209 user(s) are online (145 user(s) are browsing Forums)
Steve40th Did rear bearings and brakes, something weird on the right rear brake. Look
1114 Posts
My rear bearings were shot, as pics show as they were leaking grease. So, I put SKF rear bearings in. I also, did new teflon washer, greased brake guide pins, and greased the splines of the spindle to alleviate all noise. Wrong, after all was said and done, u joints need to be replaced.
Anyways, look at the right rear rotor. I painted the top hat, as it was silver and going to rust, with black caliper paint. Some bled over to the face of the rotor. But after bedding in the brakes, HPS Hawk pads, and 75 miles of driving, this is the wear pattern. Kinda missing about an inch of rotor it should be touching. Left side is fine, as all other rotors and pads. What do you think.
jpg  DSCF2516res.jpg (293.23 KB)
236_4d605aaf090e9.jpg 1668X1500 px
jpg  DSCF2506res.jpg (248.26 KB)
236_4d605ac20528b.jpg 1388X1104 px
jpg  DSCF2505222.jpg (451.53 KB)
236_4d605ad50185c.jpg 1476X1540 px
Posted on: 2011/2/20 0:05
Ko'u ohana aia ku'a ikaika
bogus Re: Did rear bearings and brakes, something weird on the right rear brake. Look
the pad wear is odd. It should be even across the rotor.
Make sure the pads are seated evenly, and the calipers are set in securely. If they are off a bit, that would explain a lot.
Posted on: 2011/2/20 0:49
Steve40th Re: Did rear bearings and brakes, something weird on the right rear brake. Look
1114 Posts
Well, I re-did them. Nothing was off and they pretty much only go one way.
Weird. I think the rotor wasnt cut right. Who knows.
Posted on: 2011/2/20 1:32
bam Re: Did rear bearings and brakes, something weird on the right rear brake. Look
missouri
250 Posts
This is funny, I have the exact same wear pattern on my 93 after I replaced the rear pads and rotors. The inside of the rotor is fine but the outside is just like yours, contacting on the top 1/2 only. I can even look at the pad next to the rotor and see a gap at the bottom of the pad. I was thinking my calipers are shot. Maybe the bearings (mine were shot on both sides) allowed the rotor to tilt in at the top and so the inside of the caliper where the pads sit is showing some resulting strange wear? Now that everything is new except the caliper, it is showing the bad wear pattern in the caliper. My car has 100,000+ mi. I also painted my calipers and got some paint on the inside where the pads sit but I took them back apart and scraped that area with a file and it changed nothing.
Posted on: 2011/2/20 1:51
1114 Posts
bam wrote:
This is funny, I have the exact same wear pattern on my 93 after I replaced the read pads and rotors. The inside of the rotor is fine but the outside is just like yours, contacting on the top 1/2 only. I can even look at the pad next to the rotor and see a gap at the bottom of the pad. I was thinking my calipers are shot. Maybe the bearings (mine were shot on both sides) allowed the rotor to tilt in at the top and so the inside of the caliper is worn more on the top outside? Now that everything is new except the caliper, it is showing the bad wear pattern in the caliper. My car has 100,000+ mi.
Weird, How can a caliper not keep things flat?
bearings are brand new.
Posted on: 2011/2/20 1:55
missouri
250 Posts
The caliper when it is new is perfectly aligned so that both of the sides are parallel where the pads sit, maybe it's possible for that to wear strangely when the rotor is not perfectly perpendicular since the bearing is allowing the rotor to move in at the top relative to the mounting of the caliper to the suspension, make sense? Just a guess, I can't imagine what else it could be. I am going to borrow a mike from a friend and check the two surfaces to see if the are parallel.
Posted on: 2011/2/20 2:02
1114 Posts
Cool, let us know the results
Posted on: 2011/2/20 2:48
Matatk Re: Did rear bearings and brakes, something weird on the right rear brake. Look
I'm wondering if the caliper piston is hanging up inside the bore. Can you somehow mic it with a mic stand and see how far it is compressing? Or visually inspect it?
Also, are you sure the rotor is 100% level/flat or that the pad is the same thickness throughout?
Posted on: 2011/2/20 16:30
1114 Posts
The piston went in fine when I compressed it to allow the pads to fit.
The rotor I did not check. They are Raybestos, and new. You can see they were cut. That doesnt mean they are done right though. We'll see what it looks like after a few hundred miles.
Posted on: 2011/2/20 17:10
flyboy Re: Did rear bearings and brakes, something weird on the right rear brake. Look
I didn't think new rotors needed to be cut.
