Dads90 | Hazy Windshield | ||
Does anyboby have the same problem ? I can use a Windex type cleaner twice. Then use Stoners for the final wipe and I'll be damned the window forms a hazy film again the very next day. I normally drive home into the setting sun and its more noticable at that point. I just want a clear windshield. Any suggestions ?
Posted on: 2009/6/24 3:23
1990 Silver Blue Metallic, ZF6, Hurst shifter, Z51, Dana 44 3.33 ratio, FX3 system, mostly stock. |
TommyT-Bone | Re: Hazy Windshield | ||
Now that you mention it ........ |
Posted on: 2009/6/24 3:33
CSS996 | Re: Hazy Windshield | ||
Mega Guru
Stop using stoners... They are lazy by nature.
Maybe it isn't so much what you're using to clean the window, as much as it is the stuff you use to clean the dash? Maybe the chemicals are leaving the dash pad during the heat of the day and depositing on your glass. |
Posted on: 2009/6/24 3:58
Currently "Between Vettes". |
Dads90 | Re: Hazy Windshield | ||
The Stoners doesn't have detergent so its not suppose to leave a film. I use a little california duster on the dash, don't put any cleaner on it. Im tempted to try some anti fogging junk, cause the defrost vent might be leaking cold air and contributing. |
Posted on: 2009/6/24 4:08
bogus | Re: Hazy Windshield | ||
It's caused by all the plastics off gassing.
I would use a home brew mix... an empty spray bottle, filled with hot water, a good shot of Dawn and a couple of ounces of ammonia. Shake and apply using 0000 wire wool. Then use Windex to rince off. |
Posted on: 2009/6/24 4:11
The home brew sounds like a go, but a little leary of the steel wool.
Posted on: 2009/6/24 4:21
0000 wool is very soft... hence the 4 zeros. It is used a lot in the window tint biz.
Posted on: 2009/6/24 5:31
pianoguy | Re: Hazy Windshield | ||
I bought some real fine white microfiber cloths last year that work great - you just use water to wet it, then wring it out until it's almost dry. Leaves no streaks or residue. I got them from somebody advertising on CF, but I think you can get them at auto parts stores. I'll see if I can find a link.
Posted on: 2009/6/24 10:35
Posted on: 2009/6/24 12:16
Matatk | Re: Hazy Windshield | ||
Is it hazy all over or just where the defrost vent is (ala bad heater core)
Matthew |
Posted on: 2009/6/24 17:48
BrianCunningham | Re: Hazy Windshield | ||
That's what I was thinking. |
Posted on: 2009/6/24 18:08
It is all over. Direct driver eye level thru to the passenger side. I can wipe my thumb pad across it to remove it. But it comes back. Maybe if I didn't breath it wouldn't fog. LOL
Posted on: 2009/6/25 3:22
BillH | Re: Hazy Windshield | ||
I use chrome polish on the outside of windows to remove water spots. Even use it with a foam buff pad on a drill.
Chrome polish on windows is a old hotrodder's trick. I'm currently using Mother's Mag polish. You may want to try it on a descrete spot. Was your car ever repainted? |
Posted on: 2009/6/25 13:18
DaleD | Re: Hazy Windshield | ||
My driver's side window was pretty bad. I used a clay bar on it, and it improved it a lot. Just a suggestion, YMMV.
Posted on: 2009/6/25 13:32
Whenever someone says "I'm not book smart, but I'm street smart", all I hear is "I'm not real smart, but I'm imaginary smart". |
