djxib | Check out these emissions numbers | ||
1992 LT1, LT4 heads, stroked to 383, forged internals, Vortech supercharger 12psi, alky injection, stock headers, x-pipe and borla mufflers. Air injection and EGR still operational:
25/25 Test: HC PPM 26 (allowed 117) CO % 0.02 (allowed 0.65) NO PPM 22 (allowed 821) CO+CO2 % 14.6% (minimum 6.0) 50/15 Test: HC PPM 22 (allowed 120) CO % 0.1 (allowed 0.67) NO PPM 49 (allowed 907) CO+CO2 % 14.5% (minimum 6.0) These results are even better than last year's test, plus I have burnt around 40 chips since the last test! I think I'll celebrate with a couple of cold ones tonight. Cheers Gurus |
Posted on: 2010/1/16 20:18
Andy 1996 Greenwood Collectors Edition LT4 Previously 1992 Convertible Polo Green. 383 LT1/LT4 forged/balanced. V7-YSi, Alky. 608RWHP... Now sitting at a dismantler with a salvage title. Still runs... |
88BlackZ51 | Re: Check out these emissions numbers | ||
timing was bumped down?
Posted on: 2010/1/16 20:24
djxib | Re: Check out these emissions numbers | ||
Timing is completely stock when not in boost.
Posted on: 2010/1/16 22:19
bogus | Re: Check out these emissions numbers | ||
sweetness!!!
Posted on: 2010/1/16 22:23
Matatk | Re: Check out these emissions numbers | ||
Who says a modified motor can't pass emissions!
Posted on: 2010/1/18 2:47
pianoguy | Re: Check out these emissions numbers | ||
Outstanding!
Posted on: 2010/1/18 4:01
BrianCunningham | Re: Check out these emissions numbers | ||
congrats!
Posted on: 2010/1/18 15:56
Jeffvette | Re: Check out these emissions numbers | ||
What is the 25/25 and the 50/15 test?
25 mph for 25 seconds and 50 mph for 15 sec? |
Posted on: 2010/1/19 2:23
25% load for 25 seconds and 50% load for 15 secs. Precisely what "load" is I have no idea. I think this might be a Ga-specifc test. Also, see autoblog or Google "Prius GA emissions" for some fun on how they couldnt do emissions testing on the Prius... |
Posted on: 2010/1/19 4:31
1Fast04Vert | Re: Check out these emissions numbers | ||
Nice numbers Andy. Looks like you are good for another year.
Posted on: 2010/1/19 14:40
flyboy | Re: Check out these emissions numbers | ||
Excuse my ignorance, but is there a cat. converter? If not, I guess they don't do a visual.
Posted on: 2010/1/19 14:48
jaa1992 | Re: Check out these emissions numbers | ||
Andy - great numbers.
Got mine back together with headers and everything back together. Its time to start working on my tune. You going to wosch's Sat? |
Posted on: 2010/1/26 2:49