Posted on: 2011/2/20 17:13
I think he meant from the factory.
But just because it's a new part, doesn't mean it's always good or in spec....unfortunately.
Can you mic the pads, too, and see if they are the same thickness?
Posted on: 2011/2/20 17:20
1114 Posts
I could have, but, since they are already on, and wearing, I cant.
They are Hawk pads, pretty good company.
Posted on: 2011/2/20 17:21
RestoMod57 Re: Did rear bearings and brakes, something weird on the right rear brake. Look
Phoenix, AZ
55 Posts
I used to recommend to customers that new rotors be cut, but only with a computerized on-the-car lathe. Two reasons, the quality of some rotors was sub-standard (especially Chinese produced ones), and secondly the on-car lathe matches the cut to the hub and its wobbles.
Posted on: 2011/2/20 17:47
jaa1992 Re: Did rear bearings and brakes, something weird on the right rear brake. Look
Stone Mtn, GA (near Atlanta)
187 Posts
Caliper spread maybe? Caused by the wobbly bearing?
Try a rebuilt caliper on that side?
Check the mount as well.
Posted on: 2011/2/21 19:35
1114 Posts
If the aluminum caliper is spread, I think it would be cracked or show signs of wear. I just cant see aluminum forged calipers bending. Not that its impossible,
Posted on: 2011/2/21 19:38
1114 Posts
Okay, I went out and took the right rear brakes apart. Nothing unusual popped up. I then redid the break in of the pads procedure, and it still is the same.
The pad was wearing, and you can see it is now not flat as it was when new. So unless I re cut the rotor, it will eventually start wearing onto the rotor.
I plan on flushing the brakes in a week or so, so I may take the rotor off and recut it. Couldn't hurt to see if that is the problem.
Posted on: 2011/2/21 22:38
Churchkey Re: Did rear bearings and brakes, something weird on the right rear brake. Look
69 Posts
After machining a kazillion rotors I can tell you that it is impossible to machine a rotor on a rotor lathe so that the brake surface is at an angle to the hub surface. If the rotor was mounted improperly on the rotor lathe the rotor will wobble (laymans defination of run out) when installed on the hub. The result is a pulsating brake pedal. If you have access to a dial indicator use it to determine if the rotor is running true.
IMHO the caliper is/has spread or the pads are not seated/installed properly in the caliper housing or the caliper is not installed properly on the upright. Perhaps some trash/junk between the caliper & upright
Posted on: 2011/2/21 23:22
1114 Posts
Okay. Not the rotor then. I will check it with a dial indicator when I do the brake flush.
Pads really arent rocket science. They fit right in and really cant be installed wrong on the rear Vettes calipers. I mean, you would have to go out of your way to put them in wrong. And it is pretty tight with new pads and rotors.So, no wiggle room.
How the heck can a caliper just all of a sudden spread, after 144000 miles. Wasnt doing this with the other pads and rotors.
Posted on: 2011/2/21 23:27
CentralCoaster Re: Did rear bearings and brakes, something weird on the right rear brake. Look
What does the backside of the rotor look like?
If its the same then yeah, I guess it'd have to be a spread caliper. Although even with that I would expect the pad to still lay flat on the rotor though, and to be not flush against the piston.
The caliper could have been spread previously but the pads eventually wore to compensate. What do the old pads look like?
Posted on: 2011/2/22 1:21
1114 Posts
The back side is fine, as is the left rear caliper as both sides are perfect.
If it is a spread caliper, who is to say anything I buy wasnt bad before being "remanufactured" I guess new is the only way to get a caliper.
Posted on: 2011/2/22 1:30
Reman is only as good as the shop doing the work. If it's an ac delco reman it was probably done in china or mexico. You'd think checking for spread would be part of the process.
Posted on: 2011/2/22 1:40
Calm Re: Did rear bearings and brakes, something weird on the right rear brake. Look
Vancouver, Canada
608 Posts
You would think the measurement specs for caliper spread (and measurement points) would be published somewhere on the net?
Posted on: 2011/2/22 1:43
1114 Posts
Choices out here are cardone and bendix.
rock auto has ac delco, but with shipping back and forth, its not worth the cost.
