186 user(s) are online (132 user(s) are browsing Forums)
PLRX Collector Edition LT4 Build Up
SoCal
212 Posts
I never posted my LT4 build up here. I now Pete K's threads are a monster compared to mine but, just to share with you Gurus.
Some wording may refer to "yesterday" and that is wrong refer to the date on the pictures. I'm copying and pasting from the thread I posted on other forum.
August 2008, after about 4 months of looking at it, planning and wondering if I wanted to do this project I went ahead and bought a 1996 LT4 Collector Edition Vette. I paid $3,500 and it was trashed. The engine was clean in the inside and that was the #1 reason I bought it.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT420.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT419.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT418.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT417.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT416.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT415.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT414.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT413.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT412.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT411.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT410.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT49.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT48.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT47.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT46.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT45.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT44.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT43.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT42.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT41.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT4.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/3500/CELT423.jpg[/IMG]
There are many steps I took that I wish I didnt, I'll go to the punch-line and the end of the LT4 rebuild.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02633.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02634.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02635.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Rebuild/LT4Rebuild3.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Rebuild/LT4Rebuild4.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Rebuild/LT4Rebuild5.jpg[/IMG]
Posted on: 2011/1/13 20:21
PLRX Re: Collector Edition LT4 Build Up
SoCal
212 Posts
This was my first time doing the whole thing. Took me couple of pistons to get the hang of it :D. Did the crank
and 4 pistons (Scat Crank and Rods with SRP pistons)
What you all think?:woowoo:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02648.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02651.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02652.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02654.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02655.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/DSC02658.jpg[/IMG]
Posted on: 2011/1/13 20:22
SoCal
212 Posts
Below
Posted on: 2011/1/13 20:24
SoCal
212 Posts
Scat rods, SRP pistons
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct1.jpg[/IMG]
GM Performance 12499225 lifters
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct9.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct6.jpg[/IMG]
:lol::lol::lol::lol:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct7.jpg[/IMG]
Torque down to manufacturer specs: 45 lbs ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct5.jpg[/IMG]
within specs :thumbs:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct4.jpg[/IMG]
LLoyd Elliot's LE2 from Ultradyne cams
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct10.jpg[/IMG]
My old friend "The Duck" water pump gear, install with special tool and torque to 106 lbs ft in
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct11.jpg[/IMG]
torque to 18 ft-lbs
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct12.jpg[/IMG]
got some play dough :o
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/11oct14.jpg[/IMG]
torque oil pump to 66 lbs ft and wind tray bolts to 30 lbs ft, screen is 3/8" from the oil pan, took it to the muffler shop and got it welded
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct12.jpg[/IMG]
apply oil to the main seal, install gasket and torque to 11 ft-lbs
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct122.jpg[/IMG]
applied silicone/RTV on all oil pan's corners
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct123.jpg[/IMG]
106 lbs in on center bolts and 15 lbs ft on corner bolts and studs
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct124.jpg[/IMG]
torque knock sensors to 15 lbs ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct125.jpg[/IMG]
install gasket and oil ring and torque oil filter adapter to 18 lbs ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct126.jpg[/IMG]
SoCal
212 Posts
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct14.jpg[/IMG]
Thread sealant
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct141.jpg[/IMG]
Torque to 65 ft lbs (22-45-65)
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct142.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct143.jpg[/IMG]
Posted on: 2011/1/13 20:25
SoCal
212 Posts
After a great C4 Yosemite Run and a harsh Monday at work I needed to relax and got busy.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/26Oct.jpg[/IMG]
Thread sealant :thumbs:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/26Oct1.jpg[/IMG]
Torque Rocker Studs to 50 lbs ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/26Oct2.jpg[/IMG]
Torque lifter tray to 18 lbs ft, hopefully I got the roller-rockers right :D
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/26Oct3.jpg[/IMG]
Torque oil and fuel pressure sensors to 106 lbs in
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/26Oct5.jpg[/IMG]
The oil pressure gauge torques to 106 lbs in but I grabbed the wrong torque wrench and OOOUCH :ack:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/26Oct4.jpg[/IMG]
Posted on: 2011/1/13 20:26
SoCal
212 Posts
Torque oil pressure gauge sensor to 106 lbs in
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct281.jpg[/IMG]
Now, ENSURE you install an oil filter before you prime the engine...
