230 user(s) are online (129 user(s) are browsing Forums)
LD85 C4 cam swap
Indianapolis, Indiana
784 Posts
OK, I've been sick for the past 3 weeks, but today I made good progress, unfortunately I did not pick up a damper puller so that is where I stopped,
I did check the AC Condenser that I bought it it is @ 1.0" thick and the stock condenser is 1.75-2.0 thick
Everything is stripped down except the damper and cover, I'll grab a puller and get the cam out on Thursday or Friday
Posted on: 2013/3/9 20:42
2005/Z51
bogus Re: C4 cam swap
lotsa work just to get to that point.
Almost makes taking the engine out easy.
Posted on: 2013/3/9 23:07
LD85 Re: C4 cam swap
784 Posts
6 of one and 1/2 dozen of the other, had to drain the coolant because of the water pump, had to take the front of the engine off anyway, did not have to pull the headers and y-pipe by leaving it in.
By Thursday I should have the cam in a box and on its way back to Bullet in Mississippi.
Posted on: 2013/3/10 3:41
2005/Z51
that sounds reasonable.
all the valve train still has to come off... gee...
Posted on: 2013/3/10 4:30
Matatk Re: C4 cam swap
Looking forward to seeing the progress!
Posted on: 2013/3/10 11:30
784 Posts
Yes all the valve train came off either way but the tranny & bell housing & powwer steering pump stayed on
Posted on: 2013/3/10 12:15
2005/Z51
right.
Posted on: 2013/3/11 14:34
784 Posts
Stupid crap really makes me mad,,, the timing cover is new and the seal is leaking because the timing cover is a cheap stamping type cover and teh front seal hole is slightly off center and was not sealing at the 9, 12 and 3 o'clock areas, so the hole is off center towards the bottom of the engine, rubbing only in the bottom 1/3 of the gasket.
Anyway, I pulled the hub today during lunch and took the cover off.
All I need to do is take the timing chain off and hook some thin welding rod onto the lifters to pull them up away from the cam without the lifters coming out, then slip the cam out.
Also, I am contemplating using 1.52 rockers on the intake side with 1.6's on the exhaust side, anyone have any experiences with this?
My buddy ol'Rj does this, he tried the 1.52's on the intake and then the exhaust and his track results showed that using them in the intake probably allowed for better scavenging using the 1.6's on the EXH.
Posted on: 2013/3/11 19:33
2005/Z51
That was common on TPI cams, but depending on what cam you are running since it is aftermarket, not necessary.
Posted on: 2013/3/12 0:06
784 Posts
Cam is en-route to Bullet Cams
Posted on: 2013/3/15 19:29
2005/Z51
784 Posts
Had a long talk with Bullet Cams yesterday, flat out great people! They will take the time to talk with you if you need.
Regarding the split ration rockers, they said yes, when using the AFR heads, the EXH ratio inefficiency is very good, so slowing down the rocker with the 1.5 will actually boost the TQ in stead of using a 1.6's on the EXH. This was exactly my thought, on accident of course, but I knew the AFR EXH flow efficiency we @ 85% based on my flow charts, so there was no need to leave it open as long, and by using a .612" lift on the Intake, this helps the top end but sacrifices some low end TQ. Since I have 210cc heads, I did not want to kill anymore of my HP than necessary.
This does not affect the timing events, only the speed of the open and close of the valve and the lift. So, I'll be using 1.52-Exh & 1.6-Intake on the new cam
Cam specs are;
228/234 @ .050
284/289 @ .006
114 CL
.3825 lobe x 1.60 = .612"
.3825 lobe x 1.52 = .581"
Overlap at .050 = 3*
Overlap at .006 = 58.50*
So of the stuff came below and the cam will be ground this week and be back in my grimy hands next week.
Posted on: 2013/3/22 11:38
2005/Z51
CorvetteBob Re: C4 cam swap
1409 Posts
Cam specs are;
228/234 @ .050
284/289 @ .006
114 CL
Christmas came early for you. Care packages from Summit/Jegs are always fun to get!
Posted on: 2013/3/22 15:13
784 Posts
Valve cover hits wiper motor, no problem
RJ to the rescue:thumbs:
Strip and re-paint, and it is good as new
Posted on: 2013/3/22 18:18
2005/Z51
rklessdriver Re: C4 cam swap
I put those same rocker covers on my 84. Nice for the $$$, with one gripe... I wish they didn't cut the breather holes at the factory... I prefer to have both breathers at the front of the engine.
The cam lobes they are sending you sound good. Short advertised duration with a lot of lift. That's good for matching up driveability and power. I personally don't think you need the lobe centers spread out that far (114) but all it will do is make the power curve more gradual and hold on longer at the expense of some low/midrange. I'd expect it to drive very good on the street.
Posted on: 2013/3/22 20:23
784 Posts
Thanks Will, I'm pumped about getting it back on the road, I only drive it @ 2 months last year, it spent 3 months at paint, and 3 months at tune.
I was able to do 3 legs of the Hot Rod Power Tour before the paint and tune, so this year it should be all driving on road time with my son, he turns 15 so I get to teach him more about quality 60's & 70's rock & roll music :-)
Posted on: 2013/3/22 21:00
2005/Z51
That sounds like a great trip...can't wait until my kids are old enough!
Posted on: 2013/3/23 0:30
784 Posts
Cam "should" ship Monday/
My valve covers are at the powder coater being blasted and recoat & re-clear
Posted on: 2013/3/30 22:16
2005/Z51
Side tip...check with the cam company to see what distributor gear they recommend. I had to use a composite nascar distributor drive gear $$$ with my comp cam.
