190 user(s) are online (120 user(s) are browsing Forums)
Early SBC
4.3L 265ci - 1955 thru 1956
4.6L 283ci - 1957 thru 1962
4.9L 302ci - ...
Steel_Blue_91 Interrmittent no start!! No logic.
Burlington, NC 27217
76 Posts
My 91 seems to have a mind of it's own. If I go down to just fire it and let it run for a few min. during the week, it will start and run fine. If I need to move it for whatever reason, it just clicks. Happened again this morning - needed the space to pull the Ranger in and bleed the brakes. Jumped in and hit the key and got a single click and nothing. Repeated attempts got the same result. Got a little pissed and came up for a cup of coffee. Returned to smack the starter with a hammer to see if that changed anything, hit the key just for fun and BAM - she fired fine like nothing was wrong!!
Any ideas?
Posted on: 2008/11/22 14:25
jsup Re: Interrmittent no start!! No logic.
1778 Posts
Dirty battery connections. Clean them up good.
Both ends of the cables.
Posted on: 2008/11/22 14:37
Schrade Re: Interrmittent no start!! No logic.
Next time it won't start is the time to put a multimeter on it...
Posted on: 2008/11/22 15:22
1778 Posts
What would that tell him? Voltage isn't the problem, amps under load is.
Posted on: 2008/11/22 15:29
Woodstock Re: Interrmittent no start!! No logic.
Bremen/Germany
369 Posts
...makes you think, mmmmh? :sign7:
Posted on: 2008/11/22 15:56
91 convertible
1778 Posts
Not really. Still looking at battery connections before the starter.
Posted on: 2008/11/22 16:00
bogus Re: Interrmittent no start!! No logic.
20861 Posts
I agree. When a car sits too long, the battery connections will corrode.
I would remove both + and - connections and the battery.
Check the ground cable that runs to the chassis. I will bet money it is all tore up from corrosion.
Take a steel brush and clean off all the rust you see. You will need to remove the battery tray, too.
Check under the tray, too. Rust will be there, I can almost guarentee it.
Steel brush all of it and then prime and paint with semi-gloss black. It will look like a million bucks.
Next up, follow the ground cable. It will terminate on the block. Clean that up, too. Make sure the fitting at the block isn't damaged or corroded. New cables are not that expensive (from GM, even) and are a nice investment.
Finally, clean the cable battery ends. Steel brush and some terminal protectant will go a long way to keeping the corrosion down. I use the red stuff in a spray can. Clean the battery ends, too.
That's about it... it will take a morning to do it all, but the end result will be well worth it.
Posted on: 2008/11/22 17:37
1778 Posts
When you put the terminals back on, coat them with either di-electric grease or lithium grease. It will keep them from rotting again.
Having a boat in salt water I have gotten into the habit of putting di electric grease in every electrical connection I touch.
Posted on: 2008/11/22 17:46
BrianCunningham Re: Interrmittent no start!! No logic.
Mine did that.
I wound up replacing the starter.
Turns out the reason it failed was a rear main seal leak.
It soaked the starter, and also a brand new clutch!
Posted on: 2008/11/22 22:15
Multimeter can also measure amperage yup.
If he has the right multimeter, next time it won't start, he can put a multimeter on it.
Here's one multimeter that can test a no-start:
There's other multimeters that can test a no-start too uh huh.
png  multimeternostarttester.png (33.42 KB)
1687_492884ab48c4b.png 200X194 px
Posted on: 2008/11/22 22:17
dan0617 Re: Interrmittent no start!! No logic.
You need a starter or a starter repair/rebuild. Mine did the EXACT same shit. At first tapping it with a hammer would make it go, then eventually not. Next time it acts up hold the key over and have someone tap the starter. I'll bet it will go.
Posted on: 2008/11/22 22:21
20861 Posts
IF you need a starter (you can have it tested) don't even bother with remanned parts. They are uber-junk.
