148 user(s) are online (96 user(s) are browsing Forums)
dan0617 D44 swap....and D36 diagnosis
Took 2 hours for me to get the car up and supported, wheels off, X brace off, and exhaust off. Next day, took 2.5 more hours to have the rear out and on the ground. Went MUCH quicker than I thought it would, this is my first time screwing with an independent rear (other than 1/2 shaft U joints).
[IMG]http://i250.photobucket.com/albums/gg259/dan0617/DSCF0029.jpg[/IMG]
[IMG]http://i250.photobucket.com/albums/gg259/dan0617/DSCF0032.jpg[/IMG]
I took the batwing off the D36. All looks great inside, with the exception of the bearing caps and spider gears. Both bearing caps are broke and 2 spider gears have teeth missing. The rear was clunking a little when going around a corner and had an axle seal and pinion seal dripping a little, but other than that was still going strong.
[IMG]http://i250.photobucket.com/albums/gg259/dan0617/DSCF0030.jpg[/IMG]
[IMG]http://i250.photobucket.com/albums/gg259/dan0617/DSCF0033.jpg[/IMG]
[IMG]http://i250.photobucket.com/albums/gg259/dan0617/DSCF0034.jpg[/IMG]
Not as bad as I expected it to look in there. I have an old D36 here with a broken case, perhaps I can use the spider gears and bearing caps from that rear to fix this one and sell it. I'd have to figure out how to pull it apart. Or, if anyone is interested I'll sell this one as is for $100 and give you the old broken one also, so you can pull parts out if it and fix this one. They both have 3.07 gears but the broken case one has gears that are pretty rusted up.
For the D44, I have both a D44 batwing and an adapter plate to drill my D36 batwing and use it. I think I'm going to try the adapter plate and D36 batwing. It appears that the structural strength of the arms of the batwing are identical on my D36 and D44 batwing. The plate should add a little strength to the case if anything so I'm going to try it. If all goes well I'll sell the D44 batwing to recoup some cost.
Posted on: 2010/2/2 14:56
pianoguy Re: D44 swap....and D36 diagnosis
Nice work!
Posted on: 2010/2/2 15:23
RestoMod57 Re: D44 swap....and D36 diagnosis
Phoenix, AZ
55 Posts
There is a fairly recent string on some steps of rebuilding the D36 - if you want to tackle it.
http://www.corvette-guru.com/modules/ ... pe=&topic_id=7466&forum=1
I recently rebuilt mine, also 3.07, but I installed 3.54 gearing instead. It's not difficult, just time consuming. If you do, I would also suggest replacing all bearings, cups and seals. Timken makes the original bearings and I found their fitment to be perfect. Don't buy the other brands if possible - one of the differential cups was much thinner than the original when I bought it as a "package" from JT's.
You will also need setup bearings, probably new clutch packs, and specialty tools (dial indicator at minimum).
There are very experienced gurus here that know alot more about it than I do - just letting you know some FYIs I found.
Good work, it looks great!
Posted on: 2010/2/2 16:38
pr0zac Re: D44 swap....and D36 diagnosis
awesome.. that is impressive. you are lucky it stayed together like it did. that is a fair amount of damage. lol
Posted on: 2010/2/2 17:40
dan0617 Re: D44 swap....and D36 diagnosis
Thanks for the advice. I might get into it after the car is back together, but it sounds like I'd have more money in it than I could sell it for.
Posted on: 2010/2/2 18:18
I am surprised. Before putting it in the garage I did a hard launch from about 5 to about 80 to see how the afr was in cold weather since it was 20 degrees outside and I run open loop. The rear held up fine. I can't believe it didn't eat itself up since it was flexing around in there.
Posted on: 2010/2/2 18:20
rklessdriver Re: D44 swap....and D36 diagnosis
I gotta agree with pianoguy. NICE WORK!! (on destroying that D36)...
Just FYI you can't just swap the cap from one center section to another. They are line bored at the factory like the main caps on an engine block. It would have to be line bored again to be fixed correctly and that might cost more $$$ than its worth.
You might get lucky just swapping one and it be round enough to get by... but it might not be and then you end up selling someone a D36 grenade waiting to happen.
Posted on: 2010/2/2 22:38
Matatk Re: D44 swap....and D36 diagnosis
22812 Posts
Wow, that's pretty rough, huh? I'm far from a differential expert but I think cracks and missing pieces are bad
We have to remove the diff in the 79 for repair this year. I'm not sure if I want to try it myself or just pay a shop since I know zero about them and don't really have the right tools (although my dad being a machinist has all the dial indicators, etc, needed). Keep us posted on the work and if you find a good book on how to rebuild them.
