305 user(s) are online (251 user(s) are browsing Forums)
cor123, more...
The Natio...
BrianCunningham I'm glad I got the 4wd option on the truck
I've never felt more comfortable driving in snow.
I've also see multiple 2wd pickups either sideways, or off the road
Posted on: 2009/12/9 14:48
BillH Re: I'm glad I got the 4wd option on the truck
Ha, you ought to ride in my Silverado, it's one wheel drive .
Posted on: 2009/12/9 14:52
CentralCoaster Re: I'm glad I got the 4wd option on the truck
I can't even keep my 2wd pickup planted in the rain.
Too much torque!
Posted on: 2009/12/9 14:56
BrianCunningham Re: I'm glad I got the 4wd option on the truck
Too much torque!
I've noticed I need to keep it in 4wd for the rain as well.
BTW it's definitely 4wd not Awd
Sharp turns in a parking lot you can hear the tires chirp!
You can also hear the drive gears going down the road.
Heavy duty units all the way.
Posted on: 2009/12/9 15:02
pianoguy Re: I'm glad I got the 4wd option on the truck
Good day to have winter tires here.
Posted on: 2009/12/9 15:31
Andrew Re: I'm glad I got the 4wd option on the truck
Jefferson City, MO
447 Posts
Hmmmm... this isn't very good on the drive train. I wouldn't recommend this at all, unless you know you are not going to turn. The only time I've ever used 4x4 on the road was in snow, ice, or pulling a boat up a boat ramp.
Does your truck have a Detroit locker or breadbox setup?
Posted on: 2009/12/9 15:52
2003 Atomic Orange Z06
SOLD 1979 4 Speed with 383
I'm not sure, but my commute is on local roads.
I'm thinking the same thing though, keep it in 2wd unless it's really nasty out.
I've fishtailed a couple of times in the rain.
I need to get a cover on it so I can weigh the back down.
Posted on: 2009/12/9 15:57
Jefferson City, MO
447 Posts
If you are not sure, then you don't have Detroit lockers. They have a very distinctive and unmistakable clacking sound when going around a right or left turn. I would definitely not drive in 4x4 on the street, unless it is slippery enough for the tires to spin without forcing all of the stress on the driveline components!
Now come on Brian, fishtailing in a truck is fun and relaxing, after fishtailing in a C4, especially that car you've been building!
Posted on: 2009/12/9 16:04
LOL
Posted on: 2009/12/9 16:18
My 2wd Silverado will light up the tires easily in the wet with the 3:73. But, if you drive it easy it won't fishtail at all. No one I know uses 4wd in the rain.
I do put weight in the back in the winter, this works really well:
gif  yhst-47899628452395_2078_1651678.gif (0.00 KB)
Posted on: 2009/12/9 16:25
Ultraman Re: I'm glad I got the 4wd option on the truck
14751 Posts
My 1/2 ton Chevy's have an auto button that you can push which leaves it in 2wd unless it starts to slip then the 4wd kicks in. It's not that way on the 3/4 ton stuff, there it's one or the other. We got 10 inches and a lot of drifts.
Posted on: 2009/12/9 16:57
tjpreul Re: I'm glad I got the 4wd option on the truck
I have a S-10 with the zr2 package. It is nice because it has the RPO G80 (limited slip). Which if one wheel starts to spin there is a small weight that catches and locks the diff. I think it has to be around a 6mph difference. I can tell the difference in the snow.
Posted on: 2009/12/9 17:26
Sweet90 Re: I'm glad I got the 4wd option on the truck
Edmonton, Alberta
1143 Posts
Personally, up here 4WD - AWD should be manditory.
Jim
Posted on: 2009/12/9 18:29
I don't think anybody's putting detroit ratcheting lockers in new pickups. They are junk. And all the manufacturers are into those electronic lockers now.
Posted on: 2009/12/9 19:39
Jefferson City, MO
447 Posts
I agree! New trucks don't use them. I didn't know if his truck was old or new. However, lockers are great for true off roading.
Posted on: 2009/12/9 20:14
Matatk Re: I'm glad I got the 4wd option on the truck
I love my 4wd and have used it the past few days now that the bad weather is starting. I have highway tires on my xterra that I found out suck in the snow w/o using the 4wd. My wife's rogue is selectable awd which is nice, too. No more winter cars for me without awd/4wd.
Posted on: 2009/12/9 23:25
It's THUNDERSTORMING out now
I took your advice and stuck in back into 2wd
The truck seemed happier.
