311 user(s) are online (252 user(s) are browsing Forums)
BillH Champion Radiator
Finally got around to putting a radiator in the 92.
Bought the Champion that's been discussed here before.
The TIG welding is just OK, probably will last a long time.
Exact fit, just drop it in, hose ports are correct.
For $199.99 which includes $30 in shipping, I'm good.
jpg  IMG_1287.JPG (583.29 KB)
881_5779485100575.jpg 1600X1200 px
jpg  IMG_1288.JPG (509.03 KB)
881_57794860d9100.jpg 1600X1200 px
jpg  IMG_1290.JPG (613.00 KB)
881_5779486ce8962.jpg 1600X1200 px
Posted on: 2016/7/3 17:16
Schrade Re: Champion Radiator
More work than INJ swap???
Good pics there..................................
Posted on: 2016/7/3 17:23
BillH Re: Champion Radiator
Now for the bitch..........not at Champion but at GM.
Some sadistic son of a bitch at GM decided to put a big rubber air intake for the air pump in between the shroud and the frame. I think this is only on the 92's.
There's 3 screws that hold the upper and lower shrouds together. The clearance between the rubber intake and the screw head is 1/4 in., and the heads are 7mm. A 7mm wrench is only about 4 in. long (not long enough to reach the screw) and you can't hold on to the wrench because your hand won't fit between the rubber and the shroud.
Couldn't reach 2 of the screws underneath the car either but could get in there with a Dremel and a 1 in. cutoff wheel to cut the pointy end of the screws off and pop the spring speed nuts off.
All GM had to do was install the speed nuts on the lower shroud instead of the upper and you could reach them from the bottom of the car.
jpg  IMG_1291.JPG (696.18 KB)
881_57794b92bef0c.jpg 1600X1200 px
jpg  IMG_1292.JPG (613.38 KB)
881_57794b9f09e3e.jpg 1600X1200 px
Posted on: 2016/7/3 17:30
Hardly, the amount of work you're doing is impressive ( but I'm doing a tad more on the 67 Coupe).
Should have been a 3 hour job but........
I'd rather be workin' on the racecars.
Posted on: 2016/7/3 17:33
I pulled my AIR System when I did headers / exhaust.
This was long before exhaust write-up however; I think I remember that rubber coupler ('90) ...
jpg  IMG_5654.JPG (594.33 KB)
1687_577950cfd7bfc.jpg 2592X1944 px
Posted on: 2016/7/3 17:52
Actually, I can see it in your pic Chuck, right hand side two thirds of the way up. The black thing with the 2 slots in it.
Posted on: 2016/7/3 19:37
j3studio Re: Champion Radiator
BillH wrote:
Some sadistic son of a ...
So many things in the C4.
Posted on: 2016/7/3 19:49
BrianCunningham Re: Champion Radiator
a welded unit is the way to go.
Had BOTH stock side tanks break at a track event
Later cars get it from the aircleaner
At least some bean counter made it easier to work on.
Posted on: 2016/7/3 20:29
Matatk Re: Champion Radiator
Looks pretty good. Interested in the follow up of how well it cools.
Posted on: 2016/7/5 15:47
rklessdriver Re: Champion Radiator
Those 3 bolts on each side of the shroud of the later C4's are a real SOB.
I did the radiator in my 92 about a year after I bought the car and I did another one few yrs later on a 93 for a young Marine that worked for me.... neither of those cars got those bolts put back. I'm just not that big of a glutton for punishment.
That Champion radiator will do a good job for you Bill. The one I put in the 79 few yrs back is still doing great.
Posted on: 2016/7/5 17:55
GRIS Re: Champion Radiator
OKLAHOMA
7663 Posts
MATT, MY '95 HAS A CHAMPION THREE TUBE, COURTESY THE PO. IT HAS DONE GREAT, 190 DEGREES ON THE HIGHWAY IN THE OKLAHOMA SUMMER, AND THE FANS COOL IT DOWN IN TOWN.
Posted on: 2016/7/5 18:21
Test Drive, 25 miles.
First, it seems to warm up much faster than the old one. I let it idle to 125 before I drive.
It also seems to heat up slightly faster at the red lights but cools right down as usual.
On the interstate, it runs 2 degrees cooler (192). in 5th.
It does the same thing as the old radiator, either LT1 water pumps or my LT1 water pump doesn't like 1,700 RPM, the temps go up slowly (65 mph) put it in 5th and they go back to 192. I have to be going about 80 to use 6th.
Pleasantly, from a red light @ 194 , pulling the 4 mile hill from the valley to my house, it stayed on 194 which is better.
194 was the old freeway temp.
BTW this is the 2 row radiator.
Posted on: 2016/7/8 22:04
GOLDCYLON Re: Champion Radiator
Peoria, Arizona
23 Posts
Make sure you get all the air out of system. That might be why the temp swung up so high. GC
Posted on: 2016/7/9 15:57
Edited by GOLDCYLON on 2016/7/9 16:31:20
GOLDCYLON - 91 ZR-1 #2014
Resized Image380 P&P&PCed,Ported Heads,Jeal headers,/Corsas/FIKSE FM-5s /LED TLs, HID Projectors,/R Baer Eradaspeed Rotors with Wilwood 6 piston front calipers
Yea, the 92 LT1 has bleeders on the t-stat housing and the throttle body. Bleed them once= done.
Posted on: 2016/7/9 21:34
Peoria, Arizona
23 Posts
Yep just wanted to make sure you had did that. Cool beans
Posted on: 2016/7/10 0:04