Posted on: 2010/2/2 23:00
Good Book? My good book has been Azzato's thread from the other forum from along time ago for the rear swap. I'm also swapping over to poly-graphite bushings everywhere and your thread on that has been my good book. Thanks!
As for the rear, I never did an independent so I was a little worried. It is pretty straightforward, or at least it has been so far. My biggest problem so far is not owning enough metric wrenches.
For progress tonight: I removed the batwing bushings and replaced them, then I drilled my D36 batwing to match the adapter plate, "right stuffed (lol)" the mating surfaces, and assembled. I'm doing the car in my in-law's garage, but I'm doing the assembly work and such in my basement. So, I then went to the car and swapped out the c-beam and slid in the D44 driveshaft. I then removed the trailing arms from the passenger side, brought them home, removed the bushings and put in new.
As for my method of removing bushings, thanks Matatk. I'm drilling 8 or so holes through the rubber around the metal center, then beating the center out and using a screwdriver and hammer to beat the rubber out. As usual, I make due with the tools I have instead of purchasing a press. Works though.
Posted on: 2010/2/3 2:52
22812 Posts
Thanks for the compliment, and it seems you're making progress. I'm looking for a book maybe on rebuilding the innards of the case, if you decide you are going to do it, as well.
Posted on: 2010/2/3 12:19
PeteK Re: D44 swap....and D36 diagnosis
One thing to keep in mind is that bearing caps cannot be interchanged. Like an engine, the caps are line honed to size. If the cap you install in place of the broken one is (dimentionally) slightly:
Smaller
Larger
or off center than the other "1/2" of circle, bad things can happen.
You may get lucky swapping caps, or you may not.
Posted on: 2010/2/3 15:39
i read a while back of a company that installed billet caps on d44 cases and they didn't require honing. they sold them until the cases became too hard to track down. i can't think of the name of the company.
Posted on: 2010/2/3 18:01
I sold the rear as-is, and included a used set of bearing caps and a used carrier. The buyer can piece together a usable rear or have it re line honed or whatever might be necessary, but at least this way he has necessary parts and can decide what work to do or not to do himself. Less money for me but this way I won't feel responsible if I piece something together and it doesn't last. If I were fixing it to reuse it I would have just assembled it and ran it till it died. It was actually still working pretty well with 2 completely broken bearing caps and 2 spider gears with missing teeth so chances are it would have lasted quite a while with just putting in the "new" gears and caps and seals.
Posted on: 2010/2/4 21:34
Yesterday's progress.....got the trailing arm bushings all installed and trailing arms back on car, then dropped the tranny pan and changed the filter.
PETEK....couple of questions please....
There was a fairly heavy amount of blackish, dark greyish sludge in the filter and some greyish sludge stuck to the magnet in the tranny pan. No chunks or filings stuck there, but it must have been metallic somewhat or it wouldn't have been stuck to the magnet. The fluid looked very good....still red, still smelled like new, no filings or discoloration or anything.
Is this fairly normal for a trans that has made a couple dozen mid to upper 10 second passes at the strip, probably 50 hard launches on the street, and about 3000 highway and street miles??? I bought the trans last winter and put it in, it has 1 season on it. Only problem I have noticed is that it acts like the governor is sticking a little when the trans fluid is cold, I'm now thinking because the filter was sludged up some. Have you torn apart a beefed up 700R4 or changed the filter in one after a season of racing? What do you find in the pan and filter if it is healthy? And what do you see if it is not healthy?
Some people say this is normal for a trans like this being used like this, and some are saying any metallic like substance is bad news. Again, no filings at all, just a grayish sludge stuck to the magnet and a blackish sludge in the filter.
Posted on: 2010/2/4 21:40
Today I got the new rear up in the car and bolted in. Not real easy to do when working by yourself! Got the batwing bolts torqued, the C-beam bolts torqued, the driveshaft and 1/2 shafts hooked up, then removed the dogbones and brought them home for new bushings. Won't be long I'll be up and running.
What brand and viscosity do you guys recommend for rear differential fluid? I'd like to go synthetic, if I do, do I still need to add the bottle of friction modifier?
Posted on: 2010/2/5 21:00
I would not be thrilled about sludge in the filter. The black sludge in the pan is friction material. What you ae describing sounds a bit excessive.
