279 user(s) are online (133 user(s) are browsing Forums)
sliding Fuel cut-off rev limiter
Zagreb, Croatia
326 Posts
Does anybody here use fuel cut-off rev limiter?
Stock setting is something like 10000 rpms.
I was wondering if anybody uses it and what difference
in rpms do you use for fuel cut-off enable/disable?!
Posted on: 2010/8/26 10:25
Woodstock Re: Fuel cut-off rev limiter
Bremen/Germany
369 Posts
I've been helping a friend to program his '87 383 L98.
After seeing the pictures from your previous mess, we went ahead and put the rev limiter at 6000.
Now he uses it sort of as a feature and loves it. He puts his automatic in 2 gear and rides it up to 6000, after hitting the rev limiter he shifts manually into 3rd.
Now he can have his eyes on the road and doesn't need to worry about the revs anymore. Like I said, he loves it.
Posted on: 2010/8/26 10:47
91 convertible
Matatk Re: Fuel cut-off rev limiter
I had Mick program mine in. Even though it's a LTR setup, I didn't want to take any chances. I had him set mine at 6000 if I recall correctly.
Posted on: 2010/8/26 11:24
Aboatguy Re: Fuel cut-off rev limiter
My Avatar was redistributed!
498 Posts
Mine's set a little above 7k and I hit it all the time.....
Posted on: 2010/8/26 18:11
89Vette Re: Fuel cut-off rev limiter
135 Posts
Pick a difference in the 50rpm range. So, if you turn off at 6250rpms,,,have it turn back on at 6200.
Posted on: 2010/8/26 19:26
iCorvette Re: Fuel cut-off rev limiter
302 Posts
you will notice it when you hit it, it stops the car
Posted on: 2010/8/26 21:38
PLRX Re: Fuel cut-off rev limiter
SoCal
212 Posts
PCM4Less removed both of mine. I wish I had it in my automatic.
Posted on: 2010/8/27 0:23
mseven Re: Fuel cut-off rev limiter
Motor City Madhouse
247 Posts
Bruno,
I thought you had a 6al in the car? If so put in the pill for rpm desired. I'm not a fan of cutting fuel and would rather cut spark as rev limiter but if concerned a fuel cut is better than nothing. What rpm were you planning on as a shift point? I would go approx. 100rpm above the shift point with approx. 75rpm difference.
Mick
Posted on: 2010/8/27 1:04
Motor City Madhouse
247 Posts
that's a real easy fix, won't Alvin/Brian re -do it for you?
Posted on: 2010/8/27 1:06
sliding Re: Fuel cut-off rev limiter
Zagreb, Croatia
326 Posts
mseven wrote:
Bruno,
Mick
NO, I still have completely stock HEI system. I plan to
upgrade, but not just yet.
I'll set it to 6800. I plan to rev it to 6500-6700 max. but
just for insurance. So 50-75 rpms difference should work!
Thanks guys!
Posted on: 2010/8/27 6:31
Stl94LT1 Re: Fuel cut-off rev limiter
128 Posts
I can't see using the rev limiter/fuel cut-off as a shift point. Your friend's engine may be running on borrowed time.
Posted on: 2010/8/28 17:33
SoCal
212 Posts
Yes, sir. I got few others project ahead. I waiting for this heat wave to pass.
Posted on: 2010/8/28 19:12
