MK 82 | Firefox?? | ||
I was having trouble with no avatars and no quote or reply boxes.
I discovered that it is a Firefox thing as I have no problems with IE. I prefer Firefox because it doesn't crash like IE. I am running Vista. Anyone else use Firefox? |
Posted on: 2009/7/27 21:30
96 CE Roadster LT4 |
JonnyAngle | Re: Firefox?? | ||
I use FF and can see everything. I'm on XP though.
Posted on: 2009/7/27 21:39
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. |
pianoguy | Re: Firefox?? | ||
I run Firefox (3.51 now), but am not running Vista (Win2K on one machine, XP on another) - no problems here.
Posted on: 2009/7/27 22:54
Matatk | Re: Firefox?? | ||
No help here, sorry. I run xp with FF. Maybe BMW can chime in.
Matthew |
Posted on: 2009/7/27 23:13
CentralCoaster | Re: Firefox?? | ||
Did you post this while in FF?
If you're not logged in, it won't show those buttons. Avatars should work though unless you're viewing it in compact mode. |
Posted on: 2009/7/28 0:08
BrianCunningham | Re: Firefox?? | ||
FF here, on a Linux machine
Posted on: 2009/7/28 1:29
bmwgsa | Re: Firefox?? | ||
I've tested the site with IE, Opera and FF on XP, Vista and Linux (no IE on Linux) - it all works fine.
IE8 does have a weird problem, but nothing that would cause buttons to disappear. Do you have any addin's in FF? Which ones? Give me a little more so I can try and duplicate your problem..... |
Posted on: 2009/7/28 2:35
�It�s all devastatingly true � except the bits that are lies� I am fervently hoping to qualify for the category of "ageless" as opposed to "maturity impaired". |
Dads90 | Re: Firefox?? | ||
Mac person here, using both Safari and Fire Fox no problems.
Posted on: 2009/7/28 3:27
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
rogerwillson | Re: Firefox?? | ||
I know only that it is a browser.
Posted on: 2009/7/29 7:57
Mind Games |
