Posted on: 2010/7/13 15:25
SpectatorRacing | Re: Car's new stance with coilovers | ||
Cunningham, that car will always be slow until you get some stickers on it!!!
Posted on: 2010/7/14 22:56
aka Scaryfast |
LOL
I like stealth mode Tell newbies it's stock to mess with them |
Posted on: 2010/7/14 23:12
loaded up some pics of my suspension mods
more... http://s242.photobucket.com/albums/ff ... wood/Corvette/Suspension/ |
Posted on: 2010/7/15 0:53
You should budget $200 towards a camera, lol.
Did you do coilovers and the banski at the same time? I honestly have a reallly hard time understanding how coilovers in back would effect the ride unless the coils were progressive rate or just softer. |
Posted on: 2010/7/15 6:32
the springs are dual rate, which is one reason they really help out.
Get to try out the new suspension Sunday, looking forward to it! |
Posted on: 2010/8/6 21:23
Finished my morning run, I'm on gate duty @ the moment
The car felt so go with the front bar disconnected I decided to try it out @ the autocross, don't know unless you try ;) Well...it turns in fine :lol: I'll be hooking it back up for the next one! |
Posted on: 2010/8/8 17:23
