vetteblondie | Holy Cow - Sticker Shock | ||
on one of those 'red top' batteries - GEEZ LOUIZE!!!!!! Never got one before and everyone recommended them. Are they really worth that extra $100?
And it's STILL hard to start... |
Posted on: 2008/8/13 17:44
The answer to any question that begins with "Am I the only one who..." is always "no". �Ugol's Law Yes, I'm a bitch... just not YOURS. |
biggrizzly | Re: Holy Cow - Sticker Shock | ||
DIE HARD
WAL-MART All work great too. I'm using a battery I got at Autozone several years ago and it is still doing great. I keep it on a battery tender to keep it fresh. |
Posted on: 2008/8/13 17:46
CentralCoaster | Re: Holy Cow - Sticker Shock | ||
No.
Posted on: 2008/8/13 18:01
pianoguy | Re: Holy Cow - Sticker Shock | ||
I have a Fleet Farm battery in my car, works like a charm.
Posted on: 2008/8/13 18:29
CSS996 | Re: Holy Cow - Sticker Shock | ||
Mega Guru
I can't see myself ever spending big bucks on a battery. Wal-Mart is good enough. I've owned Die-Hard and never had any trouble. A couple Interstates have given me just a bit of trouble, but would buy another if Wal-Mart didn't have what I needed...
10% discount since the wife works there. 'Nuff said. |
Posted on: 2008/8/13 18:34
Currently "Between Vettes". |
red_johnny | Re: Holy Cow - Sticker Shock | ||
They are not worth it. I did a yellow top a few years ago and it ran the car audio stuff good with out dying but after 3 years the battery was toast.
Posted on: 2008/8/13 18:44
SpectatorRacing | Re: Holy Cow - Sticker Shock | ||
The optima batteries (or other gel cel types) are primarily good for two things:
1. Safety - they are full of gel instead of liquid so acid doesn't spray all over you if the battery is ruptured in a crash 2. Deep cycle - for cars that aren't driven much, or any car where the battery isn't regularly charged. If you discharge a battery enough times (let it sit and suck the juice out of it) it will destroy it. A deep cycle battery can recover from a full discharge more often than a normal one. If you don't need either of those things, you don't need a red top. |
Posted on: 2008/8/13 19:00
aka Scaryfast |
I thought the yellow or blue tops were for deep cycling?
They are also good for off-road or racing because they take the vibrations and hits better than a liquid battery, and give more more mounting options, in the car, under the car, etc. |
Posted on: 2008/8/13 19:28
Jeffvette | Re: Holy Cow - Sticker Shock | ||
Come back and bitch when you spend about 350 bucks for a battery.
Posted on: 2008/8/13 20:21
Could be. I never really looked at what the colors pertain to. I don't use an Optima. Perhaps the red tops are just an entry level gel cel. Quote: They are also good for off-road or racing because they take the vibrations and hits better than a liquid battery, and give more more mounting options, in the car, under the car, etc. True. I didn't figure that pertained in this case... Quote:
Must be a ZR-1 thing. Marine batteries aren't cheap;) |
Posted on: 2008/8/13 20:35
aka Scaryfast |
Matatk | Re: Holy Cow - Sticker Shock | ||
BTW, I don't think they are worth it. A lot of folks buy a good battery with a good warranty and just get 'em replaced for free/discount if they go bad Matthew |
Posted on: 2008/8/14 0:18
LOL, race weight, Odyssey or Braile. |
Posted on: 2008/8/14 1:02
BrianCunningham | Re: Holy Cow - Sticker Shock | ||
Spiral wound batteries are great at handling g-loads at the track. I've seen conventional batteries died because the plates have warped.
Posted on: 2008/8/14 3:57
vetteblondie | Re: Holy Cow - Sticker Shock | ||
heck, I bitch when I have to spend ANYTHING else, done enough already! Nevernind changing it is a pain in the ass. And, made me late for work.
Posted on: 2008/8/14 4:17
