281 user(s) are online (224 user(s) are browsing Forums)
xccter Who's Replaced an L98 AIR Pump?
Downtown Annapolis, MD
461 Posts
Sounds like the bearing is almost toast on my AIR Pump on the '88. Anybody replaced one recently? I hope a new pump comes with the gasket for the tube.
Posted on: 2009/3/7 17:55
´71 350/270 L48 Coupe
NCRS #48337
bogus Re: Who's Replaced an L98 AIR Pump?
why not eliminate it? Does MD require visual on an 88? Or are you out for 100% originality?
All the air pump does is help light off the main cat a little quicker. That's all it does. That and clutter the engine compartment and suck down 5hp. Oh, and fail and eat belts.
Posted on: 2009/3/7 18:22
patgizz Re: Who's Replaced an L98 AIR Pump?
Medina, OH
228 Posts
i've replaced it at least 5 times. it has failed every year since the original one died.
the ones i got came with new gasket for the tube. and since it's lifetime warranty they keep giving me new ones. i finally got a deal on an eliminator
Posted on: 2009/3/7 23:42
xccter Re: Who's Replaced an L98 AIR Pump?
461 Posts
I don't care about originality on the '88. The '71 is another story.
I've only seen the eliminator pulley for L83s. Who makes one for L98s?
I'm interested.
Mark
Posted on: 2009/3/8 1:30
NCRS #48337
85L98-84L83 Re: Who's Replaced an L98 AIR Pump?
113 Posts
I'm interested.
Mark
You don't care about originality? What about those tacky gold stickers they hand out at bloomington?
Posted on: 2009/3/8 2:11
Matatk Re: Who's Replaced an L98 AIR Pump?
22803 Posts
Couple companies make them, but it's gonna run you about $150. I used an old air pump, gutted the fins, and stuck it back in there. Then I ripped all the air lines out that went to/from it. The bearing isn't really serviceable, but I threw a bunch of extra grease in there just to help it out in case.
Posted on: 2009/3/8 11:33
Danspeed1 Re: Who's Replaced an L98 AIR Pump?
Mooresville, North Carolina
1121 Posts
You can make an eliminator for it for under $50 with a little creativity.
DG
Posted on: 2009/3/8 14:00
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
volzfan Re: Who's Replaced an L98 AIR Pump?
Kingsport, TN
306 Posts
If you know a machinist, or have access to a lathe and mill and can do your own work (I am fortunate in that respect), you could do what I did. I fabricated this one out of 1/2" aluminum, some 3/4" aluminum barstock for the "standoffs", and bored an old alternator pulley out for bearings. The bearing mount is a piece of 1 1/2" steel shafting out of the scrap bin at the machine shop. May or may not be your cheapest route, but I like the way it looks much better than the aftermarket kits available from most suppliers.
Posted on: 2009/3/8 14:38
Vettes of the Smokies
113 Posts
Wow, that looks good.
Posted on: 2009/3/8 16:58
dude, you need to make detailed instructions for that setup. Measurements, dimentions... what have you.
Then we need to make it available on the Guru tech library!!!
Posted on: 2009/3/8 19:54
22803 Posts
Better yet, you should make them and sell them for less than the $150 tpis charges.
Posted on: 2009/3/8 23:08
Kingsport, TN
306 Posts
Thanks for the kind words, everyone.
It may take me few days, but I'll try to put a sketch together with some dimensions. Maybe I can get #1 son (Trae1976) to do it on Autocad and post some good drawings. I'll work on it.
Posted on: 2009/3/9 11:05
BeachBum Re: Who's Replaced an L98 AIR Pump?
751 Posts
Breathless Performance out of Florida used to make Air Pump Eliminator kits, which consisted of a couple of powder coated mounting arms and a pulley to replace the pump, thus you change nothing on your set-up and it really is just a 20 minute changeover considering it just bolts in place where your current air pump is.
The benefit is HP if that is something that interests you....unlike some other C4 items, it "really" is worth some HP....literally around 10 hp.... as per my tests years ago. Not much I know, but better than a swift kick in the head.
I do not know if Breathless still makes them..... or even if they are still in business. But should be easy to find. They used to be a supporting vendor of CF.... thus maybe they are still over there, I dunno.
I will say, the kit was a little over priced at around $ 150 back then when I bought it..... but, it was hassle-free, so I guess from that perspective, maybe it was worth it.
good luck !
Posted on: 2009/3/9 20:13
C4 Corvette 436 - Pure Black
dougs91 Re: Who's Replaced an L98 AIR Pump?
Olalla Wash.
22 Posts
So a question,when you eliminate the air pump what do you do with the lines? cap them,pull them off? This is interesting. Thanks,Doug
Posted on: 2009/3/12 19:41
1991 QBlue L98
22803 Posts
For the lines that hook into the exhaust manifolds, just cap them off. I removed all of the lines that ran in front of the engine block that were accessible. Much cleaner and easier to work in there. I left the tube that runs down to the cat because it was a nuisance to remove.
Posted on: 2009/3/12 20:18
Olalla Wash.
22 Posts
Great! Thanks for the information.Doug
Posted on: 2009/3/12 20:31
1991 QBlue L98
CentralCoaster Re: Who's Replaced an L98 AIR Pump?
I removed the check valves from the headers and installed 1/2" NPT pipe caps on there.
I got some pretty stainless ones from mcmaster.com
You can run it temporarily with the check valves, but they will actually let air draw into the exhaust system at certain rpms and make noise.
Posted on: 2009/3/12 20:44
22803 Posts
I put cheap home depot caps on mine.
I don't have any good pics, but you can see it a little here from when I was changing my injectors.
Photobucket
Some of the junk removed:
Photobucket
Posted on: 2009/3/12 20:54
Bling bling yo.
Posted on: 2009/3/12 21:00
