116 user(s) are online (88 user(s) are browsing Forums)
bluewood Floor Jack
Millersville, MD
4 Posts
I am looking to get a floor jack. Do i really need to get a low profile one if I use the designate jack points? Vette is not lowered.
Any recommendations on branch/model?
thanx gary
Posted on: 2008/2/3 16:30
96 Torch Red Coupe
94z07 RE:Floor Jack
94 Posts
Before I got two little low profile jacks, I would drive onto four wood blocks to allow my big jack under the car. I used 2x10's and cut them to 12".
BTW I don't ever crawl under a car supported only with jacks but I do raise one side of the car with my little jacks, place stands at key points and rotate the tires front to back while the weight of the car is still on the jacks. I know it isn't following the rules according to Hoyle but it's easier than transfering the weight to the stands. Anyone else cheat?
Posted on: 2008/2/3 19:17
Business makes progress. Fortune passes everywhere.
MK 82 RE:Floor Jack
Palm Beach Gardens, FL
439 Posts
I would go with lo profile.
Posted on: 2008/2/3 19:24
96 CE Roadster LT4
bogus RE:Floor Jack
I have an AC-Hydraulic.
If you want to spend this kinda cash, that is...
http://www.drivewerks.com/catalog/sho ... L/POR_TOOL_ACHyd1_pg1.htm
Posted on: 2008/2/3 19:32
pianoguy RE:Floor Jack
I got NAPA's low-profile jack for around $200, and am happy with it so far. I know a guy who recently got an Arcan model XL35 from Northern Tool for $129, and likes it a lot.
Posted on: 2008/2/3 20:30
Notorious RE:Floor Jack
That is a sweet jack. I might have to get one of those.
Posted on: 2008/2/3 20:35
pappyfreebird RE:Floor Jack
1028 Posts
i like the cut up 2x10s ... i have n assortment of them fer low harleys...and yes id cheat too leaving wieght on jack fer quick rotation shouldnt hurt...long as stands r on stand by...who evoer did my rotation put the 9.5s on front n 8.5s on rear...aint looked yet to see ifn z51 er jus a previous owner changed wheels ...ok i shut up :tongue:
Posted on: 2008/2/3 20:47
MK 82 RE:Floor Jack
439 Posts
I have an assortment of cut up 2X10s for low Harleys. Yes I sometimes cheat leaving weight on the jack for a quick rotation. It shouldn't hurt as long as the stands are on standby. Whoever did my rotation put the 9.5s on the front and the 8.5s on the rear. I haven't looked yet to see if it is a Z51 or if the previous owner changed wheels. I shall now cease communication.
I Speak Hillbilly
Posted on: 2008/2/3 20:58
96 CE Roadster LT4
1028 Posts
wahahahahaha help helup oh heellluuup me!!! sarry i feel good yea yea!!
Posted on: 2008/2/3 21:00
Ramrod RE:Floor Jack
S. California
296 Posts
I have an El Cheapo Harbor Freight $79.00, it lifts the car, jack stands go under at the four corners. I still have my hands and feet, I shall cease at this point.
Posted on: 2008/2/3 21:48
Midnight85 RE:Floor Jack
Streator, IL.
264 Posts
I just got two new jacks from
Harbor Freight for Christmas.
They are made for cars such
as our Vettes. They have two
supports that go on each side
of the tire and lift the car that
way. You can't "cheat" then,
you have to put stands under
the car to get the wheels off.
I would include a link but I
can't find them on the HF
website. If anyone is interested
I can take some pics of mine.
Posted on: 2008/2/4 17:09
smooth like so.....
Formerly "Aquavet" in Pa.
386 Posts
http://search.harborfreight.com/cpise ... ame=&requestedPage=10
How high will they go?
Posted on: 2008/2/4 19:38
Alan
2001 Navy Blue Metallic
Midnight85 Re: like so.....
Streator, IL.
264 Posts
Dang, I couldn't find those darn things anywhere, thanks.
I've never had mine all the way up yet but I've had it high enough to go in from the front and change oil, and I'm a BIG guy. I was amazed at how steady they are that base isn't very big. If I were lifting the rear though I would definitely use wheel chocks. I had my family get me a pair so I could lift one end at a time and keeping the car level.
Posted on: 2008/2/5 3:19