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct28.jpg[/IMG]
...If you don't something like this could happen to you. This is a photochop not like it happened to me :D :rolleyes:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct282.jpg[/IMG]
LT4 is now primed and ready for intake manifold
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct283.jpg[/IMG]
SoCal
212 Posts
More pictures, almost there :cheers::cheers:
Torque oil pump driveshaft bolt to 18 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct30.jpg[/IMG]
To install intake, clean all surfaces with brake cleaner or fast dry agent
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct301.jpg[/IMG]
I used 600 grit sand paper to help RTV adhere to the block and intake.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct302.jpg[/IMG]
RTV
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct303.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct304.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct305.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct306.jpg[/IMG]
Apply thread sealant to all intake bolts.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct307.jpg[/IMG]
First pass torque all bolts to 71 lb in. Use sequence illustrated in the FSM.
Second pass torque to 35 lb ft. I found all bolts adjusting until the fourth pass to 35 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct308.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct309.jpg[/IMG]
Install Opti and torque to 106 lb in.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3010.jpg[/IMG]
This is the bottom right water pump bolt. It is exposed to coolant.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3011.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3012.jpg[/IMG]
Torque water pump bolts to 33 lb ft and the thermostat housing to water pump to 89 lb in.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3013.jpg[/IMG]
Intake ported by Elliot Portworks :thumbs:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3014.jpg[/IMG]
Torque the crankshaft balancer hub bolt to hub to 74 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3015.jpg[/IMG]
Torque header bolts to 30 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3016.jpg[/IMG]
Torque throttle body bolts to 18 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3017.jpg[/IMG]
New TB plate :D.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3018.jpg[/IMG]
Torque EGR plate to 18 lb ft and engine coolant bleed pipe bolts to 30 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3019.jpg[/IMG]
Torque crankshaft balancer bolts to 63 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Oct3020.jpg[/IMG]
Posted on: 2011/1/13 20:27
SoCal
212 Posts
Installed the rack & pinion. Torque the main bolt to 30 lb ft and the clamp bolts to 18 lb ft. Torque the steering column bolt to 30 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1.jpg[/IMG]
Torque PS cooling bolts to 86 lb in. :rolleyes:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov11.jpg[/IMG]
[SIZE="3"]Get Ready-[/SIZE]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov12.jpg[/IMG]
[SIZE="4"]Get Set-[/SIZE]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov13.jpg[/IMG]
[SIZE="5"]Go [/SIZE]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14.jpg[/IMG]
[SIZE="5"]LT4 is back in :cheers: :thumbs: :cheers: :thumbs: [/SIZE]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov15.jpg[/IMG]
Don't let this pictures fool you. It not that easy, the engine doesn't just drop/fit in.
If this engine do not work or anything goes bad after all this time, work, cuts, chunks taken out of my hands and money I may go insane.:crazy::crazy::crazy::crazy:
Posted on: 2011/1/13 20:28
SoCal
212 Posts
[IMG]http://i275.photobucket.com/albums/jj290/plrx/PLRX%20LT4/Rebuild/LT4Builduppost.jpg[/IMG]
SoCal
212 Posts
So I ordered the 7777 gasket, removed the TB, AIR line and the intake. [B]Look[/B] the RTV or bolts thread sealant
were 7 days old and they were not totally dried.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov6.jpg[/IMG]
Now the path is clear :thumbs::thumbs::thumbs:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov61.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov62.jpg[/IMG]
Posted on: 2011/1/13 20:29
SoCal
212 Posts
Light coat of oil to ease up installation
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov7.jpg[/IMG]
Torque fuel rail to 89 lb in. These are FIC Bosch III injectors, no clips required.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov71.jpg[/IMG]
Connect PS line and install belt pulley. Torque bolt to 24 lb ft.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov72.jpg[/IMG]
ASR components up!
