biggrizzly | Exhaust options? | ||
OK... I know that Brad and some others have changed exhaust systems to go back to a more tame sound. Either in the past year I have become an old fuddy-duddy or this 383 exhaust combo is definitely louder and has mucho worse harmonic drone. I currently have the 3" Maganaflow Cat Back and its just too loud for my wife.
I have a factory resonator left over and the pipes that go rearward from there, however I have no factory mufflers. I gave them away a while back. What did you guys do to meet a happy medium between sound quality and performance. Also, I have no plans for Corsa, I'd like to just find a good quiet muffler to stick on here behind the resonator if I can fit all that under there. |
Posted on: 2011/6/11 19:19
tjpreul | Re: Exhaust options? | ||
Here is a used factory one, be sure to check shipping. You could sell yours to make up the cost. Bose also makes headphones for planes. A set of those may work too.
http://cgi.ebay.com/ebaymotors/92-96- ... uckQ5fPartsQ5fAccessories |
Posted on: 2011/6/11 21:48
Matatk | Re: Exhaust options? | ||
I'm going to the factory lt exhaust, Don. Same boat, my magnaflows are too loud with too much drone. I got mine from a fella on CF for cheap.
Matthew |
Posted on: 2011/6/11 23:39
1Fast04Vert | Re: Exhaust options? | ||
Don, I might be shopping for a 3" Magnaflow cat back, but it will be a while before I am sure. Keep me in mind if you decide to sell what you have.
Posted on: 2011/6/12 0:56
Ultraman | Re: Exhaust options? | ||
NAPA Sound Masters for my 90. No drone, inexpensive. Maybe they make them for an LT set up.
Posted on: 2011/6/12 1:25
pianoguy | Re: Exhaust options? | ||
Baffles might be another option - I have seen some cone-shaped ones that can be installed inside the pipes.
Posted on: 2011/6/12 1:34
bogus | Re: Exhaust options? | ||
x-pipes might help...
However, to my (very sensitive) hearing, Corsa is the best. I know, it's expensive as hell, but it does work well. @Marc - Just so you know, what works on an L98 may not help an LT1. The exhaust configuration is seriously different. |
Posted on: 2011/6/12 2:04
rklessdriver | Re: Exhaust options? | ||
Have you tried to plug one of the muffler outlets?
I remember back a few years ago on CF a guy figured out that it quited down his Magnaflow and got rid of the drone... I would suggest a simple expandable rubber freeze plug - if you can find one that will fit the exhaust tip. Easy to uncork it for the track and cork it back up for the ride to and from. Will |
Posted on: 2011/6/12 2:06
biggrizzly | Re: Exhaust options? | ||
I got an X-Pipe, The 383 is really louder. |
Posted on: 2011/6/12 2:07
I found the thread.
http://forums.corvetteforum.com/c4-te ... ltered-my-magnaflows.html Dude there used steel wool to block off one outlet per muffler - but I think just a rubber freeze plug in the tip would be easier. Will |
Posted on: 2011/6/12 2:23
Yeah that's what I figured. thanks...... |
Posted on: 2011/6/12 3:05
jonszr1 | Re: Exhaust options? | ||
i tried the cone shaped baffles and they really didnt change the sound at all just lightened my wallet by a cnote .if you are going to use a resonator get the one off a 96 its a true 23/4 in one .the other years neck down to either 21/4 or 21/2.you could most likely build a really nice system for around 400. use the 23/4 in exhaust pipe, and intead of an xpipe put in a balance tube. i just put one on at a buddies suggestion and the car is a lot quieter .it really freeked out a modded neon that tried me on for size . couldnt believe that i pulled him by 5 cars from 50 to 110. he just knew he would beat me as the car was so quiet .hehe. it seems that the xpipe promotes drone a little on this chassis . i need to go to the strip next weekend and see what effects it has on performance , you can get 21/2 in super turbo muffler and she will be almost as quiet as stk but make some decent power . you really don't need a resonator if you use the crossover . lastly the 96 lt4 cars had a balance tube that was installed behind the rearend . gm found that it quieted down the car a bunch. hope this helps a little . what is your rear wheel hp????/
Posted on: 2011/6/12 5:08
flyboy | Re: Exhaust options? | ||
Here's an interesting link on exhaust science. Seems relevant for an Lt1 setup, also.http://www.superchevy.com/technical/e ... st/0505phr_exh/index.html
Posted on: 2011/6/12 13:31