Posted on: 2013/3/30 22:46
784 Posts
Its a cam regrind so the gears wont change, but I'll ask, I'm pretty sure i have been using the GM melonized distributor gear with great results for the past 4 Bullet cams
Posted on: 2013/3/31 1:52
2005/Z51
Ok good, just thought I would mention it.
Posted on: 2013/3/31 2:48
Aboatguy Re: C4 cam swap
My Avatar was redistributed!
498 Posts
I agree.....
I've done C4 cam head swaps with the engine in the car a couple of times and then with the engine out. Now I just pull the engine. In my case at least, I can get it done quicker and easier by pulling the engine. Your experience may be different
MIke
Posted on: 2013/3/31 15:00
784 Posts
OK, thats it, I'm pulling the engine
Posted on: 2013/3/31 21:40
2005/Z51
784 Posts
Covers are coated, and on the way back
Posted on: 2013/4/3 14:37
2005/Z51
784 Posts
Stick is back
actual life will be .611 (1.6) on Intake and .581 (1.52) on Exhaust
Posted on: 2013/4/5 20:33
2005/Z51
So did you decide to pull the motor?
Posted on: 2013/4/5 23:26
784 Posts
No, cam will go back in tomorrow and I'll be half way done if not more by 5pm
going slow, cleaning and painting some stuff, little by little
Posted on: 2013/4/6 0:53
Edited by LD85 on 2013/4/6 1:22:53
2005/Z51
784 Posts
Posted on: 2013/4/6 17:56
2005/Z51
784 Posts
Snot
straight up with 4-degree advance ground in
Fold the tabs.
Posted on: 2013/4/6 18:29
2005/Z51
784 Posts
JB Weld around the pick up tube.
Posted on: 2013/4/6 19:22
2005/Z51
784 Posts
Posted on: 2013/4/8 17:42
2005/Z51
784 Posts
Should button it up Saturday, very close, just been short on time. It's been off the road since August.
All I need to do is put ion the radiator, AC Condenser, Compressor, coolant and put valve covers on and fire it up,
FAST program should be fine the way it is, but I'll check it out after I road test and look for leaks, re-tighten bolts etc.
This could be the first year I am caught up on all of the mods I have wanted to do, I just might become a, a, a, WAXER!
Posted on: 2013/4/30 12:00
2005/Z51
Great progress...btw what were the old cam specs / why were you replacing it?
Posted on: 2013/4/30 13:53
784 Posts
The Big Duration HR cam made 430-rwhp & 460-rwtq, but the valve overlap caused fuel smell in the exhaust that I just got tired of,
http://s556.photobucket.com/user/LAPC ... ard.jpg.html?sort=3&o=440
jpg  238242camcard.jpg (0.00 KB)
Posted on: 2013/4/30 15:09
2005/Z51
784 Posts
Fire in the hole!
It kicked over on the first try, darn I'm getting good.
But,,,,I still need to put the valve covers on, But,,, I'm too tired to spend another hour on it, Oil pressure was @ 60-psi
Next I'll let it idle and check the fans and get hot, look for leaks, burp the radiator, then shut it off and let it cool down...
I'll post a video of the idle when I get the covers put on.
[URL=http://s556.photobucket.com/user/LAPCO/media/2013-05-04163511_zps7b108338.jpg.html]Resized Image[/URL]
Posted on: 2013/5/4 20:31
2005/Z51
joeld Re: C4 cam swap
Good deal!
Yea, that does give ya a nice warm feeling when it fires quick and clean.
Posted on: 2013/5/4 21:20
pianoguy Re: C4 cam swap
Sweet - looking forward to the vid!
Posted on: 2013/5/5 1:04
784 Posts
The Dual Synch distributor makes it a piece of cake to install, I can tweak the timing to the FAST XFI program once I warm up the engine, probably next Thursday,
travelling for business Mon-Tue, & Wed eve is booked, supposed to rain all week anyway.
Posted on: 2013/5/5 22:10
2005/Z51
784 Posts
I lost the rumpity rump, oh well
Posted on: 2013/5/10 23:37
2005/Z51
784 Posts
Posted on: 2013/5/15 2:49
2005/Z51
SpectatorRacing Re: C4 cam swap
LD85 wrote:
Snot
I just rebuilt the LS2...couldn't find my Permatex because I loaned it to a buddy who kept it...
Used Lucas oil assy lube; it seemed fine. It was green and it smelled like mint. Did they really need to make it smell like mint?
Posted on: 2013/5/15 5:47
784 Posts
On terra firma, but the tune is off, I'll let the FAST XFI learn mode do its thing for a few days.
jpg  Done.jpg (0.00 KB)
Posted on: 2013/5/15 11:18
2005/Z51
Personally I wish that all petroleum based products had a nice smell added.
Imagine you build engines, transmissions or rear ends every day....
Would you rather go home smelling like:
(1) Mint (Lucas assembly lube)
(2) 3 day old cat piss (GM positraction additive)
LD85 -
I think the car sounds pretty good at idle....
Maybe it's up a little bit too high on the idle RPM.
You can always crank in a few degrees extra timing advance and lower the idle target RPM which will accentuate the "lick" at idle....
I'd imagine with 36* advance and a target idle RPM of 850 it would sound pretty darn good.
Posted on: 2013/5/15 12:30
BillH Re: C4 cam swap
+1
Even worse when it's used.
Posted on: 2013/5/15 13:39