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov73.jpg[/IMG]
New LT4 TB plate
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov74.jpg[/IMG]
A/C and cooling are on place and to be connected tomorrow.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov75.jpg[/IMG]
SoCal
212 Posts
Clean the flywheel's surface with brake cleaner
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov8.jpg[/IMG]
Torque flywheel bolts to 74 ft lb
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov81.jpg[/IMG]
Torque pressure plate to flywheel to 30 ft lb. Use FSM tighten order.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov82.jpg[/IMG]
Torque the bellhousing to engine block to 37 ft lb
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov83.jpg[/IMG]
Tranny do not just "slide in"
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov84.jpg[/IMG]
Put tranny on the floor and slide it in sideways and back on the jack.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov85.jpg[/IMG]
SON of A BITCX. This sucker kicked my ***. Torque tranny bolts to 37 ft. lb. Use FSM tighten order.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov86.jpg[/IMG]
ZF Doc Beam Plates
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov87.jpg[/IMG]
Discard washers, torque tranny bolts to 37 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov88.jpg[/IMG]
Discard washers, torque axle bolts to 59 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov89.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov810.jpg[/IMG]
The last time I install the ZF it went into the clutch/pressure plate in less than a minute today, this sucker kicked my ass twice. I'm very tired. I need to by a lift :yesnod::yesnod:
SoCal
212 Posts
Magnaflows Catalyt Converters :thumbs:
The passenger side came with only one O2 stud and the exit pipe was too small. Took it to the local muffler shop and problem solved :cheers:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov9.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov91.jpg[/IMG]
Torque clutch master to 18 lb ft. Don't forget to bleed, instructions are to be found in the FSM, a total engineering failure.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov92.jpg[/IMG]
Install tranny cover plate, install starter and torque to 35 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov93.jpg[/IMG]
Torque O2 sensors to 30 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov94.jpg[/IMG]
Posted on: 2011/1/13 20:30
SoCal
212 Posts
Veterans Day so I took it easy. Day off , It is my day :flag: so worked on the Vette until 2:30 PM only :D
Magnaflow Performance Exhaust back on the Vette. [B]This is the most unfriendly "bolt-on" system[/B] I have seen for any car.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov11-1.jpg[/IMG]
Looks like this system was designed for an automatic. The O2 sensor plug was on the clutch master cylinder way. It was plugged and a new O2 sensor plug was installed.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov111.jpg[/IMG]
The new catalyst is not 100% "fit-in". Home made exhaust pipe bender. :thumbs:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov112.jpg[/IMG]
These bolts are one of the biggest PITA to remove and to install if you use the OEM catalyst. There was plenty of space to work there.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov113.jpg[/IMG]
ZF Doc beam plate touches the muffler hang bracket. Try using a pry bar but it did not move. I'll wait, gamble and hopefully it does not create lots of resonance.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov114.jpg[/IMG]
I'm done for the day. If you served and went into combat, I Salute You:flag::flag:
Posted on: 2011/1/13 20:31
SoCal
212 Posts
IT'S ALIVE
Yesterday received the ECM in the mail and this morning I didn't even got some. I went into the garage and got busy.
