155 user(s) are online (91 user(s) are browsing Forums)
movnviolation Arrrggg #@$%!!!
Hesperia, Calif
188 Posts
Motor is in, looking good, Fires right up, and sounds like a beast!
Then water starts pouring out the drivers side header.
Shut it down, and a whole lot of bad words.
Well, what did I do now. Must have screwed up the head gasket some how. Brand new heads. Pull it down and when I pull the drivers side head and expect to see something, everything looks good. Now what. Motor only has about 5-6K.
Visually, the head looks good and the Felpro gasket is not distorted or anything.
I call AFR and ask them if they have had a problen with the 180 comp heads and was told There has not been a problem. They advised me to send both heads back and they would check them. I live within probably 75 miles from them so I would drive them there if that had to be. I am not ready to pull the right side down yet. I plan to take the head to my engine builder and have him check the head before I pull the other side down.
I don't know what the problem is. I permatex the new head bolts I ordered with the heads as instructed.
I was hoping it was something stupid I did, but as of yet, I can not find the problem!
I would like to say that I feel better now, but I dont!!
Thanks for reading!!
Posted on: 2009/1/17 6:08
Mods
cuisinartvette Re: Arrrggg #@$%!!!
Russ out of the exhaust pipe itself, the bolt hole?
Posted on: 2009/1/17 6:11
Calm Re: Arrrggg #@$%!!!
Vancouver, Canada
608 Posts
For what it's worth......I had the same exact experience upon firing up my fully done 383.
Freaked me out! Water squirting out my left tailpipe....then tons of white smoke while it warmed up! I wanted to shut it down immediately and tear into it....find the problem!
THEN it occured to me that when I originally pulled the motor (a few months before) I hadn't drained the block properly, and when the engine tilted (when pulled), a considerable amount of water spilled out into my exhaust manifold.
I let it run for another 15 mins and sure enough, it turned out to be trapped water in the exhaust system. WHEW!
I really hope that's the case with yours.
Posted on: 2009/1/17 6:57
happydad Re: Arrrggg #@$%!!!
northern Ill
151 Posts
I'm also interested in where it was coming from...Maybe we could help
Posted on: 2009/1/17 11:02
Matatk Re: Arrrggg #@$%!!!
22810 Posts
Hopefully it's like what calm experienced! Was everything snug? Any loose or missing bolts? I doubt the heads are warped, but try checking them with a straight edge if you already pulled it off.
Keep us posted.
Posted on: 2009/1/17 11:58
Midnight85 Re: Arrrggg #@$%!!!
Streator, IL.
264 Posts
Same exact thing happened to me, took about a 10 minute drive before all the water was burned out of the pipes. You should have done some testing before tearing it all apart.
Posted on: 2009/1/17 15:16
pianoguy Re: Arrrggg #@$%!!!
Man, that blows - hope it is something simple!
Posted on: 2009/1/17 15:19
movnviolation Re: Arrrggg #@$%!!!
Hesperia, Calif
188 Posts
Crankcase has water in the oil! Wish that would have been the problem.
Thanks!
Posted on: 2009/1/17 15:25
Mods
wesmigletz Re: Arrrggg #@$%!!!
Land of Fruits and Nuts
325 Posts
You may have had a leak where the intake and heads meet. Happened to me when we had my engine on a dyno.
Posted on: 2009/1/17 15:45
BrianCunningham Re: Arrrggg #@$%!!!
Posted on: 2009/1/17 17:29
Schrade Re: Arrrggg #@$%!!!
Do some of the OEM bolts extend into the coolant jackets?
Posted on: 2009/1/17 17:36
bogus Re: Arrrggg #@$%!!!
IIRC, yes, they do...
Posted on: 2009/1/17 18:17
Hesperia, Calif
188 Posts
You may be closer than you know! I had the heads milled from 65cc to 58cc at AFR when I ordered them. I called TPIS and asked them if I had to have the Miniram milled to match. I was told "No!" I am questioning this now.
Any thoughts?
Russ
Posted on: 2009/1/17 20:58
Mods
that could do it.
actually it was the 1st thought that occured to me.
Posted on: 2009/1/17 21:05
anesthes Re: Arrrggg #@$%!!!
Boston, MA
Any thoughts?
Russ
A lot of people make that mistake the first time around.
If you angle mill the heads, you MUST angle mill the face of the heads where the intake sits. You never ever ever mill an intake manifold. ever. That would be foolish, because you would be married to the intake forever and if you wanted to change you'll have to have another intake milled.
Now I'm assuming since you had AFR mill the heads they would have done the intake face (and you would see it)
but people make mistakes. I usually check all my clearances before I bolt it up.
-- Joe
Posted on: 2009/1/17 21:58
Hesperia, Calif
188 Posts
I checked the paperwork I received with the heads, and it said the heads were flat milled. Said nothing about angle milling.