Posted on: 2009/12/10 0:33
Good, I flick off the 4wd as soon as the road changes from snow to wet.
For a real 4wd/snow experience nothing beats:
Coming back, fairly burnt out, from Laguna Seca 3 day race.
4 1/2 hours done out of a 6 1/2 hour tow.
4wd Excursion towing a 24 ft. enclosed trailer (8,000lbs.)
On I80, its raining in Sacramento, hit snow at Auburn.
Headed towards an 8,000 ft. hill.
30 mi past Auburn, the CHP has the road blocked off as usual checking for snowtires/chains.
I stop at the checkpoint, road conditions are now R3, chains mandatory. Oh by the way, you have to chain up one trailer axle too.
It takes 3 hours to go 50 miles.
Funny thing about Donner Summit is that you don't see 2wds in the ditches but you see a bunch of 4wds in the ditches every time.
Posted on: 2009/12/10 2:55
1Fast04Vert Re: I'm glad I got the 4wd option on the truck
Sure glad I don't have to worry about snow: 1. I am in Geaorgia, 2. I am retired so don;t have to worry about it anyway.
But my RAM 2WD has the 5.9L and will burn the rubber off the tires about anytime I want it to. I do have to be a little carefull on the wet roads though.
Posted on: 2009/12/10 3:47
There are some downsides to using lockers on icy roads. A locker is good if you're stuck in a ditch, but more likely to put you in the ditch to begin with.
With an open diff, one wheel will slip, but the other might maintain traction. With a locker, they both slip. And the locker is more likely to cause tire slip around turns if it doesn't unlock.
Posted on: 2009/12/10 4:35
Jefferson City, MO
447 Posts
Yep, that's a great way to describe it. Lockers are great for hard core off road use (rock climbing, going through deep tire grooves or ditches, or deep mud), but not so great on the road. With that being said, it's even better to be able to control the lockers through an Atlas system. Attached is when you need lockers.
This is why I get a kick out of folks saying how well their positrack 2wd trucks do on the road, which most of the time is really limited slip.... but that's a whole other story.
jpg  Picture 405.jpg (0.00 KB)
Posted on: 2009/12/10 15:00
Is that your rig? Where is that trail?
Posted on: 2009/12/10 17:32
Jefferson City, MO
447 Posts
I wish this was mine. A friend at work used to own this YJ, but since has upgraded. This was taken in CO. I have owned some TJ's and a truggy. Currently I do not have an off road toy, but will again. Good 4 cylinder TJ's are not expensive. This is a hobby like Corvette's. Buy and build as things break. Off roading is a blast!! I don't have the guts to do what my buddy did in that picture though.
Posted on: 2009/12/10 18:14
What about a TruTrac (screw differential)?
http://www.corvette-guru.com/modules/ ... hp?topic_id=10461&forum=1
http://www.eaton.com/EatonCom/Product ... DetroitTruetrac/CT_130283
The Detroit Truetrac was the first helical gear differential ever introduced into the automotive aftermarket as an Eaton brand. It remains the leading helical gear-type limited slip differential in the industry. Detroit Truetrac's proven helical gear design eliminates the need for wearable parts, resulting in maintenance free traction recognized not only for its toughness, but its smooth and quiet operation as well.
Posted on: 2009/12/10 18:20
This is my brother's in Johnson Valley. I wouldn't mind buying it off him. I guess I'll have to just build my own.
Posted on: 2009/12/10 18:33
Jefferson City, MO
447 Posts
Brian, I don't know much about that particular product, but have seen the Eaton eLocker system at work. They seem to make good diffs.
CentralCoaster, that makes me want another one!! Nice rig. I can see a Toyota rear diff, but what is the transfer case and front diff? I also like the self made rocker crush guards. Have you ever been wheelin' with him? Just a warning, if you go, you'll be hooked. It's a wild feeling reaching out of a lifted vehicle window and touching the ground... The fun part about building these is it does not have to look good. So it is easier to hack, experiment, then hack again, knowing that dents, dings, scratches, and weld marks are battle scars and are welcome. Just a different type of auto hobbie.
Posted on: 2009/12/10 19:22
Haven't in awhile. I've driven it a little, and his Landcruiser.
He has a 4.3L vortec motor in there, a Marlin Crawler double transfer case, I recall he's geared at about 200:1 in low range.
Posted on: 2009/12/10 19:32
