212 user(s) are online (159 user(s) are browsing Forums)
Dads90 Hazy Windshield
Pearland, Tx
318 Posts
Does anyboby have the same problem ? I can use a Windex type cleaner twice. Then use Stoners for the final wipe and I'll be damned the window forms a hazy film again the very next day. I normally drive home into the setting sun and its more noticable at that point. I just want a clear windshield. Any suggestions ?
Posted on: 2009/6/24 3:23
TommyT-Bone Re: Hazy Windshield
33772 Posts
Now that you mention it ........
Posted on: 2009/6/24 3:33
CSS996 Re: Hazy Windshield
Mega Guru
Central PA
3644 Posts
Stop using stoners... They are lazy by nature.
Maybe it isn't so much what you're using to clean the window, as much as it is the stuff you use to clean the dash? Maybe the chemicals are leaving the dash pad during the heat of the day and depositing on your glass.
Posted on: 2009/6/24 3:58
Currently "Between Vettes".
Dads90 Re: Hazy Windshield
Pearland, Tx
318 Posts
The Stoners doesn't have detergent so its not suppose to leave a film. I use a little california duster on the dash, don't put any cleaner on it. Im tempted to try some anti fogging junk, cause the defrost vent might be leaking cold air and contributing.
Posted on: 2009/6/24 4:08
bogus Re: Hazy Windshield
It's caused by all the plastics off gassing.
I would use a home brew mix... an empty spray bottle, filled with hot water, a good shot of Dawn and a couple of ounces of ammonia. Shake and apply using 0000 wire wool.
Then use Windex to rince off.
Posted on: 2009/6/24 4:11
Pearland, Tx
318 Posts
The home brew sounds like a go, but a little leary of the steel wool.
Posted on: 2009/6/24 4:21
0000 wool is very soft... hence the 4 zeros. It is used a lot in the window tint biz.
Posted on: 2009/6/24 5:31
pianoguy Re: Hazy Windshield
I bought some real fine white microfiber cloths last year that work great - you just use water to wet it, then wring it out until it's almost dry. Leaves no streaks or residue. I got them from somebody advertising on CF, but I think you can get them at auto parts stores. I'll see if I can find a link.
Posted on: 2009/6/24 10:35
Posted on: 2009/6/24 12:16
Matatk Re: Hazy Windshield
Is it hazy all over or just where the defrost vent is (ala bad heater core)
Posted on: 2009/6/24 17:48
BrianCunningham Re: Hazy Windshield
That's what I was thinking.
Posted on: 2009/6/24 18:08
Pearland, Tx
318 Posts
It is all over. Direct driver eye level thru to the passenger side. I can wipe my thumb pad across it to remove it. But it comes back. Maybe if I didn't breath it wouldn't fog. LOL
Posted on: 2009/6/25 3:22
BillH Re: Hazy Windshield
I use chrome polish on the outside of windows to remove water spots. Even use it with a foam buff pad on a drill.
Chrome polish on windows is a old hotrodder's trick.
I'm currently using Mother's Mag polish.
You may want to try it on a descrete spot.
Was your car ever repainted?
Posted on: 2009/6/25 13:18
DaleD Re: Hazy Windshield
Cuyahoga Falls, Ohio
1389 Posts
My driver's side window was pretty bad. I used a clay bar on it, and it improved it a lot. Just a suggestion, YMMV.
Posted on: 2009/6/25 13:32
