214 user(s) are online (117 user(s) are browsing Forums)
skirlin Half shaft Ujoints will not come out
Caledonia Michigan
277 Posts
I had an AH-HA moment when I removed the right side shaft. The outer ujoint is completely shot, I am surprised it is still in one piece. I have everything out, spindle nut was fun but got er done. I followed the advice on previous threads about how to replace the joints using a vice and sockets. I broke the vice. Are they usually in that tight? I had one of my father's friends say put some heat to it and it will loosen right up. The shaft is aluminum and I have had some bad experiences with heat and aluminum. Help please.
Posted on: 2009/3/23 7:22
BrianCunningham Re: Half shaft Ujoints will not come out
sounds like it might have welded itself to the halfshaft
Posted on: 2009/3/23 14:11
bogus Re: Half shaft Ujoints will not come out
Do you have a harbor freight nearby? If so, get their 20 ton floor press. About $120.00 usually.
Posted on: 2009/3/23 14:31
or take it to a parts store with a press
Posted on: 2009/3/23 14:33
Matatk Re: Half shaft Ujoints will not come out
22806 Posts
Can you drill it?
Posted on: 2009/3/23 16:35
1Fast04Vert Re: Half shaft Ujoints will not come out
Do not use heat. Mine were too tight for a vise, I had to take them to a friend with a press, and also pressed the new ones in while I was there.
Posted on: 2009/3/23 17:34
Randy93 Re: Half shaft Ujoints will not come out
Winter Park, Fl
51 Posts
1st off, Brian change your avatar. I forgot what I was going to post, TWICE!!
Use a hammer with a socket the same size as the whole and beat it out, had to do that with mine.
Posted on: 2009/3/23 18:44
BillH Re: Half shaft Ujoints will not come out
Using a vice is sometimes hard when the joints are old. And you need a decent vice to do it, a 5-6 inch at least because they are beafier. And cheap vices will break, that's why good 6 inch vices cost over $120.
Without a press, the hammer and socket works but, you can't use your small ballpeen. You really need a 3lb. short handle hammer. They're sometimes called drilling hammers. They're $12 or less.
Once you get the bearing cup to move a little (break any corrosion), you can move to the vice.
A little heat won't hurt at all but I wouldn't recommend an A/O torch unless you know what you're doing. The best small torcg is a Mapp gas one, looks like a prophane but gets quite a bit hotter (prophane's worthless).
Posted on: 2009/3/23 22:14
Matatk wrote:
Can you drill it?
Nope Matthew, The bearing cap's hardened. The entire cap has to be pressed out so you can dron the joint down into that hole. And if you used a drill bit the same size as the cap, you'd screw up the hole in the yoke where the new cap has to go.
Posted on: 2009/3/23 22:18
CentralCoaster Re: Half shaft Ujoints will not come out
None of this makes any sense to me. Just drive a wedge in behind the ujoint to pop it loose. A vise is only used for installing it.
Posted on: 2009/3/23 23:48
vetteoz Re: Half shaft Ujoints will not come out
He is trying to get the uni cap out of the halfshaft eye ; not the drive yoke in the spindle / diff
Posted on: 2009/3/24 0:16
jhammons01 Re: Half shaft Ujoints will not come out
^^Huh?
He is trying to get the u-joint out of the Half Shaft yoke.
Anyway OP, just get anything larger in Diameter to put under the lower part of the yoke.
Then get a Socket or something shaped like that you don't care to own anymore......place it on the u-joint cap and hit it with a hammer.......hard.....
It is aluminum the cap will move easily within.
This was just about the easiest u-joint I ever removed in 30 years of shade treeing.....
Posted on: 2009/3/24 6:07
Posted on: 2009/3/24 13:55
skirlin Re: Half shaft Ujoints will not come out
Caledonia Michigan
277 Posts
The shaft came out of the car rather easily. The problem was removing the joints from the yokes. Both sides were seized. I have replaced ujoints before and never had this problem. That is when I start asking people with more experience for suggestions.
"^^Huh?
This was just about the easiest u-joint I ever removed in 30 years of shade treeing....."
Absolutely, I did just that and it should have worked like you described, but didn't budge.
Due to the lack of progress I decided to visit my local garage. It took him just under a half hour to get the job done. He said normally it is a very simple quick job but this time the shaft did not want to let go. He was all smiles when he got done, ah Victory. It cost me $36. I am happy. When an experience mechanic with all the right tools has a hard time, I don't feel so bad.
Now I get to put it all back together .
Thanks everyone.
Posted on: 2009/3/24 15:31
Excellent!
Posted on: 2009/3/24 16:10
4 lb hammer......didn't work??
6 lbs Hammer.......
Sledge hammer....
Hammer and bailing wire
Posted on: 2009/3/24 18:43
