158 user(s) are online (133 user(s) are browsing Forums)
1963 through 1967 Corvette.
« 1 (2)
bogus Re: Maintenance Project From Hell
I will keep that in mind! Thanks!!!!
Posted on: 2009/7/16 0:14
WE HAVE VICTORY!!!!!
I got that damned seal installed! I took a lock ring compressor shaft thingy, turned it down a touch and the seal fit perfectly.
Slid it over the WP shaft and tapped away! It's all in perfect looking and stuff!!!
I will post some pics of my modified tool tonight.
Posted on: 2009/7/17 1:39
pianoguy Re: Maintenance Project From Hell
Excellent! Don't forget new o-rings for the coupler.
Posted on: 2009/7/17 1:45
Pics of the tool!
A couple of observations regarding that seal:
The seal itself, the rubber is very hard. It doesn't flex easily - as in getting on the tool - and seems to hold its shape for quite a while. I suspect that once it sets around the shaft, it ain't going no where, yo.
The tool makes install real easy. It lined up, the socket just tapped it home. So very easy.
jpg  _DSC0074.jpg (181.41 KB)
3_4a600c39180b8.jpg 653X542 px
jpg  _DSC0075.jpg (171.88 KB)
3_4a600c4653ca4.jpg 672X689 px
Posted on: 2009/7/17 5:29
BrianCunningham Re: Maintenance Project From Hell
Later optis, not sure of the early ones, had an o-ring inside the camshaft.
Make sure you dig that one out.
I thought mine came out with the opti shaft, it didn't, which is how I managed to install opti wrong, clocking was off.
Posted on: 2009/7/17 13:10
SpectatorRacing Re: Maintenance Project From Hell
Be VERY careful when you put this all back together. LT1's must have some oil leak somewhere or they explode. If you fix all the leaks your car won't know what to do and panic will ensue...
What are you LTCC guys doing with the rotor inside the opti? You have to have something to hold the disc to the bearing plate. I machined up some spacers that were the same thickness as the rotor base so I could use the same screws. Is that the same thing you guys did?
Posted on: 2009/7/17 17:52
BillH Re: Maintenance Project From Hell
I know one exception to this rule, Jon. And it has a MSD.
Posted on: 2009/7/17 17:54
I got the motor in last nite!
Man... getting the motor mount bolts lined up is really tricky!
Posted on: 2009/8/12 13:47
Glad to hear
Going to be nice with all the leaks fixed
Posted on: 2009/8/12 14:47
The clutch is in!!!!!!
Posted on: 2009/8/15 2:45
Good to hear, Andy!
Posted on: 2009/8/15 4:03
More good news... only to be tempered by annoying problems...
The trans is IN!
The rear ujoint exploded... so I am getting new ujoints for the drive shaft.
Posted on: 2009/8/16 2:09
Steve40th Re: Maintenance Project From Hell
1114 Posts
I use the DELTEQ, but what I did was cut the rotor down to just a round disc, then I loctited the screws and installed it.
Too put the WP seal on I used a cut-off sharpie. SLid right on too. No leakys so far.
Posted on: 2009/8/16 3:31
Ko'u ohana aia ku'a ikaika
Ujoints are OUT!!!!
Posted on: 2009/8/20 2:39
1Fast04Vert Re: Maintenance Project From Hell
Ujoints are OUT!!!!
Quick, turn around, you are going the wrong way. You want to put them in, not out.
But I guess your brakes will last longer.
Posted on: 2009/8/20 2:53
new ones go in tonight...
Posted on: 2009/8/20 13:56
The c-beam and drive shaft are in. What a sumnabitch to do.
Posted on: 2009/8/23 3:56
j3studio Re: Maintenance Project From Hell
I thought that was the L98!
Posted on: 2009/8/23 21:26
tobijohn Re: Maintenance Project From Hell
Palm Beach Gardens, FL
515 Posts
Aren't there some expensive whatchamacallits that make that job easier?
EDIT: Oh yeah, beam plates...
Posted on: 2009/8/23 22:33
John
1996 LT4 coupe black/black
AIRFOIL FREE!
beam plates help once the SOB is aligned...
The car is all but assembled. I need to finish some wiring, and that's it.
Posted on: 2009/8/24 3:08
TommyT-Bone Re: Maintenance Project From Hell
The final countdown. Good news!
[insert pic of Kevin holding wire bundle here]
jpg  Andy.jpg (8.28 KB)
852_4a9302de069ec.jpg 116X184 px
Posted on: 2009/8/24 21:23
Found a bug in the Helm Service Manual.
There are three reinforcement bars for the left side for the AC and alternator.
These brackets mount to the exhaust manifold. According to the book, the manifold has 2 studs, at bolts 3&4. Well... two brackets come off the AC compressor go to #3 bolt.
The other one is nearly vertical and goes to bolt #2! This one connects to the alternator.
Posted on: 2009/8/25 0:42
It's alive!!!!
I got it running last night. Tonight, I will be fine tuning things... I have a miss... more than likely caused by a bad plug wire or ground or something of the like.
Posted on: 2009/8/26 0:24
captmike13 Re: Maintenance Project From Hell
Hillsboro Mo
2165 Posts
That is good news Andy.
Posted on: 2009/8/26 0:57
13 GMC 3500 dually
captmike13@yahoo.com
I got rid of the misses and it ran pretty darn good!
It is all back together... the only thing now was me being an idiot... I left the hood open... and it killed the damned battery. So it's charging. I should be back in action tomorrow night.
Posted on: 2009/8/26 5:57
Oh well... I was checking under the car just now... there is a stain of oil. I have a leak.
I just don't know from where. I will check tonight when I can get under there. It may require me to start the engine and watch, but I might be able to find it.
The location, meaning, where the stain starts, is rather odd... I just don't know yet.
Crap.
Posted on: 2009/8/26 13:35
Whew. All is right with the world...
Check your valve covers. Mine are extremely sensitive, if they're not PERFECTLY aligned and nestled tightly on the head they leak in the back.
Hopefully it's that simple.
Posted on: 2009/8/26 14:38
That's what I did, I machined a little aluminum spacer so the screws weren't too long and installed it.
So far so good.
Posted on: 2009/8/26 14:40
OK
Photobucket
Posted on: 2009/8/26 14:55
It can not be oil!!! It must be ps fluid. I had run the engine sans belt... First time with belt - oil!!! Must be ps leak!!!
Posted on: 2009/8/26 17:40
oh cr@p that $uck$
how long after you put the intake on did you wait to fire it up?
(yes I'm thinking China wall leak)
Posted on: 2009/8/26 17:50
1114 Posts
My PS fluid hose on the 93 rubbed against the balancer and it sliced it open. Easy to fix though, JB weld or a new one.
Posted on: 2009/8/27 3:42
It was the compression fitting on the pump itself.
Whenever I do the rack, I will replace the pump and all hoses and the cooler. The poor cooler has been beaten to death by misplaced floor jacks.
But... it is running and seems to run just fine! The trans shifts just fine and the engine sounds great!
It's taken a long time, but it seems like it was all worth it!!!
Posted on: 2009/8/27 6:38
« 1 (2)
