258 user(s) are online (199 user(s) are browsing Forums)
BrianCunningham [graphic] I'm glad I have a 6pt harness
Ouch!
-----Original Message-----
Sent: Wednesday, June 10, 2009 12:31 PM
To: ne-svt@googlegroups.com
Subject: NE-SVT: Harnesses
Everyone (especially guys) who use a harness should look at this (some graphic images, be warned, may be NSFW, but is still important to read).
http://www.sciencedirect.com/science? ... 4efd9af52e783895ccdb#fig1
This is one of those images that you won't soon forget (and shouldn't). In light of this, I'd like to start a discussion on harnesses. I just spent a considerable amount of money on seats for my Lotus so that I could run the OEM lap belts. I currently have a Willans 4 point harness. I've read that 4 point harnesses (without ASM) can be dangerous and that many places require 5 or 6 point harnesses. Having seen the above link, I'm not sure I really want to run a 5/6 pt. On the other, other hand, I know that my 4-pt harness (both the Willans I currently have and the Scroth that I used to have) both ride up to high when tightened (this can also cause serious internal injury/death). I also really like the way that my 4-pt harness holds me in place.
So, what is the collective wisdom (4-pt., 5/6 pt. or OEM belts)? I'm not opposed to spending money on my safety, but I just want to make sure I do what is best.
I'm kind of leaning towards just using the OEM belts. The new seats I bought have a lot of support, so I'm somewhat hopeful that I won't need the "bracing" of the harness to hold me in place. They are also a lot easier to live with while driving on the street.
-Paul
(although my "buddies" are now "mission accomplished," I still want them around)
Posted on: 2009/6/10 17:10
CentralCoaster Re: [graphic] I'm glad I have a 6pt harness
This needs a bigger warning.
Link shows closeups of a guy who almost lost his nuts. (Yes, those nuts).
Click on them to enlarge if you really want to lose your appetite.
Posted on: 2009/6/10 17:26
I do fear submarining with OEM belts, or at least getting gutted by it. The lap belt rides too high on me. I guess I could raise my seat to help a little.
Posted on: 2009/6/10 17:32
pianoguy Re: [graphic] I'm glad I have a 6pt harness
I'll give that a cringe factor of 10.
Posted on: 2009/6/10 18:18
Mekanic Re: [graphic] I'm glad I have a 6pt harness
Tampa Bay Florida
827 Posts
Interesting read. Safety in motorsports is a BIG thing for me. Ricers with stock seats and non-certified 4 points make me cringe in horror.
I've never seen an injury like that with a 6 point belt tho. My guess is it wasn't tightened enough making him impact the belts in the crash.
Posted on: 2009/6/10 23:28
~Rich
Polo LT4
BillH Re: [graphic] I'm glad I have a 6pt harness
That's the beauty of the antisub belts, adjusting their length allows you to control the position of the lapbelt (higher or lower).
The tighter you pull the shoulder belts, the higher the lapbelt comes up.
So damn many people have their belts adjusted wrong anyway, it's scary. BUT, not as scary as a 4 point belt.
Posted on: 2009/6/11 1:57
bogus Re: [graphic] I'm glad I have a 6pt harness
ouch.
I think I will pass.
Posted on: 2009/6/11 2:05
Matatk Re: [graphic] I'm glad I have a 6pt harness
22808 Posts
So is that what caused this?
Posted on: 2009/6/11 2:35
I'm not sure I understand your question correctly Matthew.
I'll try an answer, let me know if it's something else.
The injurys to this guy could be caused by multiple things. My first guess is that the belts were too loose. My second guess is that the belts were impropery installed specific to the mounting locations.
Many guys get a 5 or 6 point seup and think they can wear the belts at the tension they wear their street belts at.
Many guys just use whatever bolts are already available on the car to fit the harness and those locations can be incorrect.
There are specific ways that the lapbelt should be installed and a specific point on your hips that it should cross. The antisub belts should control the location of the lapbelt (up or down) when the shoulderharness belts are pulled very tight.
