219 user(s) are online (147 user(s) are browsing Forums)
1st Gear: 1.76/1.82
2nd Gear: 1.00
- 14 Bolt Pan.
- Vac...
vis_croceus what goes under this bolt (LT1)
VA
260 Posts
My "before" pics are failing me on this one:
Posted on: 2010/7/6 1:15
bogus Re: what goes under this bolt (LT1)
bracket for ICM?
Posted on: 2010/7/6 1:20
vis_croceus Re: what goes under this bolt (LT1)
VA
260 Posts
bracket for ICM?
That goes on the head. This is on the block.
Seems like maybe it would hold a wiring harness clamp or something like that.
Here's the previous pic in the series. It's peeking out from behind the ICM/coil bolt.
Probably I'll get done and whatever it is will be in the leftover parts pile. At least it is near the top where I can get back to it...
Posted on: 2010/7/6 1:47
94 vert
1Fast04Vert Re: what goes under this bolt (LT1)
I will take a look at mine in the morning and tell you what I see there.
Posted on: 2010/7/6 2:16
tjpreul Re: what goes under this bolt (LT1)
I looked on my '92 and there is nothing bolted into that spot. In your second picture it looks like that is the one for the ICM.
Posted on: 2010/7/6 2:20
MK 82 Re: what goes under this bolt (LT1)
Palm Beach Gardens, FL
439 Posts
There is nothing there on my LT4.
[IMG]http://i244.photobucket.com/albums/gg8/LT496/DSC00241.jpg[/IMG]
[IMG]http://i244.photobucket.com/albums/gg8/LT496/Bolt-1.jpg[/IMG]
Posted on: 2010/7/6 3:14
96 CE Roadster LT4
BillH Re: what goes under this bolt (LT1)
Steve, that's a ground connection. There should be a ring terminal on a single wire that comes out of the harness that has the IAC connector in it (at least on a 92). The bolt also has a star washer on it.
Posted on: 2010/7/6 13:17
pianoguy Re: what goes under this bolt (LT1)
That looks like a good place to bolt on a Turbonator.
pr0zac Re: what goes under this bolt (LT1)
its an empty hole on my car.
Posted on: 2010/7/6 16:02
439 Posts
Must have changed over the years. There is no ground there on my 96 LT4.
Eddie
Posted on: 2010/7/6 16:43
96 CE Roadster LT4
Yea, GM probably changed it to save $0.02.
jpg  IMGP0822.JPG (0.00 KB)
Posted on: 2010/7/6 19:35
BrianCunningham Re: what goes under this bolt (LT1)
Nice trivia question though
Posted on: 2010/7/6 21:10
VA
260 Posts
Bingo! Thanks!
Posted on: 2010/7/6 23:31
94 vert
