190 user(s) are online (137 user(s) are browsing Forums)
JrRifleCoach GP***Tapered Rear Wheel Bearing Part Deux ***GP
1524 Posts
[size=18:445cb2cd4c][color=red]This GP is CLOSED
2/4 - Bearings ordered
[/color:445cb2cd4c][/size:445cb2cd4c]
Price? 257.90 a pair, plus $10 shipping via USPS Priority Mail for MO's
Add an additional $8.00 if using PayPal. No Checks or CC's.
Shipping weight is 25 lbs. I ship via USPS Priority flat rate to the US.
I'm OK with shipping out of country. It can be expensive. So to be fair to both of us, if you or any other C4Guru member that wants a set, you need to research the shipping costs ahead of time. I did ship one set to Canada that cost approx $25 USD.
I can suggest using;
www.usps.com
www.ups.com
www.fedex.com
Calculate the rate based on
25 lbs 11"x 8 1/2"x 5 1/2"
11.36kg 28cm x 21.6cm x 14cm
From Sonora, CA 95370 to your location
Any documentation required needs to be emailed to me in advance.
Here are some other prices from the web;
C4guru GP TAPERED 267.90 includes shipping
Corvette Central BALL 299.99 w/o shipping
Ecklers BALL 299.99 w/o shipping
VanSteel AC Delco BALL 519.98 w/o shipping
Ecklers AC Delco BALL 575.98 w/o shipping
Rock Auto BALL 311.58 w/o shipping
Ebay TAPERED (same part) 313.76 includes shipping
The GP will be for 15 pairs, The next block will start after January 1 and end when all the money is collected or the 4th of February which ever comes first. Shipment will take 2-3 weeks and I'll get'em out to you ASAP!
Heres the list of reservations. I will update this list as each member checks in and payments are received. Please PM me or use my listed email address. I will send the payment info at that time.
I'll check in twice a day to update this info column.
If your not listed, please contact me ASAP.
ALSO Please communicate with c4guru PM or email. NOT on the CF
(Counts are pairs)
aboatguy...........1 Paid MO
gear-head2.......1 Paid PP
Metal-Tech........1 Paid MO
DropTopCE.........1 Paid PP
CactusJim............1 Paid MO
Ramrod..............1 Paid pp
Bluewasp............1 Paid pp
_______________________________________
Other links of interest
First RWB GP
RWB Research on the CF
RWB Disassembled
Posted on: 2007/12/5 4:28
JrRifleCoach The next GP starts now!
1524 Posts
TTT If your name is on the list please checkin here. I will be collecting the monies as well. If those listed have not checked in before the end of January I will drop your name to the next GP and offer the spot to the next requester in line.
Others not listed/mentioned are welcome to place their requests.
Fair is fair to all on the C4guru
Posted on: 2007/12/30 6:53
DrEvil RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
Get in mah belly!
71 Posts
My caffiene hasnt fully kicked in yet but the short version I take it is that we found a tapered rear wheel bearing that provides substantial side loading for cornering applications that should last longer. Its not serviceble. No negatives, still uses ABS and is a direct bolt in replacement. Anything else?
(yes I read the links but found the info to be a bit convoluted in my current state.)
Posted on: 2007/12/31 17:30
JrRifleCoach RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
1524 Posts
Short answer....Yes
To date, nothing negative.
Posted on: 2007/12/31 17:38
Get in mah belly!
71 Posts
Posted on: 2007/12/31 18:33
SpectatorRacing RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
I'm going to perform the track testing this summer to verify...
Hopefully I can get in on this one, but just bought a new truck and have a cage / fuel cell install to pay for.
Anyone have $257 i can borrow?
Posted on: 2007/12/31 18:55
Bluewasp RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
6 Posts
I'm still in for 1 pair.
Posted on: 2008/1/2 11:19
MK 82 RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
Palm Beach Gardens, FL
439 Posts
I will take a pair!
Posted on: 2008/1/6 21:03
96 CE Roadster LT4
1524 Posts
I know its still early, however few members on the "A" list have checked in.
If your on the "B" list theres a good chance we'll get you a pair this round.
Cheers!