Got the TWS and filled up the ZF
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A1.jpg[/IMG]
Finished aligning the exhaust and torque the Magnaflow clamps to 50 lb ft. Now, don't come and torque your clamps to 50 lb ft,
they'll snap. Magnaflow's Performance Exhaust Clamps come with this package and instructions.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A2.jpg[/IMG]
Major set-back with the camber brace. Few of us know what a PITA it is to install well... I got it done AND-I forgot to install
the serpentine belt :cuss:cuss:cuss. It is on the floor, I'll get it done before alignmnet.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A3.jpg[/IMG]
PCM for Less.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A4.jpg[/IMG]
LT4 ready
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A5.jpg[/IMG]
Got some Chevron 91 + octane booster :D
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A6.jpg[/IMG]
That son of a bitch started right away :thumbs: Got it break in dle for 20 minutes 1,900~2,200~2,000 RPMS
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A7.jpg[/IMG]
Accelerator assistant
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A8.jpg[/IMG]
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov14A9.jpg[/IMG]
After 20 minutes, I stopped the engine. Checked the coolant, change the oil filter and all it's good.
Got to say this: The idle is smoother than before and it burns cleaner/smells less. The gddmt DMF is new and the sucker is
already making it's decease noises. It freaking scared me first, I thought it was coming from the engine.
Tomorrow I'm planning on finishing the suspension/front sway bar and will raise the rear maybe 1/4"~1/2". I'll do my best to take it for a spin.
Posted on: 2011/1/13 20:32
SoCal
212 Posts
Got the sway bar in. Torque to 40 lb ft at ride height
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1514.jpg[/IMG]
Something cane up to my mind. I forgot to tighten the engine mounts. Torque to 40 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1522.jpg[/IMG]
Torque wheels to 100 lb ft--On the floor.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1523.jpg[/IMG]
SoCal
212 Posts
A recap of the whole project
Beware, this torque specifications work for late C4 Vettes. Haynes manual says for 1988-1996.
Torque upper control arm to crossmember bolt to 37 lb ft
Upper shock bolt to 19 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1510.jpg[/IMG]
Torque new ball joint bolts to 13 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1511.jpg[/IMG]
This is a C5 brake kit upgrade.
Torque the kit bracket to the knuckle to 150~180 lb ft
Torque the C5 caliper bracket to C5 kit bracket to 125 lb ft
Torque caliper to caliper bracket to 25 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1512.jpg[/IMG]
Torque shock lower bolts to 22 lb ft
Sway bar to upper link nut to 35 at ride height
Sway bar to lower link nut/to lower control arm to 22~35
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1513.jpg[/IMG]
Sway bar to frame to 40 lb ft at ride height
Lower control arm to frame to 82 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1515.jpg[/IMG]
Monospring retainer bolt to 46 lb ft at ride height
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1516.jpg[/IMG]
Hub to bearing to knuuckle bolt and nut to 46 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1517.jpg[/IMG]
Upper ball joint to 33~63 lb ft
Lower ball joint to 55~88 lb ft
Tie rod to knuckle to 33 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1521.jpg[/IMG]
SoCal
212 Posts
Tie rod housing to differential to 55 lb ft
Spring to differential carrier bolt to 37 lb ft
Support rod bracket to differential carrier bolt to 47~62 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1518.jpg[/IMG]
Cam bolt to support rod to 187 lb ft
This is a VBP rod, torque to 70 lb ft
Muffler hanger bolt to 40 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov155.jpg[/IMG]
Support rod to knuckle 107 lb ft
Tie rod to 37 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1519.jpg[/IMG]
Shock stud to knuckle to 89 lb ft
Shock to stud 61 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov153.jpg[/IMG]
Control arms to chassis to 63 lb ft
Control arms to knuckle to 140 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov15-1.jpg[/IMG]
Upper shock bolts to 22 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov152.jpg[/IMG]
Sway bar to chassis to 18 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov1520.jpg[/IMG]
Spindle nut to 164 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov159.jpg[/IMG]
Wheel hub bolts to 66 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov157.jpg[/IMG]
Torque caliper mounting bracket to knuckle to 70 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Nov154.jpg[/IMG]
SoCal
212 Posts
First ride
Low quality short video
[URL=http://s275.photobucket.com/albums/jj290/plrx/CE%20LT4/?action=view¤t=Nov15M.flv][IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/th_Nov15M.jpg[/IMG][/URL]
Posted on: 2011/1/13 20:33
SoCal
212 Posts
Last Friday I tried to install the Camber Brace following it's instructions and it is a PITA to squeeze thru the accumulator.
