172 user(s) are online (116 user(s) are browsing Forums)
flyboy Rehabbing the "halo" cover
My halo covers had some damage, so I purchased a used right side and repaired the left. There is no filler that adheres well to polypropylene so I had to pop-rivet some sheet metal for backing and cross my fingers with the epoxy. Paint would not have produced the desired result, so I covered with ultra leather using spray adhesive. Turned out even better than hoped for.
jpg  P1010003.JPG (130.72 KB)
1735_4d19457416f3a.jpg 640X480 px
jpg  P1010001.JPG (145.04 KB)
1735_4d1945852ea10.jpg 640X480 px
jpg  P1010005.JPG (130.87 KB)
1735_4d1945adacb5d.jpg 640X480 px
jpg  P1010007.JPG (132.14 KB)
1735_4d1945bcdf46f.jpg 640X480 px
jpg  P1010009.JPG (121.14 KB)
1735_4d1945d119d3e.jpg 640X480 px
Posted on: 2010/12/28 2:05
bogus Re: Rehabbing the "halo" cover
looks VERY nice!!!!
Posted on: 2010/12/28 2:11
BillH Re: Rehabbing the "halo" cover
Looks great, Joe.
Want to share some info on ultra leather? Never heard of it.
Looks very nice, easy to conform.
It's not a product from Ultraman is it?
Posted on: 2010/12/28 2:17
flyboy Re: Rehabbing the "halo" cover
Thanks. It feels like glove leather. Used for upholstery. About a mm thick. The thin fabric backing gives it a little stretch lengthwise but not across the width. 3M high strength spray adhesive, coat both surfaces, kind of tricky, (once it's grabs, that's it) but I have a lot of experience with contact adhesives. Here's where I bought it.
http://www.fieldsfabricsonline.com/Ul ... -Reinforced-HP_c_340.html
Posted on: 2010/12/28 2:31
j3studio Re: Rehabbing the "halo" cover
Interesting ...
... nice work!
Posted on: 2010/12/28 2:44
Matatk Re: Rehabbing the "halo" cover
22810 Posts
Wow that looks great. Just what I need for my damaged halo pieces, I believe.
Posted on: 2010/12/28 2:56
Ultraman Re: Rehabbing the "halo" cover
14785 Posts
I'm thinking I should be getting some type of royalty from it, bit I'm still trying to figure out what a halo cover is! It looks good, nice work!
Posted on: 2010/12/28 4:05
don't worry, you still have time to register Ultrawhips and Ultrachains.
Posted on: 2010/12/28 4:09
What did you do with the garment hook?
Good eye. Garment hook delete.
jpg  P1010002.JPG (136.68 KB)
1735_4d19655dcf76e.jpg 640X480 px
Posted on: 2010/12/28 4:19
pianoguy Re: Rehabbing the "halo" cover
Outstanding! Have I ever mentioned that you have waaaaaaaaaaaaaaay too much time on your hands? ;-)
Posted on: 2010/12/28 4:27
good idea. I like that. Lots!!!
Posted on: 2010/12/28 4:30
JeffK Re: Rehabbing the "halo" cover
High Point, NC
1440 Posts
That looks great! I was just thinking the other day that I wished there was a write up somewhere about wrapping those pieces.
Posted on: 2010/12/28 12:42
Joe, Do you think that would stretch over the corners of the console lid?
Posted on: 2010/12/28 13:56
Definitely. I tried with a scrap on a similarly shaped corner.
Here's a detail of the inside.
jpg  P1010001.JPG (135.69 KB)
1735_4d19fac2e37e6.jpg 640X480 px
Posted on: 2010/12/28 14:57
I might have to get some to play with. I was thinking about getting a cover when I order a shift boot from Redline but think that the ultraleather glued down may be better.
Posted on: 2010/12/28 15:04
Suggestion - when you put it back together, use stainless steel screws. It will look sweet against the black leather.
Posted on: 2010/12/28 18:40
That garment hook is a stunningly useless component ...
Posted on: 2010/12/29 2:47
After a near disaster on the left hand side, I managed to cover four pieces. I think I'll quit while I'm ahead.
jpg  P1010002.JPG (144.35 KB)
1735_4d1b40722817e.jpg 640X480 px
Posted on: 2010/12/29 14:07
That does look really good.
Are you using regular 3M spray adhesive?
Posted on: 2010/12/29 14:11
I used the "hi-strength 90". Coat both sides, heavier on the fabric to allow for absorbtion. I held the pieces upside down while covering and started from the end to minimize the risk of accidental contact.
I scrubbed the pieces in a TSP solution to clean.
Lightly sand, then I wiped them with some ketone which actually started to soften the surface. Whether that helped with adhesion or not, on an experimental piece, when I pulled the ultra leather off, some of the poly actually pulled off with it. It's a permanent bond, I believe.
Posted on: 2010/12/29 14:44
rklessdriver Re: Rehabbing the "halo" cover
That looks very nice.
I could have really used your skills back when I bought my Porsche 928...
Posted on: 2010/12/29 17:56
89Vette Re: Rehabbing the "halo" cover
135 Posts
I can't figure out their pricing. How much does $66 buy?
Could this stuff be used to cover door panels? (IOW how much curve stretch is present?)
Do you use a hair dryer or heat gun to stretch/mold?
Posted on: 2010/12/30 4:21
Looks to me like it would be for a yard but looking around, the prices are all over the place. One marine shop wants $88 plus a 5 yard min.
A good color chart.
http://www.gulffabrics.com/ultralht.htm
Some good reading:
http://www.hotrodders.com/forum/gsear ... raleather-67590.html#1185
I did a search and didn't come up with any vendors other than Joe's link.
But it's still interesting stuff.
I think it would work well on a door panel.
Posted on: 2010/12/30 13:51
1 Yard=36X47-54".
I think so. See photos. See posts 4&15.
I didn't use any heat.
The fabric backing is the limiting factor for stretch.
Posted on: 2010/12/30 13:58
VetteMed Re: Rehabbing the "halo" cover
Alachua, FL
37 Posts
Nice job... will have to keep this in mind for future projects.
Posted on: 2010/12/30 18:41