Posted on: 2010/2/5 22:17
I got into the filter further today, wasn't as heavy as I thought but was a layer on the filter paper. Looks like the same stuff that was in the pan. I was worried because it stuck to the magnet, meaning it had metal in it. I was expecting some black, always find that even on a normal non high performance trans when I do a filter change, but wasn't expecting anything metallic at all. I guess I'll just run it till it quits, or maybe it won't quit.
Pete, what do you use for differential fluid? And what front and rear shocks do you drag race your 'vette with, if you don't mind me asking?
Posted on: 2010/2/5 22:24
I use gm fluid and additive. A local guy does arca races and that is the fluid they found to be best.
Shocks are bilsteins.
Posted on: 2010/2/5 22:27
Cool. I'd have thought you were running adjustable shocks. I'm not sure if I should spend the cash on adjustables or just go with some monroe's or something like that on the back.
Posted on: 2010/2/5 22:52
22812 Posts
Dan, when I swapped the rear I used synthetic Mobil 1 (I think 75-90??? I'll have to look in the garage if I still have it) and two bottles of GM friction modifier. Some synthetics already have it included, so check the bottle.
Posted on: 2010/2/6 3:41
I ended up going with Lucas rear oil, and no additive. The bottle says no additive needed for limited slip rears, it is already in there. Says it is good for any type of rear with no additive needed. I saw they had Redline synthetic but at $19 per bottle I just couldn't drop the money on it, compared to the Lucas at $7 and change.
Got the rear pieces all bolted back on and done. Got the exhaust back up. All I need to do now is pull a tranny cooler line to get some more tranny fluid out, then refill it with B+M Synthetic Trick Shift (wanted a synthetic fluid so it has less viscosity change to temp, but would still grab good and not slip so I'm trying this). Then bolt the wheels on and run it on the jackstands to make sure all is good and the speedo works and all. After that, just gotta put the X-brace back on and get it down off the stands and the D44 swap is done!
Next up will be a new heavier gauge power wire to the nitrous bottle heaters (since I added a second heater I can smell the power wire melting it's coating), and installation of my new sunvisors.
Posted on: 2010/2/12 15:19
Josh Re: D44 swap....and D36 diagnosis
Put some jack stands or something under the knuckles before you run the car. I chucked a U-joint once running the wheels with the suspension at full droop. Do something to level out the half shafts a bit.
Posted on: 2010/2/12 15:41
jhammons01 Re: D44 swap....and D36 diagnosis
Most Differential (Dana 36/44) experts say to use 80/90w Gear oil and TWO bottles of additive.
So you've put a quart and half in there and how much additive??
The question that would bother me is this. if the thing takes a quart and a half and GM says ONE bottle of additive....then you've put a lube in there that has the additive......hypothetically you should have 1.5 bottle of additive........
So whether you buy into the now day experts say or what GM says.....you are halfway in the middle of both.
Listen, and if you hear the clicking from the Differential, you'll have your answer.
Posted on: 2010/2/12 16:19
Now, if this were the 'other' place, you'd have 50 guys telling you it is fine to roll it with the wheels hanging.
Posted on: 2010/2/12 16:21
Agreed. I searched the internet pretty heavy with no definitive answer. Many say to add a bottle of additive anyway, many say not to with the Lucas 80W90 gear oil. The bottle says no additive needed for limiited slip differentials and it is GL5 compliant. I'll drive it and listen for any noise at all out of the rear.
My Chilton's says to use 3.75 pints. Mine only took about 1.5 quarts, which is 3 pints. That is after I ran it, put it down on the level, and topped it off. I'm thinking it's because the adapter plate I used takes up some fluid space in the rear.
Posted on: 2010/2/12 23:39
GREAT idea, however too late for me. I ran it on the jackstands for maybe 1 or 1.5 minutes. Took it up to 65 mph tops just once. Mostly 45 and below. Didn't seem to have any problems, but never thought of what you just said, next time I'll do that. I'm hoping you had a U-joint ready to chuck itself anyway and that's why it happened.
I did finish up the rear swap, ran it on the stands, all seemed and sounded fine, speedometer is working (I changed the driven gear for the new rear gearing) and all. I then put the X-brace back on and buttoned up the odds and ends. Barring any problems or noises on the first test drive I'm officially a 3.45 geared D44 rear ready to break into the 11's on motor and rip off a 10.40 on the spray. I'm going to give C409's adapter plate a good test!
Posted on: 2010/2/12 23:41