In the process I broke the coolant temperature sensor. I had to drain the cooling system, yes I removed the
knock sensor...the whole enchilada. I was so mad that I threw the camber brace back in the box and I was going to forget about it.
On Sunday after I came back from the Death Valley Run in my 95 LT1 and later on that evening I jumped in the
LT4 and took it for a drive. I noticed how loose the front suspension is without the Camber Brace. I cooled down and was going
to give the Camber Brace one more try BUT-THEN-I realized...The A/C system is empty
Start by disconnecting the IAT, MAF, coolant temperature sensor and Opti vent hose line. Remove the air intake ducts.
On my case I disconnected and removed the accumulator.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem24.jpg[/IMG]
Remove the front upper control arms (wishbone) bolts
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem241.jpg[/IMG]
On the driver's side the bolt will hit the belt but if you play with the belt and wiggle the bolt it will come loose.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem242.jpg[/IMG]
Slide the camber brace (open ends facing down) thru the rad hose and once it is horizontal, twist the camber brace. see picture
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem243.jpg[/IMG]
Barely 1/8" from the water pump
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem244.jpg[/IMG]
Be extremely careful with the MAF and coolant temperature sensor, it wedges between the camber brace and the
water pump. The plastic shield will be squash:yesnod:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem245.jpg[/IMG]
Re-connect the accumulator and tight the camber brace. The camber brace is maybe 1/16" shorter that the space
between the upper control arms/crossmember frame. Using the supplied shims, place one between the camber
brace and the crossmember frame. In my case the factory bolt was not long enough, to secure the camber brace and
the upper control arm. Use camber brace's supplied longer bolts. The driver's side was long enough.
Torque upper control bolt to crossmember frame to 37 lb ft
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem246.jpg[/IMG]
Connect the air duct, the coolant temperature sensor, MAF, IAT and Opti's vent hose.
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem247.jpg[/IMG]
Drove it to work today and got it aligned :thumbs:
[IMG]http://i275.photobucket.com/albums/jj290/plrx/CE%20LT4/Novem25.jpg[/IMG]
There was a shop next door and got the A/C system charged with freon. [IMG]http://www.iconeasy.com/icon/thumbnails/Culture/Xtra%20Homes/Igloo%20Icon.jpg[/IMG]
285 miles into the engine breaking, 715 miles to go :cheers:
Happy Thanksgiving [IMG]http://www.meetingtomorrow.com/uploads/images/image/turkey-image.jpg[/IMG]
SoCal
212 Posts
SCAT 9000 Series Cast Steel Crankshaft
SCAT Sportsman I-Beam Rods
SRP Forged Piston Set – Inverted Dome
JE Piston Rings
Engine was externally balanced by Dougans Racing Engines in Riverside, CA
Balanced on a Hines Microcomputer Balancer
Intake and Heads: LE2, by Elliot Portworks
The heads flow 285 cfm at .600 lift on intake
and 193 cfm at .600 lift on exhaust.
-Valves:
Duration: 223 intake 230 exhaust
Lift: .565 intake .565 exhaust
Lobe Separation Angle (LSA): 112
-Combustion Chamber: 52cc[/INDENT]
MSD Opti and coil
Magnecor Spark Plug Wires
OEM flywheel, plate and clutch
B&M Shifter
Vortex Ram Air
1000 CFM MAF
58mm TB
Hooker Shorty Headers
Magnaflow Catalysts
C5 Front Brakes with drilled/slotted front and rear discs
Sway Bars: 32mm Front-26mm Rear
Tuned by PCM for Less
Compression: 11.1
No, I have not dynoed yet. But before the build up it made 306 RWHP in a Mainline Dyno.
pianoguy Re: Collector Edition LT4 Build Up
Outstanding thread, Pete!
