172 user(s) are online (95 user(s) are browsing Forums)
TommyT-Bone, more...
vetteblondie Holy Cow - Sticker Shock
Jonesboro, AR
4657 Posts
on one of those 'red top' batteries - GEEZ LOUIZE!!!!!! Never got one before and everyone recommended them. Are they really worth that extra $100?
And it's STILL hard to start...
Posted on: 2008/8/13 17:44
�Ugol's Law
biggrizzly Re: Holy Cow - Sticker Shock
DIE HARD
WAL-MART
All work great too.
I'm using a battery I got at Autozone several years ago and it is still doing great. I keep it on a battery tender to keep it fresh.
Posted on: 2008/8/13 17:46
CentralCoaster Re: Holy Cow - Sticker Shock
No.
Posted on: 2008/8/13 18:01
pianoguy Re: Holy Cow - Sticker Shock
I have a Fleet Farm battery in my car, works like a charm.
Posted on: 2008/8/13 18:29
CSS996 Re: Holy Cow - Sticker Shock
Mega Guru
Central PA
3644 Posts
I can't see myself ever spending big bucks on a battery. Wal-Mart is good enough. I've owned Die-Hard and never had any trouble. A couple Interstates have given me just a bit of trouble, but would buy another if Wal-Mart didn't have what I needed...
10% discount since the wife works there. 'Nuff said.
Posted on: 2008/8/13 18:34
Currently "Between Vettes".
red_johnny Re: Holy Cow - Sticker Shock
They are not worth it. I did a yellow top a few years ago and it ran the car audio stuff good with out dying but after 3 years the battery was toast.
Posted on: 2008/8/13 18:44
SpectatorRacing Re: Holy Cow - Sticker Shock
The optima batteries (or other gel cel types) are primarily good for two things:
1. Safety - they are full of gel instead of liquid so acid doesn't spray all over you if the battery is ruptured in a crash
2. Deep cycle - for cars that aren't driven much, or any car where the battery isn't regularly charged. If you discharge a battery enough times (let it sit and suck the juice out of it) it will destroy it. A deep cycle battery can recover from a full discharge more often than a normal one.
If you don't need either of those things, you don't need a red top.
Posted on: 2008/8/13 19:00
I thought the yellow or blue tops were for deep cycling?
They are also good for off-road or racing because they take the vibrations and hits better than a liquid battery, and give more more mounting options, in the car, under the car, etc.
Posted on: 2008/8/13 19:28
Jeffvette Re: Holy Cow - Sticker Shock
Come back and bitch when you spend about 350 bucks for a battery.
Posted on: 2008/8/13 20:21
Could be. I never really looked at what the colors pertain to. I don't use an Optima. Perhaps the red tops are just an entry level gel cel.
True. I didn't figure that pertained in this case...
Must be a ZR-1 thing. Marine batteries aren't cheap;)
Posted on: 2008/8/13 20:35
Matatk Re: Holy Cow - Sticker Shock
BTW, I don't think they are worth it. A lot of folks buy a good battery with a good warranty and just get 'em replaced for free/discount if they go bad
Posted on: 2008/8/14 0:18
LOL, race weight, Odyssey or Braile.
Posted on: 2008/8/14 1:02
BrianCunningham Re: Holy Cow - Sticker Shock
Spiral wound batteries are great at handling g-loads at the track. I've seen conventional batteries died because the plates have warped.
Posted on: 2008/8/14 3:57
vetteblondie Re: Holy Cow - Sticker Shock
Jonesboro, AR
4657 Posts
heck, I bitch when I have to spend ANYTHING else, done enough already! Nevernind changing it is a pain in the ass. And, made me late for work.
Posted on: 2008/8/14 4:17
�Ugol's Law