Also, I looked into the ports of the pass. side head still on the motor, and there is coolant sitting on the closed valves. Acually I could have stuck my head is as those ports are huge.
I am only a novice, but things are sure looking like intake, not head problems.
Posted on: 2009/1/18 0:00
Mods
post some pics, including the gaskets
Posted on: 2009/1/18 0:17
Hesperia, Calif
188 Posts
It takes me days to try to post pics. However I would not know what to take a picture of. The head looks new, and so does the gasket. Absolutely no marks or distortions.
It seems everything is pointing at the intake. I will have the head checked locally rather than taking it to AFR at this time!
Thanks for the responses!
Posted on: 2009/1/18 3:13
Mods
I bet its as Wes said. A slight mill on the intake wont hurt anything tell your machinist how much they cut off the heads...dont do it unless you have to though. . You may be able to get away with using a thicker intake gasket. I bet $ thats the issue.
Sorry to hear you gotta tear that back down.
Posted on: 2009/1/18 3:23
BeachBum Re: Arrrggg #@$%!!!
751 Posts
Thicker gasket and/or double gasket can sometimes solve these problems. In any regards, its no big deal and I doubt you hurt your motor.... drain it, run some new oil once you get the motor going for a couple of minutes, then swap oil again.
good luck !
Posted on: 2009/1/18 4:03
C4 Corvette 436 - Pure Black
cuisinartvette wrote: You may be able to get away with using a thicker intake gasket.
Ditto on the thicker gasket.
Last week, lookin' at some aluminum exhaust gaskets, they were close to 1/10" thick - .094. If you can find aluminum INTAKE gaskets like that, you could shave THEM...
Posted on: 2009/1/18 4:13
Hesperia, Calif
188 Posts
The gaskets might be a way to go, however, I don't want to tear this down again incase that does not work. If the head is ok, and the machinist can make things right I will probably have him do it.
The car sounds like it will be a beast, and I will never do another. If the intake will only work on my heads, that ok.
Posted on: 2009/1/18 5:25
Mods
Vancouver, Canada
608 Posts
If it were me I'd definately call AFR and confirm that they did an angle mill on the intake. If not, take them back and have AFR complete the job! If AFR did indeed do the intake surface, I'd have the machine shop simply check and re-surface the intake if needed.
Posted on: 2009/1/18 6:33
Hesperia, Calif
188 Posts
The paperwork says flat mill to the heads. No angle mill was performed.
Thanks
Posted on: 2009/1/18 14:54
Mods
Vancouver, Canada
608 Posts
Thanks
I understand that. But placing a call to confirm they actually "forgot" to angle mill may save you a 75 mile trip. My entire point being that certainly they didn't forget to angle mill! I don't know the math, but it would seem alot of material was taken off the surface to get chambers down to 58cc. I understand that they can angle mill the head surface to minimize the change to intake alignment, but is that enough without also milling the intake surface? Only their machinists would know that.
As I said, I would ensure their heads are perfectly machined before going on to other issues.
Best of luck.
Posted on: 2009/1/18 17:37
Hesperia, Calif
188 Posts
Thanks
Best of luck.
Gotcha, and good point! I really don't understand the arts of milling, but learning fast the hard way. I will be calling them Mon. A.M. also calling TPIS.
I guess I thought just taking meat off the bottom of the heads would simply drop the heads without changing the angle. Obviously not so! Assuming the problem is the intake.
And to think we do this for relaxation and enjoyment!!!
Posted on: 2009/1/18 17:52
Mods
Russ get a thick intake gasket I bet youll be Ok. I had my heads severly angle miled (different than flat but still...) and the intake done accordingly. I still had to use a thick gasket to get it to seal, not a big deal but a PITA when you realize you have to rip the intake off, thas hot rodding. It will seal up.
Email tony with your issue, he'll help you sort it out.
tony@airflowresearch.com
Posted on: 2009/1/18 18:10
Vancouver, Canada
608 Posts
LOL. No kidding, huh?
Posted on: 2009/1/18 19:11
Did you get gaskets to match the miniram NOT having a cooling passage in the back?
Posted on: 2009/1/18 20:01
Hesperia, Calif
188 Posts
The gaskets came with the Miniram. They do have water passages front and rear. Heads, miniram do not!
Posted on: 2009/1/19 2:59
Mods
Why don't the heads???
EDIT:
They don't look like this do they?
Photobucket
Posted on: 2009/1/19 3:04
TonyMamo Re: Arrrggg #@$%!!!
54 Posts
Welcome to the world of high performance engine building....LOL
To clarify, your heads were in fact angle milled to 58cc and the intake interface corrected after that machining op (and headbolt shoulders spotfaced). Look at your paperwork next to the $260 charge for the angle mill operation. We only flatmill to 60 cc (max)....any less always gets done with an angle mill.
My guess is your problem stems from the fact your intake manifold might be hanging up on the end rails of your block (before the interface gaskets have been sealed/crushed) requiring either the bottom of the intake be machined and/or the use of a thicker gasket so when you torque down the manifold the end rails don't bottom before the gaskets along each side of the head (which are sealing water and air obviously).