Find a local shop that specializes in rebuilding these things. The mini-starter used by GM is a Mitsu or Denso design (can't remember which) and the internal contacts wear down.
It shouldn't cost more than 20.00 to get that fixed.
Posted on: 2008/11/22 22:43
Steel_Blue_91 Re: Interrmittent no start!! No logic.
76 Posts
Thanks for the replys guys. I'll take them all under advisement. For the time being.....
I'll continue to threaten using the hammer as it seemed to work yesterday. lol
Posted on: 2008/11/23 12:21
CentralCoaster Re: Interrmittent no start!! No logic.
Possible bad cable connection at the starter, or more likely a bad starter solenoid. The battery has good voltage, and ignition switch powers starter solenoid (click) but solenoid doesn't close or make good contact for current to flow to the starter motor.
Posted on: 2008/11/23 17:02
pianoguy Re: Interrmittent no start!! No logic.
The last time I had to use a hammer on a starter was several decades ago, but a sticky solenoid was the culprit.
Posted on: 2008/11/23 17:04
76 Posts
Well, I have finished the brakes on the truck and can put the vette back in the garage. As I said, I'll check on all areas of responses although it has started, without fail since the recent issue.
Thanks again.
Posted on: 2008/11/23 17:48
Pcolt94 Re: Interrmittent no start!! No logic.
Orlando
31 Posts
I’m thinking you have a bad starter/solenoid also. Your symptoms mirror mine and I ended up changing the starter. That contact in the solenoid are probable defective. It was not a tough getting it out as I thought it was going to be.
If you end up changing the starter, it’s a great time to change the fuel filter because accessibility is increased greatly.
Posted on: 2008/11/24 16:10
1778 Posts
This is going back a long time, but if the solinoid is bad, the dash lights won't dim as there is no draw. Is my memory clear on that?
Posted on: 2008/11/24 16:17
Bremen/Germany
369 Posts
@jsup, you're talking about the VATS system
Steel_Blue_91's condition might even drain the battery when the engine is shut off
Posted on: 2008/11/24 16:33
91 convertible
1778 Posts
The first question we used to ask when a car wouldn't turn over is "did it click". The answer is yes, then we have a weak battery/loose connection.
If the answer was no, we say turn on the headlights, do the dim when you crank the car? If no, the either solenoid or relay.
I was referring more to the old style stuff like that.
Posted on: 2008/11/24 18:07
If the starter was drawing current but not turning, you'd be smelling burnt plastic or replacing a fusible link.
Posted on: 2008/11/24 20:37
captmike13 Re: Interrmittent no start!! No logic.
Hillsboro Mo
2166 Posts
I agree with Central. Mine did same thing. It was a bad solenoid. Cheap part to replace. about $25 for a new one.
Hope this helps.
Mike.
Posted on: 2008/11/24 21:49
13 GMC 3500 dually
captmike13@yahoo.com
76 Posts
Sorry it took so long to post back. The starting issue I had (notice the past tense)has been fixed. Was finally able to get the vette on jackstands and the starter out on Wed. Rather than buy a new (~$300) or reman.(~$150) I decided to have mine rebuilt. Dropped it at the shop Thursday afternoon. Got a call from the shop Friday to let me know that the starter was in good shape but the contacts were shot and were replaced. Got it back that day and put it in tonight. Starts each and every time now. Total cost to me - $45.00 with a 24 hour turn around time! So far, I am a happy boy.
Thanks again for all the suggestions.
Bill
Posted on: 2009/2/1 4:21
Good to hear you got it sorted out, and at a bargain price to boot!
Posted on: 2009/2/1 4:54
Livin_the_dream Re: Interrmittent no start!! No logic.
robesonia , pa
516 Posts
Bill
I have a lot of stuff rebuilt rather than buying new or reman. You get you original part back good as new if the guy is good
Posted on: 2009/2/1 14:16