Steve
Posted on: 2008/1/6 21:41
Notorious RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
I might consider lending it to you. But I'm of Italian descent so loan shark rates will apply. Also, my cousin Giuseppe would be keeping a close eye on you.... I'd be very interested in your results and will consider them a worthy acid-test.
I'd seriously be interested in perhaps the next go-around. Considering the price of any stock replacements that one would have confidence in installing, this is very reasonable. Any plans for upgraded fronts in the future too?
Posted on: 2008/1/6 21:55
I hate sporks...
1524 Posts
Front wheel bearings
The testing did not go well and the project has been placed on hold for the time being. Maybe later this year........
Until then, we still have a RWB GP going on and since the pledges are not responding, this GP is open to everyone.
Posted on: 2008/1/15 6:09
1524 Posts
Going........
Posted on: 2008/1/24 1:25
1524 Posts
Going........
[size=12:48ca74ceeb] ...............Going..............[/size:48ca74ceeb]
Posted on: 2008/1/24 22:36
1524 Posts
Going........
[size=12:715bc1b57f] ...............Going..............[/size:715bc1b57f]
[size=18:715bc1b57f]..................................Going.............................. [/size:715bc1b57f]
Posted on: 2008/1/26 21:49
jaa1992 RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
Stone Mtn, GA (near Atlanta)
187 Posts
Rats!!!!!!!
We could always use a good less expensive source for front wheel bearings.
Posted on: 2008/1/28 1:00
JrRifleCoach Last chance
1524 Posts
Times up. This GP is closed
Posted on: 2008/1/31 1:21
1524 Posts
The RWB have been ordered. Shipping date TBA
Posted on: 2008/2/4 16:35
Aboatguy RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
My Avatar was redistributed!
498 Posts
Thanks for doing all the work on this GP!!!
Are you still looking into replacements for the fronts?
MIke
Posted on: 2008/2/24 17:57
1524 Posts
Ahhh for those whom have paid......
I expect the order to arrive sometime this coming week. Then shipped out ASAP Expect delivery before March 15th.
Posted on: 2008/3/1 4:51
Ramrod RE:GP***Tapered Rear Wheel Bearing Part Deux ***GP
S. California
296 Posts
right on Bro.........
Posted on: 2008/3/1 5:46
1524 Posts
TTT
Posted on: 2008/3/5 15:47
JrRifleCoach Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
1524 Posts
The order has arrived today.
I'll be packing them up for shipping tomorrow.
You guys can start looking for these in the mail next Tuesday or Wednesday
Posted on: 2008/3/6 3:05
Aboatguy Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
498 Posts
Great Thanks for doing the leg work.
MIke
Posted on: 2008/3/6 7:59
1524 Posts
Pieces are in hand today. Will be shipping them out this weekend.
Posted on: 2008/3/7 0:44
Strick Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
Lake Wylie, SC
129 Posts
Although not part of this GP, I missed it, I got my tapered bearings yesterday and installed them last night. Now I have zero play in the rear wheels. I haven't driven on them yet as my son has me blocked in the garage. (Electrical problem) As far as looks go, they seem like a quality product. I took some pictures comparing the OEM bearing and the tapered one. Externally, not much difference.
Posted on: 2008/3/12 19:04
1524 Posts
Hear Ye! Hear Ye!
The second GP bearings have been dropped at the PO and are on the way.
Please check in when your packages arrive!
Posted on: 2008/3/16 5:58
498 Posts
Thanks Again for doing the legwork!!!
Posted on: 2008/3/16 19:40
498 Posts
Boy that was quick, the mail carrier just delivered mine!
Posted on: 2008/3/17 20:56
MK 82 Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
439 Posts
Got mine. The styrofoam was pulverized but the hubs were in good shape.
Posted on: 2008/3/17 21:50
96 CE Roadster LT4
Ramrod Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
S. California
296 Posts
Got mine today Beautiful! thanks for the work Jr Rifle Coach.
Posted on: 2008/3/18 0:43
1996 LT-1
DynaSpark Opti, Tapered Rear Wheel Bearings, SS Brake Lines, Speed Bleeders, MC Bias Spring, Hawk HPS Pads, MSD Wires,NGK Iridium, lowered, etc.
