111 user(s) are online (71 user(s) are browsing Forums)
1st Gear: 2.48
2nd Gear: 1.48
- 13 Bolt ...
mistaben what do I put on the threads of the exhaust manifold bolts?
141 Posts
what are you suppose to put on the threads for the exhaust manifold bolts?
also, if the gaskets only have like 50 miles on them, can I just reuse the old ones?
thanks guys!
Posted on: 2011/8/17 5:34
bogus Re: what do I put on the threads of the exhaust manifold bolts?
I don't put anything on them... anti seize will screw up the torque rating...
As for the gaskets? Reuse'm... should be fine.
Posted on: 2011/8/17 5:38
istter1 Re: what do I put on the threads of the exhaust manifold bolts?
Bakersfield Ca
2336 Posts
Don't use anti-seize compound.
Steve
Posted on: 2011/8/17 5:43
Carol Burnett
Bakersfield Ca
2336 Posts
Oops sorry Andy. What are you still doing up?
Steve
Posted on: 2011/8/17 5:46
mistaben Re: what do I put on the threads of the exhaust manifold bolts?
141 Posts
fsm says about 19lb-ft for stock. afr webpage says don't use a torque wrench just snug up hand tight with a wrench only. seems good to me... what I was going to do anyways, pull on it until it "felt right". *shrugs*.
thanks again guys
Posted on: 2011/8/17 6:53
Matatk Re: what do I put on the threads of the exhaust manifold bolts?
I disagree. I use anti seize on my header bolts. That along with stainless steel cap screws with lock washers.
The gaskets depend. I use Percy's reusable gaskets. If you have cheap style header gaskets, replace them. They aren't that expensive.
Posted on: 2011/8/17 7:33
I am careful when torquing into aluminum. And I have broken an OEM exhaust bolt when using anti-seize! Took the head right off.
If you decide to use anti-seize, take the torque from 19 to about 12 lb-ft. Figure that half the battle with torque is consistency and the issue here is that A-S will increase the specific torque by half - meaning 19 becomes 28. This would mean that 12 becomes 18 and everyone is really happy.
Posted on: 2011/8/17 16:28
Strick Re: what do I put on the threads of the exhaust manifold bolts?
Lake Wylie, SC
129 Posts
I make sure I have enough thread to go into the head. Most headers come with 3/4" bolts. I used 1" S/S allen head bolts because my flange was thicker than most. The allen head makes it easier to torque each bolt. Also, use a quality thread chaser to clean out the holes. Gaskets, I use the "dead" aluminum or copper gaskets. No leaks in 7 years.
Posted on: 2011/8/18 1:16
PLRX Re: what do I put on the threads of the exhaust manifold bolts?
SoCal
212 Posts
The LT4 FSM calls for 30 lbs-ft.
Posted on: 2011/8/18 1:19
flyboy Re: what do I put on the threads of the exhaust manifold bolts?
The FSM torque spec. would be for factory gaskets, bolts, etc.
Might it not be different for a performance upgrade?
Also, iron vs. alum. heads, don't know what the O.P.'s are.
Posted on: 2011/8/18 1:55
141 Posts
stock 91 is aluminum I believe, mine are currently AFR190cc's - aluminum too.
Posted on: 2011/8/18 11:10
WW7 Re: what do I put on the threads of the exhaust manifold bolts?
Almost Heaven WV
268 Posts
I have to agree with just tightening them up by feel. I have seen to many striped threads in aluminum to trust using a torque wrench on most aluminum parts..The only time I use torque wrenches on aluminum is putting on the intake base. I also don't use antiseize on the exhaust threads....WW
Posted on: 2011/8/18 23:13
Raises a question in my mind about numerous removal, inspection, install of washer type spark plugs using anti-seize in aluminum heads. Not to get off track.
Posted on: 2011/8/18 23:35
Bakersfield Ca
2336 Posts
Think of the VW spark plugs blowing out of their heads. They make a Helicoil to put on the spark plug to screw right back in. Aluminum has a heat effect it is a good and bad material around heat.
Steve
Posted on: 2011/8/19 0:15
141 Posts
i've never heard of people using anti-seize on the spark plugs....
I wouldn't do it personally. the spark plugs are really fine thread and use a clean steal thread that gets changed semi-regularly - i.e. a good seat. your exhaust manifold bolts... well, lol, you look at them and they are kind of grody usually coming with a minimum of at aleast a little rust or something on em. lol.....
Posted on: 2011/8/19 0:27
It seems to be generally recommended. Here is one thread of many.
http://www.hotrodders.com/forum/anti- ... d-spark-plugs-159537.html
Posted on: 2011/8/19 2:07
BillH Re: what do I put on the threads of the exhaust manifold bolts?
Geeze Guys.
Get the ARP catalog/technical data book.
Never put steel into aluminum without antisieze,especially sparkplugs, torque appropiately.
Tighten by feel? That's why they sell Helicoils and replacement studs/bolts.
Posted on: 2011/8/19 2:23
I always use anti seize on spark plugs
Posted on: 2011/8/19 2:34
JeffK Re: what do I put on the threads of the exhaust manifold bolts?
High Point, NC
1440 Posts
Me too, and on my header bolts.
Posted on: 2011/8/19 18:38