I am going to email DRM and see if they have any suggestions, especially measurements
Posted on: 2011/2/22 1:51
biggrizzly Re: Did rear bearings and brakes, something weird on the right rear brake. Look
I have been following this thread with interest and don't want to add anything to confuse the subject, as I'm not real knowledgeable about brakes. However, since my wheels are off I went down and looked at my contact area. Mine contact area only looks a pinch wider than yours but starts closer to the outside of the rotor and leaves about a half inch or so of no contact on the inside. I just thougth I post this rusted ugly photo for some comparison.
jpg  IMG_1349.jpg (84.83 KB)
342_4d6318bb6b282.jpg 1024X768 px
Posted on: 2011/2/22 2:03
1114 Posts
How is it compared to the other side?
Posted on: 2011/2/22 2:06
Looks the same on the rear. Other side the same.
jpg  IMG_1362.jpg (37.47 KB)
342_4d631db279f56.jpg 1024X768 px
Posted on: 2011/2/22 2:22
1114 Posts
Interesting. I emailed DRM, as they have always been very helpful on my C4 questions. Maybe they can enlighten us on measurements of a known good caliper.
I am sure that I wont get a bad caliper from a parts store, LOL.
But, it would be nice to know if I end up going there.
Posted on: 2011/2/22 2:27
I know this is a silly question, but are the dia. of your rotors to specification and the diameter of the hats?
Posted on: 2011/2/22 2:35
1114 Posts
Yep, I put them up to the old ones. But, being the silly guy I am , I threw the old ones away as they were too thin to cut one more time.
Posted on: 2011/2/22 2:37
Phoenix, AZ
55 Posts
This may be grasping at straws, but have you checked to make sure each caliper has correct inner and outer pads?
The inner pads should have the wear tab indicator on them. And the tab should be closest to the abutment bracket (holds the e-brake cable).
Also measure the pads when installed for parallel. Measure one side then the other. The difference should be no more than 0.15mm. Then measure top to bottom. This seems like where your problem may be.
The picture of your wear says it's probably something other than mis-installed inner and outer pads - but at least you'll eliminate this possibility. Just trying to help.
Posted on: 2011/2/22 15:54
1114 Posts
I did verify the pads were on the right side. The wear indicators were on the inside.
Whats strange is its only that pad, as the other three on the rear are fine.
And when you ask to measure them, is this sliding a feeler gauge in from left to right to verify how far the pad is off the rotor?
Posted on: 2011/2/22 16:00
BillH Re: Did rear bearings and brakes, something weird on the right rear brake. Look
Yea, that really needs to be done. And the rotors need to be measured.
Ckeching for caliper spread is going to be tough because you can only measure the rough casting. And if the calipers are spreading under pressure and returning when you let off, no way to really tell.
IF, the pistons are cocking in the bore, you may get an idea of how much by applying the brakes hard when stopped, then remove the caliper very carefully from the disc without moving the pistons. Chect the top and bottom of the piston surface where it contacts the pad with a snap gage. But, it still might not show much.
if the caliper is cocked in any way, the wear pattern on the front of the disc should be in a different location from the rear surface.
Posted on: 2011/2/22 16:05
Phoenix, AZ
55 Posts
Use a caliper to measure between the friction surfaces of the pads. This shows any taper to the pads. Your taper looks pretty radical from top to botton of the pad surface.
By top to bottom I mean from the caliper valley to the open side.
The explanation for this seems to be something other than the taper of the pads, but again, it's something you can eliminate.
Posted on: 2011/2/22 16:10
I'll assume here but, I think Resto's talking about using a mic with the pads out of the caliper.
And you need to pull the good pads $ measure for reference.
It's always possible that you have a bad pad.
How many miles on them, just break in?
Posted on: 2011/2/22 16:11
Yea, that makes sense.
Posted on: 2011/2/22 16:12
1114 Posts
They were broke in and immediately looked like that.
They now have 70 miles on them, half way around my third world world country of Oahu. When I took them out yesteday, the outside pad was already worn. So, it is not flat anymore. The inner pad was flat.
Posted on: 2011/2/22 16:14
Good, that's not enough to screw up the measurements.
I'd do what Resto said and then pull the pads & mic then compare those measurements to the set of another wheel.
Good luck.
Posted on: 2011/2/22 16:19
1114 Posts
Good luck.
Might be a week or so. Next time I take these off is when I flush the brakes. I also want to have another caliper on hand.
Posted on: 2011/2/22 16:34
Different situation, your pads don't even cover that part of the rotor.
Why GM put a friction surface where there's no pads is beyond me. They did the same on the C5. Won't hurt anything though.
Posted on: 2011/2/22 20:57
1114 Posts
Should the wear indicator be closest to the ground then? The front wear is supposed to be on the trailing end of the caliper on the inside.
