310 user(s) are online (267 user(s) are browsing Forums)
biggrizzly Caliper Mounting Bracket Bolts
While reading my wonderful FSM tonight (light reading), I noticed that is says to NOT reuse the caliper mounting bracket bolts. Good grief, I see our guys changing rotors frequently and I have never seen them swap bolts. I did the last time because I replaced the bracket and caliper with the new GS units.
How many of you gurus change bolts every time? It also says to torque them to 165ft.lbs -- pretty stout.
Posted on: 2011/2/25 1:59
Matatk Re: Caliper Mounting Bracket Bolts
When I did my upgrade, Jeff provided new bolts for his adapters to mount to the car but I don't remember if there were new abutment bracket bolts. If not, I reused the stock ones and I have no problem with that.
Posted on: 2011/2/25 2:08
donhall Re: Caliper Mounting Bracket Bolts
297 Posts
Precautionary statement......
Brake components can crystallize from excessive heat caused by continuos hard braking conditions. That is when you toss the bolts.
Posted on: 2011/2/25 2:35
josephf31 Re: Caliper Mounting Bracket Bolts
New Jersey
375 Posts
I remember seeing that too, and only changed them because they were probably close to 20 years old...but I've never changed them on any other vehicle.
Posted on: 2011/2/25 4:23
mseven Re: Caliper Mounting Bracket Bolts
Motor City Madhouse
247 Posts
I've re-used front and rears a couple times now (w/lock-tite).
Posted on: 2011/2/25 12:39
SpectatorRacing Re: Caliper Mounting Bracket Bolts
I have never replaced mine, perhaps I should...
Posted on: 2011/2/25 12:54
jaa1992 Re: Caliper Mounting Bracket Bolts
Stone Mtn, GA (near Atlanta)
187 Posts
Agreed, and mine have been off a lot less times than yours
I clean them up and re-use. I get em torqued close to the 165 number.
Posted on: 2011/2/25 13:17
BillH Re: Caliper Mounting Bracket Bolts
Caliper bolts or caliper bracket bolts, Don? You don't need to mess with the brackets when you change rotors.
Posted on: 2011/2/25 13:53
flyboy Re: Caliper Mounting Bracket Bolts
BillH wrote:
[quote]
That is good to know.
Posted on: 2011/2/25 14:23
bogus Re: Caliper Mounting Bracket Bolts
Yea, but let's be realistic here, at what threshold of abuse does this apply? Normal braking may result in 800~1000F, track braking will result in upwards of 1500F, but how much of that is needed before this crystallization occurs? That sounds like a lot.
I am thinking more along the lines of the torque rating to tighten the bolt may distort the threads, so the next time you torque it, 165ftlbs isn't enough.
Perhaps threadlock will fix that, but perhaps not.
It does partially explain why a bolt could back out, tho...
I am still debating my next brake upgrade... but I am leaning heavly toward a C5 upgrade. I currently have the GS upgrade. Those calipers have about 115k miles on them. This means I either replace or rebuild at this juncture. Overall, the last brake job was done in 2005. I last bled them in 2009 (when I did the engine out). I know the rear brakes need attention; they haven't been touched since the GS brakes went on in 2001!
It was fall of 2001 that Jeff @ Superior Chevy did the GS group purchase. 2 calipers, 2 rotors, 2 brackets, pins, bolts all for $440, shipped. What a steal that was.
Posted on: 2011/2/25 18:04
biggrizzly Re: Caliper Mounting Bracket Bolts
That was a steal! Mine are in pretty good shape, but I haven't driven my car much in the past couple years!
If I were to do something different and had lots of money and time to throw at it, I think it would be cool to do the C6 Z06 upgrade. I have been following the C6 Z06 upgrade thread over on CF and it looks interesting. A bit pricey, but very cool.
Posted on: 2011/2/25 18:10
Jeffvette Re: Caliper Mounting Bracket Bolts
Considering they come with threadlocker on the threads is why it says to replace them. Can't trust a tech to clean a bolt and put the correct threadlocker on them. Takes less time, almost idiot proof (still have to use a TQ wrench).
Has nothing to do with heat stress.
Posted on: 2011/3/1 5:16
Am I doing something wrong? I can see no way to remove the rotors without first removing the caliper brackets.
jpg  P1010002.JPG (118.29 KB)
1735_4d7031aa82916.jpg 640X480 px
Posted on: 2011/3/4 0:26
Agreed. I ran into this the other night too. I'm gonna take mine off to clean and repaint sometime in the next couple weeks. Yours is very clean!!
Posted on: 2011/3/4 0:36
The last brake job I did on a guys C4 was 4 years ago. I could have sworn that I didn't remove the brackets.
Maybe I was smokin' crack.
Posted on: 2011/3/4 13:41
The racer guys in my club just pull the whole caliper and bracket as an assembly when only changing rotors if the pads have good mileage left on them. I was watching my friend Pat change out to some nice Brembo rotors the other night to get ready for an upcoming HPDE. It took him hardly no time to replace all four rotors.
Posted on: 2011/3/4 13:46
Why I like racecars on the track instead of street cars: Rotors on my racecar - 15 years.
Rotors on the FE in my avatar - 3 - 4 years of abuse.
Posted on: 2011/3/4 13:57
Yeah.. these guys are always changing rotors and pads to go to HPDEs. Most of them like running CarboTechs on the track but won't put up with the squealing for daily driving. Plus some have matched track rotors and pads and a set of DD rotors and pads. That is too much of a hassle me thinks.
Posted on: 2011/3/4 14:01
The C5/6 guys that drive hard are only getting 2 events out of the std. rotors, that's nuts IMO. But, to each his own.
Posted on: 2011/3/4 14:06
So I guess it's not necessary to replace the bolt every time you remove if there aren't any issues and they are prepped properly, but the factory says to do so just to cover their a**? They sure look stout enough.
Posted on: 2011/3/4 14:16
