vis_croceus | what goes under this bolt (LT1) | ||
My "before" pics are failing me on this one:
Posted on: 2010/7/6 1:15
bogus | Re: what goes under this bolt (LT1) | ||
bracket for ICM?
Posted on: 2010/7/6 1:20
vis_croceus | Re: what goes under this bolt (LT1) | ||
That goes on the head. This is on the block. Seems like maybe it would hold a wiring harness clamp or something like that. Here's the previous pic in the series. It's peeking out from behind the ICM/coil bolt. Probably I'll get done and whatever it is will be in the leftover parts pile. At least it is near the top where I can get back to it... |
Posted on: 2010/7/6 1:47
94 vert |
1Fast04Vert | Re: what goes under this bolt (LT1) | ||
I will take a look at mine in the morning and tell you what I see there.
Posted on: 2010/7/6 2:16
tjpreul | Re: what goes under this bolt (LT1) | ||
I looked on my '92 and there is nothing bolted into that spot. In your second picture it looks like that is the one for the ICM.
Posted on: 2010/7/6 2:20
MK 82 | Re: what goes under this bolt (LT1) | ||
There is nothing there on my LT4.
[IMG]http://i244.photobucket.com/albums/gg8/LT496/DSC00241.jpg[/IMG] [IMG]http://i244.photobucket.com/albums/gg8/LT496/Bolt-1.jpg[/IMG] |
Posted on: 2010/7/6 3:14
96 CE Roadster LT4 |
BillH | Re: what goes under this bolt (LT1) | ||
Steve, that's a ground connection. There should be a ring terminal on a single wire that comes out of the harness that has the IAC connector in it (at least on a 92). The bolt also has a star washer on it.
Posted on: 2010/7/6 13:17
pianoguy | Re: what goes under this bolt (LT1) | ||
That looks like a good place to bolt on a Turbonator.
pr0zac | Re: what goes under this bolt (LT1) | ||
its an empty hole on my car.
Posted on: 2010/7/6 16:02
Must have changed over the years. There is no ground there on my 96 LT4.
Eddie |
Posted on: 2010/7/6 16:43
Yea, GM probably changed it to save $0.02.
Attach file: IMGP0822.JPG (0.00 KB) |
Posted on: 2010/7/6 19:35
BrianCunningham | Re: what goes under this bolt (LT1) | ||
Nice trivia question though
Posted on: 2010/7/6 21:10
Bingo! Thanks! |
Posted on: 2010/7/6 23:31
94 vert |