Posted on: 2011/2/22 21:02
Phoenix, AZ
55 Posts
Sorry Steve, I looked at mine (off the car, actually not installed yet), and the inner pad's wear tab is at the rear of the caliper when on the car. For left and right calipers, that's the only way the pads fit.
So the wear tab is closest to the e-brake lever (with spring). My brakes are from a 1995.
The picture here shows where taper is measured, in between the pads when they are installed. Measure both left and right. The difference should not be more than 0.15mm. But since you have driven on your pads, they may have already worn enough to make the margin bigger.
CC may be correct in that the pad surface may not be engineered to contact the entire rotor, BUT when I removed the old pads and rotors, a complete contact patch was evident.
My pads are Raybestos and model specific. Hawk should be the same though.
Hope this helps,
Steve M.
jpg  Guru_rear caliper_left.jpg (288.11 KB)
2124_4d642958a95e6.jpg 1602X1520 px
Posted on: 2011/2/22 21:24
Hope this helps,
Steve M.
Yea, you should be getting full contact, the same width as the pad with a 1/16 to 1/8th "edge" on the outside edge of the rotor where the pads don't make contact.
My Hawks show contact on the full width of the pad.
Posted on: 2011/2/22 21:32
Phoenix, AZ
55 Posts
You might also check to see if your outer pad is completely seated in the bracket. The hairpin spring should protrude through the caliper opening. Pic attached.
If it's your outside pad that's wearing incorrectly, it may also be your slide pins. Did you say you disassembled the caliper and greased them?
jpg  Guru_rear left caliper_top.jpg (312.21 KB)
2124_4d642c1d786df.jpg 1500X1043 px
Posted on: 2011/2/22 21:35
1114 Posts
I greased the slide pins. And the springs for the pad is correct.
DRM emailed me and said if the caliper ever gets hot, it fatigues and eventually is junk, and spreads.
Well, I remember a couple years ago, I had a shop do something to the car, and when I left the shop I smelt brake pads. I was on a flat road barely a couple miles away. Well, they applied the ebrake, and the indicator light was not on. Long story short, pad was on fire. When I realized it, all I could do is release the brake and drive till the fire went out and cooled off. That may have been my overheating situation. What do you think?
Posted on: 2011/2/22 21:43
Phoenix, AZ
55 Posts
On fire? Yes, that would heat up the aluminum caliper nicely and could cause the spread. If one side heated up from the e-brake, the other side did too, just not to the point of catching fire.
Sorry to bring the bad news. Maybe other Gurus have better advice. Mine is to replace calipers.
Posted on: 2011/2/22 21:51
1114 Posts
The other side was fine, no fire.
But, I am working with someone to get calipers. I will at least do one.
I cant believe I forgot about the little fire years ago. Damn I am getting oldheimers..
Posted on: 2011/2/22 21:55
1114 Posts
UPDATE: I may have fixed it. Something kept telling me the fire wasnt very much and nothing really burnt, it was just the pad.
So, I took the wheel off, asked someone to push the pedal and I watched the pad. It kept rocking, not going in flat. So, I took it apart. I found this, the anit rattle plate wash damaged. If you look close you will see a shiny part on the right, it actually is bent up there and causing, IMHO, the pad to not go flat.
So, I took it out, and did a break in procedure, again, And within a mile, look at the difference.
First pick is now, compared to the one above. Looks much better. Now I need to drive it and see if the pad gets flatter in there. I think it will. What do you think?
jpg  DSCF2534.JPG (608.93 KB)
236_4d646fff542e2.jpg 1600X1200 px
jpg  DSCF2539.JPG (600.06 KB)
236_4d64703d08e06.jpg 1600X1200 px
236_4d6470a989c1c.jpg 1668X1500 px
Posted on: 2011/2/23 2:28
Phoenix, AZ
55 Posts
Something had to be jacking that pad around is a radical way. I believe you found the culprit. Good work.
Definitely check the wear of the pads and contact patch on the rotor in the next 50-100 miles. I wouldn't go any longer than that before doing an extensive check.
The great brake mystery is solved!
Posted on: 2011/2/23 2:42
Look at the picture, it's obvious.
Posted on: 2011/2/23 5:02
187 Posts
Nope, they spread without any visible signs
I don't have one off the car or I could do some measurements.
Read the rest of the thread - yea, the bad anti-rattle plate messd up the pad alignment. I don't use them anyway
Posted on: 2011/2/23 14:13
