191 user(s) are online (127 user(s) are browsing Forums)
BrianCunningham pitch pitch pitch
What's the best way to get tree sap off your car.
Besides not parking under a pine tree to begin with?
Posted on: 2009/5/27 14:19
bogus Re: pitch pitch pitch
Dawn dishwashing soap.
Then a good coat of wax to keep it from sticking in the first place.
Posted on: 2009/5/27 14:44
itlgo2 Re: pitch pitch pitch
Missouri
288 Posts
clay bar with detail spray
Posted on: 2009/5/27 15:05
joeld Re: pitch pitch pitch
Many opinions on this subject, I have always had good luck with that Nu-Finish polish. If the sap hasn't turned "rock hard" yet, it should come off fairly easy with a good polish. Then a good heavy coat of wax.
Posted on: 2009/5/27 15:12
BillH Re: pitch pitch pitch
I'd try and disolve it first with WD40 (like tire marks at the track) or maybe OOPS, Dawn.
I definately wouldn't use polish or even a clay bar before getting most of it off.
Posted on: 2009/5/27 16:01
vetteblondie Re: pitch pitch pitch
Jonesboro, AR
4659 Posts
Actually, the stuff that removes stickers from cars - you can find at the parts store for $5 a can will do the trick too and won't hurt the paint.
Posted on: 2009/5/27 22:42
�Ugol's Law
Matatk Re: pitch pitch pitch
22806 Posts
I've used wd40 and goo gone. That and a little elbow grease. They also make tar/sap remover that should probably work.
Posted on: 2009/5/28 0:44
TommyT-Bone Re: pitch pitch pitch
33768 Posts
Mineral spirits?
Posted on: 2009/5/28 0:53
VtVette Re: pitch pitch pitch
Las Vegas, NV
357 Posts
goo gone works great!
Posted on: 2009/5/28 0:59
Brian
VTvette
Goo Gone & OOPS are just about the same.
They work well on dried out masking tape,latex paint and the road striping paint.
Posted on: 2009/5/28 1:09
