JeffK | Where can I buy this sensor connector? | ||
I need a new plug that goes on the brake master cylinder. Mine is F'd. It's the one with only one wire going to it, Black/red wire plugs into the white sensor on the master.
Any ideas? I would try calling the Chevy garage here but they aren't that sharp and I would spend an hour on the phone trying to explain what I'm looking for. I looked on MAM and Zip websites with no luck. |
Posted on: 2011/3/21 12:56
bogus | Re: Where can I buy this sensor connector? | ||
Our best friend, dude... Chris May at Superior Chevy, 1.800.728.8267, tell him I sent you.
Posted on: 2011/3/21 13:35
biggrizzly | Re: Where can I buy this sensor connector? | ||
Try this. I have bought lots of stuff from them.
Also - RockAuto has lots of good electrical stuff too. http://www.eficonnection.com/eficonnection/default.aspx HTH |
Posted on: 2011/3/21 13:36
JeffK | Re: Where can I buy this sensor connector? | ||
Are they on your side of the country? Just trying to figure out what Time zone they're in. |
Posted on: 2011/3/21 13:39
Kansas... in da middle, yo. Central time. Give him another hour.
Rockauto is another good choice. |
Posted on: 2011/3/21 13:42
Couldn't find it on Rockauto. That other site that you posted is great Don. I saved that one.
I will call Chris sometime today. |
Posted on: 2011/3/21 13:50
RockAuto is a Registered Vendor here...
We get discount codes from them from time to time. Check the RockAuto sticky in Corvette Chat. |
Posted on: 2011/3/21 14:30
I have a rather nice collection of their magnets that they send in each box. Didn't get a chance to call Chris yesterday. |
Posted on: 2011/3/22 12:22
Called Superior..discontinued part of course.
GM # 12117268 AC Delco # pt441 Can't find them anywhere..even Googled, Amazon, Ebay. |
Posted on: 2011/3/22 22:16
pianoguy | Re: Where can I buy this sensor connector? | ||
How about vette2vette?
Posted on: 2011/3/22 22:28
They gave me no love either. Said that they would not cut up a wiring harness.
Posted on: 2011/3/22 22:30
Anybody parting out a car on CF?
Posted on: 2011/3/22 22:31
Is it a unique part to the Corvette? If not, maybe a U-pull-it yard would have another GM car with the same.
Posted on: 2011/3/22 22:33
I just posted a WTB thread over there.
If they hadn't molded the rubber around the wire I would be able to kind of fix it. |
You and I think alike..84-96 Corvette only. |
Posted on: 2011/3/22 22:34
Posted on: 2011/3/22 22:49
The center piece is actually rubber but it seems like it's sealed or molded to the wire. |
Posted on: 2011/3/22 22:52
Is the rubber part boogered up, or just the plastic around it?
Posted on: 2011/3/22 23:01
Andy... I have tried for a week to get a discount code for Rock Auto. I searched Google and put at least 15 codes into my shopping cart with no luck. I also PM RockAuto from here yesterday and haven't heard from them yet. I have an order to place for motor mounts and some other stuff needed to install my engine. If you could grease the skids on a discount code that would be cool. I really need to place this order yesterday and the code would help with the shipping since they charge separate ship charges for every part if they are being drop shipped by sub-shippers. My shipping charge was nearly $40 for six items. Any discount helps |
Posted on: 2011/3/22 23:04
Thread jacker! Just kidding Don, did you try the one that I posted in the Rockauto thread?
The metal barrels came out.. it's hard to explain without pictures. But up in that connector there are 2 round metal female connectors that slide over the male connectors on the white level sensor. Both of the female pieces of mine remain on the males which means that the wire that's supposed to be attached to one of them is no longer. |
Posted on: 2011/3/22 23:13
Gotcha.
Posted on: 2011/3/22 23:15
I'm thinking that I will cut the wire off close to the rubber and then dig out the hole, shove the cut end through and try to solder the wire fast to the female...not sure when I'll have time but one day..
Posted on: 2011/3/22 23:18
rayquayle | Re: Where can I buy this sensor connector? | ||
Don, Try this - 48009412109501 will expire on March 27, 2011.
Posted on: 2011/3/22 23:21
Ray Quayle in England '86 Indy PaceCar, 4+3 NCM Founder #2896 NCM Lifetime #672 Graduate of Gordon's School |
captmike13 | Re: Where can I buy this sensor connector? | ||
Try this place out.
They may have the connector but not labeled as such. They carry the weather pack connectors. |
Posted on: 2011/3/22 23:51
that site is awesome too. They don't seem to have the one that I'm looking for but I could have saved like $20 on MAP, IAC, TPS, temp sensor connectors that I bought of Ebay. |
Posted on: 2011/3/22 23:57
Sorry for the thread hijack.... crap, I hate when that happens!! Ray... My Bad.... That code worked fine. I was entering the code into field for "discounts" Dah! I then saw the message at the top of the screen that said to enter it into the box that asks "Where did you here about RockAuto?" Once again sorry for the topic detour. |
It's all good!! I'm glad you got it worked out. |
Posted on: 2011/3/22 23:59
85RedSled | Re: Where can I buy this sensor connector? | ||
Posted on: 2011/4/5 19:56
1985 4+3 Coupe, Bright Write me a ticket RED |
I am asking again... last time, it fell on deaf ears. Odd. |
Posted on: 2011/4/5 20:01
I have one coming from Steve (Raidmagic) thank you for thinking of posting it here. |
Posted on: 2011/4/5 20:08
joeld | Re: Where can I buy this sensor connector? | ||
Hey Jeff, do you have the part # for that connector end? I need the one for my 89.
Thanks Joel |
Posted on: 2011/4/6 0:29
1989 Coupe,L98 automatic |
I ended up getting with Raidmagic and he had a good one on a parts car. I had no luck finding them any other way. |
Posted on: 2011/4/6 0:52
Excellent - Gurus to the rescue ;-)
Posted on: 2011/4/6 1:44
oops! I just caught that. I was trying to multi-task with a single task brain. Thanks Joel |
Posted on: 2011/4/6 1:48
Matatk | Re: Where can I buy this sensor connector? | ||
GM 12117268. AC Delco PT441. I believe it's discontinued, good luck. |
Posted on: 2011/4/6 2:42
Raidmagic | Re: Where can I buy this sensor connector? | ||
Yep, I've got it sitting next to me, hopefully I can make it to the post office today. |
Posted on: 2011/4/6 15:32
Cool! Hopefully there was only one postmaster who needed the same part. Ha-ha
Posted on: 2011/4/6 16:01
SpectatorRacing | Re: Where can I buy this sensor connector? | ||
What's this connector for, low fluid warning? Do you really need it?
Just a thought. |
Posted on: 2011/4/6 18:38
aka Scaryfast |
If it doesn't make contact the Service ABS light comes on. Atleast that's what is causing mine to light
Posted on: 2011/4/6 18:56
Have you tried taking the sensor off another car, putting in that master, and installing the associated connentor?
Posted on: 2011/4/7 6:44
That is a good idea Andy.
Posted on: 2011/4/7 11:00