The key is which course of action is better for performance (thicker gasket or machining the bottom of the intake that sits parallel with the block end rails). That answer is best handled by evaluating which option will better line up the intake ports of the manifold to the entrance of the cylinder head intake ports. If the intake is sitting low (in relation to the ports), a thicker gasket will raise it up solving both your problems (potential sealing issues and port alignment). If the manifold and runners line up nicely now (which means a double thick gasket will raise the manifold higher causing further misalignment), then the better approach is to mill the intake to clear the end rails and use a standard thick gasket once again.
I hope this helps and I hope my hypothesis into your problem might be on the right track.
Regards,
Tony
Posted on: 2009/1/19 17:37
dan0617 Re: Arrrggg #@$%!!!
IF the manifold is hitting on the china walls of the block before sealing the ports and water passages, wouldn't it be possible to eliminate the china wall gaskets and just use a bead of permatex there to help gain some clearance?
Posted on: 2009/1/19 18:01
54 Posts
Sure...that would help and offer some additional clearance.
To be honest, I never even use the endrail gaskets....silicone correctly applied works great and has less chance of leaking IMO.
-Tony
Posted on: 2009/1/19 18:40
That's all LTX engines ever used.
Just let it sit and cure for 24hr before you fire it up.
Posted on: 2009/1/19 18:54
54 Posts
Yep...
I wasnt sure if on some of the later model stuff some gasket manufacturers included them or not (endrail gaskets).
Best way to check and see if your manifold is bottoming is to find some .060 washers, spring shims, whatever (I use valvespring shims), and place one in each corner leaned against the head so when you drop on the intake the shims represent your .060 crushed gasket thickness. You should be able to slide a thin feeler guage at the least between the end rail and the lower parallel face of the intake. If its hanging up on the end rails (zero clearance), the manifold wont even sit squarely on the shims unless you increase their thickness lifting the manifold off the endrail now allowing it to properly rest in the "V" created by the cylinder heads intake interface.
-Tony
Posted on: 2009/1/19 19:22
Hesperia, Calif
188 Posts
I did use permatex on the ends, not gaskets. I saw a nice bead at both ends of the intake after I took it off. I don't believe it is bottoming out. I will have to check however. I am not at home now.
If I understand this correctly, and my heads were angle milled, this would mean that the intake surface of the heads were angle milled also. Therefore any intake should seal up, correct?
Tony is probably correct if it shows the heads were angle milled, they probably were. The head and intake will be at the shop in the A.M.
Posted on: 2009/1/20 3:16
Mods
Boston, MA
I always use a bead of "the right stuff".
While, Tony could be dead on. I don't think I've ever had an intake hang up on the china wall. I took like 12CC off my heads, and took about .020" out of the decks on the block and the intake seals fine with a felpro 1205.. But hey, every block is different.
-- Joe
Posted on: 2009/1/20 4:09
Hesperia, Calif
188 Posts
EDIT:
Photobucket
My mistake, heads have front and rear passages, intake does not! Did not have a chance to check until now. Was not shinning you on!
Thanks
Posted on: 2009/1/20 15:58
Mods
Russ dont worry about the intake not having passages if the intake seals up it wont matter. If you want to get trick you can drill and tap a 1/2" or so hole in the intake where the passages "would" line up, use 2 brass fittings and connect the 2 with hose. Theres another way to route also but wont work with the mini. Not a must do just something else to spend money on I guess.
Blad, you cant grind intake gaskets down
Posted on: 2009/1/20 16:16
Keep us posted on the progress and the solution!
Posted on: 2009/1/22 13:00
Hesperia, Calif
188 Posts
Well, decided to put everything back together and check all clearances on the ends of the block. Got Mr. Gasket 1/8" thick intake gaskets and set them on with the intake manifold on top. Plenty of clearance. Lifted the intake and put a lot of silicone on the ends. set the manifold and torqued it down. Beautiful seal, manifold nice and straight. All the sides were even. Put the R/R's back on, headers, hooked everything back up and start the beast. Lights right away and here comes the water again. Same thing.
Both heads are comming off on sunday (tomorrow) and my son has to go into L.A. on tuesday and he will take the heads back to AFR and let them check them out.
Called AFR on Tues and they checked the shop paperwork.
Was told that the heads were flat milled .020, and angle milled .046. Not sure what that means. Erik said that he would recommend using 1/8" gaskets. He also said that the heads are tested prior to shipping.
Thats where I am at right now!
Kinda wish that I would have just replaced the T/O bearing that started all of this and been done!!
Thanks for listening.
Russ
Posted on: 2009/1/24 6:14
Mods
22810 Posts
Is your son taking the intake with him, too? I don't know if that will make a difference or not if AFR is "only" checking the heads, but might not be a bad idea?
Posted on: 2009/1/24 12:23