Posted on: 2011/1/13 20:47
bogus Re: Collector Edition LT4 Build Up
You got a deal on that car. How many miles were on it before the rebuild?
Looks like you did a great job, and even with some of the errors, saved yourself a pot load of cash.
I did an engine out service summer of 09... did lots of things - clutch, seals, gaskets, degrease everything. I am sure I saved myself 1500 in labor, easily.
Posted on: 2011/1/13 20:57
SoCal
212 Posts
It had 69,000 miles
At an average of $80/labor yes, I save a bundle!
Posted on: 2011/1/14 1:01
Jeffvette Re: Collector Edition LT4 Build Up
Good job. Lots of work, but well worth it.
BTW, when I click on your images to look at a larger version, they don't come up.
Posted on: 2011/1/14 2:05
biggrizzly Re: Collector Edition LT4 Build Up
Pete,
Great documentation. I just don't have it in me to document every step of the way through my build like you have done. m Fabulous! I hope mine turns out as good as yours did.
Don
Posted on: 2011/1/14 3:54
Matatk Re: Collector Edition LT4 Build Up
This is a phenomenal write up with pics. I remember the build from the other forum and was following it with interest. I'm glad you took the time to post everything up here
Posted on: 2011/1/14 3:59
jonszr1 Re: Collector Edition LT4 Build Up
Lone Pine, CA
have you had a chance to take her to a chassis dyno to she what she makes ? you sure did a nice job on everything
Posted on: 2011/1/15 0:31
BillH Re: Collector Edition LT4 Build Up
Ditto, very nice work, Pete.
I like your fast idle cam, that's exactly what we use on the carbed racecars (no choke/fast idle).
The wet RTV, yea. I quit using RTV about 5 years ago on engines & gearboxes. All I use is the Right Stuff. I really like the way it works.
Posted on: 2011/1/15 1:24
SoCal
212 Posts
I wish I knew its a good product. I didnt buy it at the time because I didnt know anything about it.
Next time, my LT1 is at 107,000 miles. If I dont sell her, I'll do the same surgery + 4L60E rebuild on it.
Posted on: 2011/1/15 1:31
My suggestion would be to buy the RS in the tube that fits a caulk gun ( I can't stand the aerosol cans personally).
With the caulk tube, you have much better control of the bead. When finished, leave one inch hanging out. The next time you use it that dried inch will pull out nicely and you're ready to go. No nails, no digging around.
It's not cheap BTW. Probably $18 for the tube but that does a couple of motors easily/
I started using it on transaxles at the track when changing trans gear ratios. If I changed gears at the track using RTV, the box would always leak (not enough time to dry, like maybe one hour). The RS on a gearbox/engine oilpan can be driven immediately.
And no need to squeeze, wait to dry and torque like RTV.
RS is what the new car mgf's. use for the gasketless oilpans.
Cleans off a tad easier that RTV too.
Posted on: 2011/1/15 1:42
Raidmagic Re: Collector Edition LT4 Build Up
Florida
168 Posts
Great write up great job. That car was worth bringing back to life.
I have to admit though, you freaked me out with the normal hammer on the piston install. You got me. :D
Posted on: 2011/1/15 3:21
SoCal
212 Posts
Posted on: 2011/1/15 3:42
zoe6 Re: Collector Edition LT4 Build Up
Northern Indiana
167 Posts
Great documentation and commentary on your build Pete. Meticulous assembly. Outstanding!! Erin
Posted on: 2011/1/15 3:59
Owner of a great Vette! Totally stock ZO6
SoCal
212 Posts
I forgot to post the video clip
http://youtu.be/FiVjfH0mOi4
Posted on: 2011/1/15 4:49
Pod Re: Collector Edition LT4 Build Up
Columbia, Ms
44 Posts
Wow! outstanding job. Rebuild and patience to post process.
Posted on: 2011/1/16 13:30
87 white convertable, 383 stroker.
