103 user(s) are online (68 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
skirlin 100 miles and caught a wave.
Caledonia Michigan
277 Posts
It's Michigan and it was warm today, 62. I got it out of storage yesterday and I put over 100 miles on it just driving around, what a ride. I had an owner of a C6 give me a wave..first...and I waved back. Felt great.
I bought my 92 in November and only put about an hours worth of time on it before parking it. It is my first vette and today has been pure heaven. I found turning off the ASR is the best, laid down a set of stripes about 30 feet long before letting off the gas.
Is it normal for the hood to shake when hitting bumps? It stays firm over smooth ground but on rough road it bounces a bit. It's going to be Corvette summer.
Posted on: 2008/4/6 1:43
FLYINLOW90 Re: 100 miles and caught a wave.
Windsor Ontario Canada
514 Posts
Right On
I was in Baton Rouge La. yesterday and it was 27C down there.
Saw a fair amount of Vette's
Can't wait for the warm weather to get here and STAY......
Gary
Posted on: 2008/4/6 2:07
xccter Re: 100 miles and caught a wave.
Downtown Annapolis, MD
461 Posts
The clamshell on my '88 doesn't appear to move at all under any driving conditions that I've noticed.
Posted on: 2008/4/6 2:39
ยด71 350/270 L48 Coupe
NCRS #48337
leftoverture Re: 100 miles and caught a wave.
34 Posts
Yea, check your hood to make sure it is properly latched on both sides. Then enjoy the ride.
Posted on: 2008/4/6 22:19
1988 Z52 Coupe 4+3
skirlin Re: 100 miles and caught a wave.
Caledonia Michigan
277 Posts
Thanks gents, I will tighten it down. :thumbright:
Posted on: 2008/4/7 1:12
teebee Re: 100 miles and caught a wave.
12379 Posts
Leftoverture, I like your avatar....and userID. A Kansas (the band) fan?
My hood shakes a bit on rough roads, I don't worry too much about it.
Posted on: 2008/4/7 2:27
patgizz Re: 100 miles and caught a wave.
Medina, OH
228 Posts
after work i put my new black A-mold's on and got the car out of hibernation. i was out for a couple hours and saw 5 or 6 others. no waves from any(all with the opportunity were c5/c6) but i did have a 74/75 convertible play catch up from behind to check mine out and i had a late model camaro SS throwing revs at me.
Posted on: 2008/4/8 12:49
pappyfreebird Re: 100 miles and caught a wave.
1028 Posts
my clam shakes a tad too...seems at speeds on freeway is when i noticed...any comments er things to look for????
Posted on: 2008/4/8 15:48
CentralCoaster Re: 100 miles and caught a wave.
The end is near!
If the large pins on the hood are adjusted out too far the hood can move around. To adjust them you have to first loosen the large nut (you will need a big crescent wrench).
There are also some rubber stops near the hood latches that can be raised up to meet the hood better.
I've dicked around with mine and it either squeaks or doesn't close easily. Maybe my latch springs are shot.
Posted on: 2008/4/8 18:18
Caledonia Michigan
277 Posts
I adjusted the hood pins which did help a lot, also made the hood line up with the doors better. Watch out though, you can go too far and the door will rub. and scuff the paint. I did not notice the rubber stops, I'll have to try that out tomorrow. Thanks.
I'm also going to look around the front mounting hinges for anything loose that could contribute to the problem.
Posted on: 2008/4/9 5:00
And don't forget there's rubber bumpers up front too.
Posted on: 2008/4/9 8:04
1Fast04Vert Re: 100 miles and caught a wave.
Be very, very carefull with the ASR turned off or your hood will be more than just shaking. Take it to a totally empty parking lot, turn the ASR off, get hard on the gas and turn the front wheels and you will experience a whole new sensation.
Posted on: 2008/4/9 13:06
Eh. I drive 10,000 miles per year without ASR, or ABS. Turn it on when you hand the keys to your wife.
Posted on: 2008/4/9 18:02
Caledonia Michigan
277 Posts
Success :banana21: Thanks centralcoaster, after I adjusted the rubber stops at all four corners I drove down the road by my house I have been avoiding, to test it. It did not move. I am a happy camper.
Posted on: 2008/4/11 18:11
NC Kid Re: 100 miles and caught a wave.
North Carolina
1671 Posts
Whats ASR and do I have it?
Posted on: 2008/4/13 1:59
Caledonia Michigan
277 Posts
Hi black86v3tt3, ASR stands for Acceleration Slip Regulation. It uses three subsystems of spark retardation, throttle close down (yes, the pedal pushes back), and rear brake intervention. It works with the ABS (This was from the Factory Service Manual).
It scared me the first time it happened, there was a little snow on the road and all of a sudden there is an odd grinding type sound from the rear of the car and the gas pedal is pushing back against my foot. Just like the first time ABS kicks in, kinda freaks you out. I believe 1992 is the first year in production and is standard on every vette from then on. I assume yours is an 86 from your name so I don't think you have it. I usually turn it off if it is dry and sunny out. On the good side it won't let you do burnouts, saves ya some money. :thumbright:
Posted on: 2008/4/14 1:17
skirlin wrote:
On the good side it won't let you do burnouts...
That's a good thing? You never know when you'll need to squeeze out some tire smoke.
Posted on: 2008/4/16 15:30
1028 Posts
been lil curious myself as to ifn this ol girl will let loose of some rubber....kids lt1 trans am will toast em as far as ya like ,,, but hes at 285hp
Posted on: 2008/4/16 15:33