1524 Posts
Sweeeeet!
Posted on: 2008/3/18 1:22
1524 Posts
Anyone else received their packages?
Posted on: 2008/3/19 16:07
Metal-Tech Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
OKC
3 Posts
Not yet, but maybe the rain we had earlier in the week slowed things down a little.
Posted on: 2008/3/20 9:38
94 6spd
CactusJim Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
San Antonio, Tx.
4 Posts
Nothing yet. Hope it didn't get stuck in the mud somewhere!
Posted on: 2008/3/27 0:43
You can lead a horse to water, but you have to drag a jackass.
San Antonio, Tx.
4 Posts
Got'Em ! Probably came in the first part of the week, just forgot to check our "oversize" box at work. There they were! Box was in good shape; the styrofoam was a little busted up but did it's job nicely and kept the contents from any damage. Those are really nice pieces!
Posted on: 2008/3/28 4:19
1524 Posts
Kewl!
So metal-tech, did you find them yet?
Posted on: 2008/3/28 4:52
OKC
3 Posts
No, My postal carrier delivered them to the wrong address. I'm going to file a police report for theft since she said she delivered them. The reason I highly doubt she left them at my house is why didn't they take the Dewitts rad I got recently, much bigger box to attract attention. Everything I've ordered from Summit, Jegs, McMaster Carr, MSC, has all been left at the front door in plain sight and always been there when I got home. I should have sent some extra $$ for UPS shipping. Can you give me some details about the box for when I do the police report?, size, color, address on outer box or label. Thanks, Al
Posted on: 2008/3/28 10:07
94 6spd
1524 Posts
Al,
The box is a USPS Priority Mail, Flat-Rate box.
11x8.5x5.5 weight 25lbs. $8.95
Delivery Confirmation 0103 8555 7494 9137 1563
Ship Date 3.14.08
Postage online transaction # 11848850
I'm going to start a query/search from my end as well.
Posted on: 2008/3/29 16:52
1524 Posts
Don't give anyone your reasoning for the carriers error.
Heres why; the carrier is solely responsible for the delivery. This means that the carrier must pay for the loss as well. Since the package did not arrive at your door then the carrier will have to dig into his/her pocket to cover the loss.
I called my friend at the PO I shipped from and he said to goto the USPS.com site and file a report. Since the report is filed in this manner the PO Master must respond and resolve your problem.
So don't give them any info other than your pissed, and want your package or $280 bucks to cover your loss. I have all the receipts so I can verify the contents value.
Good Luck,
Steve
Posted on: 2008/3/29 18:19
OKC
3 Posts
Good news, the box found it's way to my house today. The bearings were fine along with the torque instructions. Steve, thanks for all the hard work putting this GP together. Al
Posted on: 2008/4/3 0:07
94 6spd
rickreeves1 Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
New Orleans
96 Posts
Is this over now or is there another GP going to happen? I just came across this today from the other forum. Anyone have miles on these that can report how they are holding up. When will fronts be available?
Thanks
Posted on: 2008/4/15 17:32
the-blur Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
1 Posts
ttt
Posted on: 2008/4/16 13:21
ITHZ Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
Carrollton,Ga
46 Posts
I'm interested as well.
Posted on: 2008/4/17 23:58
1524 Posts
A little background so we're on the same page.
First GP netted 17 buyers or 34 pieces. We got the best price and the orders were delivered just after Thanksgiving.
Second GP we barely got 7 buyers or 14 pieces. My contact pushed his boss and we still got the price. BUT, in order to get the same price I have to have a minimum of 30 pieces or 15 buyers.
This can happen quickly if the word spreads quickly. I'll do the leg work if you guys will help find the buyers.
Please contact me via PM only. I usually hang out at C-G OT these days and seldom sign-in at the other place.
Should duty call, I'm at your service.
Posted on: 2008/4/18 5:27
1524 Posts
Bump!
Posted on: 2008/4/22 6:55
kmillar Re: GP***Tapered Rear Wheel Bearing Part Deux ***GP
Calgary
2 Posts
Do you have any unclaimed wheel bearings, I'd be interested in a set.
Posted on: 2008/5/9 22:12