Both the lap and shoulder bets should be very, very tight.
There are baffons like this guy Paul who think different seats will hold them in enough.
Using 6 point belts with stock seats isn't a very good idea either.
Posted on: 2009/6/11 3:11
Tampa Bay Florida
827 Posts
Exactly Bill. Its not just the fact that you have a good seat or a good belt, proper installation angles are KEY.
Posted on: 2009/6/11 12:11
~Rich
Polo LT4
22808 Posts
That's it, Bill. Thanks.
Posted on: 2009/6/11 12:52
Yep, and it's also important whete the laps cross your pelvis and that the shoulder belts be attached to the harness bar or rollbar so that they point as straight back as possible.
I think Schroth and Willins (my favorite belts) have good diagrams too. Thanks for posting the pic.
Posted on: 2009/6/11 13:21
PJK Re: [graphic] I'm glad I have a 6pt harness
1 Posts
Hi Bill,
I never stated or implied that different seats would eliminate the need for a proper belt set up. The mere fact that I posted that original question (not to this board I might add) should have been enough evidence for you to come to this conclusion. My point in the original email was whether a 4 pt with ASM, 5/6 pt., or OEM belt would be better FOR MY PARTICULAR APPLICATION. Certainly you can agree that one set-up is not best for every application.
I understand that there is a lot of bad information and/or misunderstanding regarding safety equipment. But your reference to me as a "baffon" not only did not help your point, but was also a poor snap decision. I also suspect that you would not have said that to my face.
By the way, I think the word you were looking for is buffoon, not baffon.
Posted on: 2009/6/30 15:19
TommyT-Bone Re: [graphic] I'm glad I have a 6pt harness
33791 Posts
To quote Major General Anthony McAuliffe. "Nuts."
Posted on: 2009/6/30 16:23
Still holdin' that bridge, Tommy?
Posted on: 2009/6/30 16:25
33791 Posts
That pic made me hold something but it wasn't a bridge.
Posted on: 2009/6/30 16:29
Jeffvette Re: [graphic] I'm glad I have a 6pt harness
This incident boils down to not having the belts or a proper seat installed. I have seen many guys using a 5 point system that the shoulder straps could not get the correct angle around the upper part of the seat and keep the belts riding on the proper area of the shoulder, nor could the submarine belt do any good for lap belt fit across the pelvic area.
The crotch belts purpose and only purpose is to help hold down the lap portion after you have cinched down the shoulder belts. Your crotch should never touch the submarine belt in an accident period. All the movement and flex that you want is in the hips and the belts themselves. Hence the reason why you should replace your belts after an accident.
I'm getting tired of these commando type of guys going out to track days thinking they are the shit with improper equipment added, when the factory stuff is good enough. If you want the added safety, go out, get a bar, harnesses and a proper seat. Then finalize the purchase with a HANS or other neck support system. Then go back out to the track.
Posted on: 2009/6/30 18:54
Frist, I'll apologize for my remark,must have clicked a link here to that other Corvette forum before I read this post, usually puts me in a mood. I probably wouldn't have done it if you had posted it here. Quote:
But you wrote this:
"I'm kind of leaning towards just using the OEM belts. The new seats I bought have a lot of support, so I'm somewhat hopeful that I won't need the "bracing" of the harness to hold me in place."
At least you did state that you had no problem spending the money on the equipment.
As far as mispelling stuff, I don't bother with a spell checker because I really don't care.
Posted on: 2009/6/30 23:22
Thst's one reason I favor the formula car style subs. Since they don't clip in but go thru D-rings on the lapbelt, you have to have your stuff out of the way when you're putting them on.
As far as replacing belts after an accident, I know how far a combination of my neck and Simpsons will stretch when you hit upsidedown from 8 feet in the air. The stretch can eaisly be over 3 inches, that's how much it took for my helmit to hit the track.
Posted on: 2009/6/30 23:29
