skirlin | Half shaft Ujoints will not come out | ||
I had an AH-HA moment when I removed the right side shaft. The outer ujoint is completely shot, I am surprised it is still in one piece. I have everything out, spindle nut was fun but got er done. I followed the advice on previous threads about how to replace the joints using a vice and sockets. I broke the vice. Are they usually in that tight? I had one of my father's friends say put some heat to it and it will loosen right up. The shaft is aluminum and I have had some bad experiences with heat and aluminum. Help please.
Posted on: 2009/3/23 7:22
There is no point in living if you can't feel alive. |
BrianCunningham | Re: Half shaft Ujoints will not come out | ||
sounds like it might have welded itself to the halfshaft
Posted on: 2009/3/23 14:11
bogus | Re: Half shaft Ujoints will not come out | ||
Do you have a harbor freight nearby? If so, get their 20 ton floor press. About $120.00 usually.
Posted on: 2009/3/23 14:31
or take it to a parts store with a press
Posted on: 2009/3/23 14:33
Matatk | Re: Half shaft Ujoints will not come out | ||
Can you drill it?
Matthew |
Posted on: 2009/3/23 16:35
1Fast04Vert | Re: Half shaft Ujoints will not come out | ||
Do not use heat. Mine were too tight for a vise, I had to take them to a friend with a press, and also pressed the new ones in while I was there.
Posted on: 2009/3/23 17:34
Randy93 | Re: Half shaft Ujoints will not come out | ||
1st off, Brian change your avatar. I forgot what I was going to post, TWICE!!
Use a hammer with a socket the same size as the whole and beat it out, had to do that with mine. |
Posted on: 2009/3/23 18:44
BillH | Re: Half shaft Ujoints will not come out | ||
Using a vice is sometimes hard when the joints are old. And you need a decent vice to do it, a 5-6 inch at least because they are beafier. And cheap vices will break, that's why good 6 inch vices cost over $120.
Without a press, the hammer and socket works but, you can't use your small ballpeen. You really need a 3lb. short handle hammer. They're sometimes called drilling hammers. They're $12 or less. Once you get the bearing cup to move a little (break any corrosion), you can move to the vice. A little heat won't hurt at all but I wouldn't recommend an A/O torch unless you know what you're doing. The best small torcg is a Mapp gas one, looks like a prophane but gets quite a bit hotter (prophane's worthless). |
Posted on: 2009/3/23 22:14
Nope Matthew, The bearing cap's hardened. The entire cap has to be pressed out so you can dron the joint down into that hole. And if you used a drill bit the same size as the cap, you'd screw up the hole in the yoke where the new cap has to go. |
Posted on: 2009/3/23 22:18
CentralCoaster | Re: Half shaft Ujoints will not come out | ||
None of this makes any sense to me. Just drive a wedge in behind the ujoint to pop it loose. A vise is only used for installing it.
Posted on: 2009/3/23 23:48
vetteoz | Re: Half shaft Ujoints will not come out | ||
He is trying to get the uni cap out of the halfshaft eye ; not the drive yoke in the spindle / diff |
Posted on: 2009/3/24 0:16
jhammons01 | Re: Half shaft Ujoints will not come out | ||
^^Huh?
He is trying to get the u-joint out of the Half Shaft yoke. Anyway OP, just get anything larger in Diameter to put under the lower part of the yoke. Then get a Socket or something shaped like that you don't care to own anymore......place it on the u-joint cap and hit it with a hammer.......hard..... It is aluminum the cap will move easily within. This was just about the easiest u-joint I ever removed in 30 years of shade treeing..... |
Posted on: 2009/3/24 6:07
Posted on: 2009/3/24 13:55
skirlin | Re: Half shaft Ujoints will not come out | ||
CentralCoaster wrote:
None of this makes any sense to me. Just drive a wedge in behind the ujoint to pop it loose. A vise is only used for installing it. The shaft came out of the car rather easily. The problem was removing the joints from the yokes. Both sides were seized. I have replaced ujoints before and never had this problem. That is when I start asking people with more experience for suggestions. "^^Huh? He is trying to get the u-joint out of the Half Shaft yoke. Anyway OP, just get anything larger in Diameter to put under the lower part of the yoke. Then get a Socket or something shaped like that you don't care to own anymore......place it on the u-joint cap and hit it with a hammer.......hard..... It is aluminum the cap will move easily within. This was just about the easiest u-joint I ever removed in 30 years of shade treeing....." Absolutely, I did just that and it should have worked like you described, but didn't budge. Due to the lack of progress I decided to visit my local garage. It took him just under a half hour to get the job done. He said normally it is a very simple quick job but this time the shaft did not want to let go. He was all smiles when he got done, ah Victory. It cost me $36. I am happy. When an experience mechanic with all the right tools has a hard time, I don't feel so bad. Now I get to put it all back together . Thanks everyone. |
Posted on: 2009/3/24 15:31
Excellent!
Posted on: 2009/3/24 16:10
4 lb hammer......didn't work??
6 lbs Hammer....... Sledge hammer.... Hammer and bailing wire |
Posted on: 2009/3/24 18:43
