332 user(s) are online (282 user(s) are browsing Forums)
MK 82 Firefox??
Palm Beach Gardens, FL
439 Posts
I was having trouble with no avatars and no quote or reply boxes.
I discovered that it is a Firefox thing as I have no problems with IE.
I prefer Firefox because it doesn't crash like IE.
I am running Vista.
Anyone else use Firefox?
Posted on: 2009/7/27 21:30
96 CE Roadster LT4
JonnyAngle Re: Firefox??
Minneapolis, MN
151 Posts
I use FF and can see everything. I'm on XP though.
Posted on: 2009/7/27 21:39
pianoguy Re: Firefox??
I run Firefox (3.51 now), but am not running Vista (Win2K on one machine, XP on another) - no problems here.
Posted on: 2009/7/27 22:54
Matatk Re: Firefox??
No help here, sorry. I run xp with FF. Maybe BMW can chime in.
Posted on: 2009/7/27 23:13
CentralCoaster Re: Firefox??
Did you post this while in FF?
If you're not logged in, it won't show those buttons.
Avatars should work though unless you're viewing it in compact mode.
Posted on: 2009/7/28 0:08
BrianCunningham Re: Firefox??
FF here, on a Linux machine
Posted on: 2009/7/28 1:29
bmwgsa Re: Firefox??
Earth
735 Posts
I've tested the site with IE, Opera and FF on XP, Vista and Linux (no IE on Linux) - it all works fine.
IE8 does have a weird problem, but nothing that would cause buttons to disappear.
Do you have any addin's in FF? Which ones?
Give me a little more so I can try and duplicate your problem.....
Posted on: 2009/7/28 2:35
�It�s all devastatingly true � except the bits that are lies�
I am fervently hoping to qualify for the category of "ageless" as opposed to "maturity impaired".
Dads90 Re: Firefox??
Pearland, Tx
318 Posts
Mac person here, using both Safari and Fire Fox no problems.
Posted on: 2009/7/28 3:27
rogerwillson Re: Firefox??
8 Posts
I know only that it is a browser.
Posted on: 2009/7/29 7:57
Mind Games
